Question about Sony XM-2200GTX Car Audio Amplifier
When my amp is on 2 blue lights come on - Sony XM-2200GTX Car Audio Amplifier
    Champion:
  • 222 Answers
Check your supplies
Posted on Jun 11, 2010
1996 grand cherakee.Fuse Panel diagram
Good lord there are fuses everywhere in that truck if I remember right, you'd have been better off asking about the problem I think.. try here
http://www.jeep4x4center.com/knowledge-base/index.htm#service
find your truck, pull up the PDF then on your keyboard hit the find box (F3?) punch in "fuse" and run down the list...
For the basic panel
Cavity/Fuse Diagram (1996 Grand Cherokee, passenger side kick plate to find, Owner's Manual pgs 205-206): CAVITY FUSE DESCRIPTION 1 10 amp (RED) Radio 2 15 amp (Lt Blue) Cigarette Lighter 3 10 amp (RED) Rear Washer Switch, Body Controller 4 10 amp (RED) Airbag 5 10 amp (RED) Lamp Out Module, Overdrive Switch, OBD II 6 15 amp (Lt Blue) Vehicle Information Center/Graphic Display Module Park & Side Lamps, Overhead Console Lighted Visor, Automatic Dimming Mirror 7 20 amp (Yellow) Body Amp, Cluster, Body Controller 8 20 amp (Yellow) Rear Wiper Motor, Flipper Glass Solenoid, Cargo Lamp, Trailer Tow 9 15 amp (Lt Blue) Brake Switch 10 10 amp (RED) Rear Window Defroster 11 10 amp (RED) ABS Module 12 10 amp (RED) Heater-Ventilation-A/C Control & Recirculation Motor 13 15 amp (Lt Blue) Hazard Switch, Turn Signal Switch 14 15 amp (Lt Blue) Spare 15 15 amp (Lt Blue) Spare 16 10 amp (RED) Right & Left Courtesy Lamp, Glove Box Lamp, Halo Lamp Cargo Lamp, Underhood Lamp, Dome/Read Lamp Right & Left Visor, Automatic Dimming Mirror 17 15 amp (Lt Blue) Radio Illumination, Tail Lamp, Graphic Display Module, Park & Side Lamps, Headlamp Switch, Body Controller 18 20 amp (Yellow) Spare 19 15 amp (Lt Blue) Passing Light 20 15 amp (Lt Blue) Radio, Heater-Ventilation-A/C, Vehicle Information Center 21 15 amp (Lt Blue) Power Outlet 22 10 amp (Blue) Airbag Module Turn signals are in the flasher and it is located on the driver side below the dash (where the buzzer is located). It is a cylinder type relay. You will find two, one for the hazzard lights and the other for the signals.
Sep 19, 2014 | 1996 Jeep Grand Cherokee
Schematic to driver side fuse box
Cavity Fuse Description
1) 15 Amp Blue Horn Relay, Power Sunroof
Relay, Power Window Relay
2) 10 Amp Red Rear Fog Lights (Export Only)
3) 20 Amp Yellow Cigar Lighter
4) 10 Amp Red Headlight Low Beam Right
5) 10 Amp Red Headlight Low Beam Left
6) 20 Amp Yellow Body Control Module/Power Door Locks
7 )10 Amp Red Left Park Light/Left Tail Lamp/License Plate Lamp
8) Spare
9) 10 Amp Red Right Park Light/RightTail Lamp/License Plate Lamp/Cluster
10) Spare Cavity Fuse Description
11) 15 Amp Blue Flasher
12) 15 Amp Blue Stop Lights
13) 10 Amp Red Body Control Module/CMTC/Cluster/Pass. Airbag On,Off Indicator, Auto Daylight
Mirror/Light Bar Switch (Renegade Only)
14) 10 Amp Red PDC Fuel Pump/AC Clutch,
Starter Relay/Engine
Controller/Transmission
Controller (Diesel Only)
15) Spare
16) 20 Amp Yellow Power Outlet (Rear)
17) 15 Amp Blue Rear Wiper
18) 20 Amp Yellow Radio Choke & Relay
19 20 Amp Yellow
Frt Fog Lights/Trailer Tow
Stop and Turn Lights
20 Spare
21 10 Amp Red Radio
22 20 Amp Yellow
Power Sunroof Relay/
Antenna Module (Export
Only)
23 Spare
24 10 Amp Red PDC Blower Motor
25 10 Amp Red Heated Seat Switches/HVAC
Control Head/Trailer Tow
Battery Charge
26 10 Amp Red Headlight High Beam Right
27 10 Amp Red Headlight High Beam Left
28 Spare
29 10 Amp Red Heated Mirrors/Rear Window
Defroster Indicator
30 15 Amp Blue Heated Seat Module
31 Spare
32 10 Amp Red Wiper Switch/Front and
Rear Wipers
33 10 Amp Red SKIM Module/Data Link
Connector
34 15 Amp Blue Body Control Module/
Cluster/Interior Lights,
Hands Free Module/Radio/
CMTC/ITM Module & Siren
(Export Only)
35 Spare
36 10 Amp Red Airbag Control Module/
Occupation Classification
Module (Right Front Seat)
37 10 Amp Red Airbag Control Module
38 10 Amp Red ABS Controller/Shifter Assembly
39 10 Amp Red Hazard Flasher (Turn
Signals)/Backup Lamp
Switch (Manual Transmission
Only)/Transmission Range
Switch (Automatic Transmis
May 23, 2011 | 2005 Jeep Liberty
Dodge charger fuse box , where the fog lights relay goes ?Thanks
Cavity/ Fuse /Circuits
1/ 20 Amp Yellow/ Left High Beam Headlight
2/ 20 Amp Yellow/ Right High Beam Headlight
3/ 15 Amp Dk. Blue/ Adjustable Pedal
4/ 20 Amp Yellow/ Horn
5/ 25 Amp Clear/ Headlamp Washer - If Equipped
6/ 15 Amp Dk. Blue/ Front Control Module (FCM)
7/ 20 Amp Yellow/ Fog Lamp
8/ 15 Amp Dk. Blue/ Park Lamp
9/ 15 Amp Dk. Blue/ Non ABS Brakes
10/ 5 Amp Orange/ Starter
11/ 20 Amp Yellow/ Auto Shutdown/Powertrain Control Module (PCM)
12/ - -
13/ - -
14/ 25 Amp Clear/ Powertrain Control Module
15/ 20 Amp Yellow/ Injectors, Ignition Coils
16/ 15 Amp Dk. Blue/ Powertrain Control Module
17/ 30 Amp Pink/ Antilock Brake System (ABS) Valves
18/ 30 Amp Pink/ Windshield Wiper/Washer
19/ 50 Amp Red/ Radiator Fan
20/ 20 Amp Lt. Blue/ Starter
21/ 50 Amp Red/ ABS Pump Motor
22/ 40 Amp Green/ Radiator Fan High/Low
23/ 50 Amp Red/ High Intensity Lighting
24/ - -
25/ 30 Amp Pink/ Lighting Left High Beam/Right Low Beam
26/ 20 Amp Lt. Blue/ Transmission
27/ 30 Amp Pink/ Lighting Left Low Beam/Right High Beam
if this helps please rate 4 thumbs up.
Jan 21, 2011 | 2007 Dodge Charger SRT8 Sedan
How to disarm or reset an alarm system for a 1996 Jeep Cherokee?
Hope this helps:- Factory Disarm Purple/Yellow (-) Driver's Kick Panel Black Connector at ECM -slice into this wire, & wire it to ground, this disables the alarm.
Cavity/Fuse Diagram (1996 Grand Cherokee, passenger side kick plate to find, Owner's Manual pgs 205-206): 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22
Row 1: 1-6 (left to right) Row 2: 7-12 Row 3: 13-18 Row 4: 19-22
1996 Jeep Grand Cherokee Fuse Panel (Passenger Side kick panel) Reply
CAVITY FUSE DESCRIPTION 1 -10 amp (RED) Radio 2 -15 amp (Lt Blue) Cigarette Lighter 3 -10 amp (RED) Rear Washer Switch, Body Controller 4 -10 amp (RED) Airbag 5 -10 amp (RED) Lamp Out Module, Overdrive Switch, OBD II 6 -15 amp (Lt Blue) Vehicle Information Center/Graphic Display Module Park & Side Lamps, Overhead Console Lighted Visor, Automatic Dimming Mirror 7 -20 amp (Yellow) Body Amp, Cluster, Body Controller 8 -20 amp (Yellow) Rear Wiper Motor, Flipper Glass Solenoid, Cargo Lamp, Trailer Tow 9 -15 amp (Lt Blue) Brake Switch 10- 10 amp (RED) Rear Window Defroster 11 -10 amp (RED) ABS Module 12 -10 amp (RED) Heater-Ventilation-A/C Control & Recirculation Motor 13 -15 amp (Lt Blue) Hazard Switch, Turn Signal Switch 14 -15 amp (Lt Blue) Spare 15 -15 amp (Lt Blue) Spare 16 -10 amp (RED) Right & Left Courtesy Lamp, Glove Box Lamp, Halo Lamp Cargo Lamp, Underhood Lamp, Dome/Read Lamp Right & Left Visor, Automatic Dimming Mirror 17 -15 amp (Lt Blue) Radio Illumination, Tail Lamp, Graphic Display Module, Park & Side Lamps, Headlamp Switch, Body Controller 18 -20 amp (Yellow) Spare 19 -15 amp (Lt Blue) Passing Light 20 -15 amp (Lt Blue) Radio, Heater-Ventilation-A/C, Vehicle Information Center 21 -15 amp (Lt Blue) Power Outlet 22 -10 amp (Blue) Airbag Module -------------------------------------------------------------------------------------
1996 Jeep Grand Cherokee Alarm, Remote Starter, Keyless Entry Wiring Information Constant 12V+ Pink/Black Ignition Switch Harness Starter Yellow Ignition Switch Harness Ignition Dark Blue/Gray Ignition Switch Harness Ignition 2 Red/Black Ignition Switch Harness (for AC) Accessory Black/Orange Ignition Switch Harness Tach Gray/White Coil Brake Switch White/Tan Brake Switch Trunk Pin n/a Works with Dome Light Parking Lights Blue/Red (+) Left of Steering Column or Light Switch Head Lamp Tan/Black Light Switch Factory Disarm Purple/Yellow (-) Driver's Kick Panel Black Connector at ECM -slice into this wire, & wire it to ground, this disables the alarm. Door Trigger Yellow (-) Driver's Kick Panel see notes Door Lock 5/Wire in Driver's Inside Driver's Door Orange/Purple Lock Pink/Black Unlock Door Unlock and Passenger's Doors Inside Passenger's Door Black/White L Pink/Black Unlock Horn Wire Gray/Orange (-) Steering Column Windows Up LF=Light Blue, RF=Brown/White, LR=Blue/White, RR=Gray/Black Doors Windows Down LF=White, RF=Purple/White, LR=Red/Black, RR=Green/White
• Cruise Control Information • Stereo Information • View all Jeep Vehicles
Dec 18, 2010 | 1996 Jeep Grand Cherokee
I have a 1996 Jeep Cherokee and the heater vents dont work.I have tried to find a picture of the fuse panel i can read but i cant..When you swith it to vents it only comes out of the defrost.Where can i...
Hope this helps:
1996 Jeep Grand Cherokee Alarm, Remote Starter, Keyless Entry Wiring Information Constant 12V+ Pink/Black Ignition Switch Harness Starter Yellow Ignition Switch Harness Ignition Dark Blue/Gray Ignition Switch Harness Ignition 2 Red/Black Ignition Switch Harness (for AC) Accessory Black/Orange Ignition Switch Harness Tach Gray/White Coil Brake Switch White/Tan Brake Switch Trunk Pin n/a Works with Dome Light Parking Lights Blue/Red (+) Left of Steering Column or Light Switch Head Lamp Tan/Black Light Switch Factory Disarm Purple/Yellow (-) Driver's Kick Panel Black Connector at ECM Door Trigger Yellow (-) Driver's Kick Panel see notes Door Lock 5/Wire in Driver's Inside Driver's Door Orange/Purple Lock Pink/Black Unlock Door Unlock and Passenger's Doors Inside Passenger's Door Black/White L Pink/Black Unlock Horn Wire Gray/Orange (-) Steering Column Windows Up LF=Light Blue, RF=Brown/White, LR=Blue/White, RR=Gray/Black Doors Windows Down LF=White, RF=Purple/White, LR=Red/Black, RR=Green/White
• Cruise Control Information • Stereo Information • View all Jeep Vehiclesairconman.jpg
Dec 16, 2010 | 1996 Jeep Grand Cherokee
What is the fuse box layout for 1986 Lincoln Town Car?
Here is a recap by fuse/CB:
1. 15 amp -Light Blue
2. 8.25 amp -CB
3. Not Usable
4. 15 amp -Light Blue
5. 15 amp -Light Blue
6. 20 amp -Yellow
7. 10 amp -Red
8. 15 amp -Light Blue
9. 30 amp -Light Green
10. Not Used
11. 20 amp -Yellow
12. 20 amp -CB
13. 5 amp -Tan
14. 20 amp -CB
15. 10 amp -Red
16. 20 amp -Yellow
17. 15 amp -Light Blue
18. 10 amp -Red
Do you have a problem with a specific device? Let me know and I may be able to tell you what Fuse/CB.
Jul 23, 2010 | 1986 Lincoln Town Car
Fusebox diagram
hi, this is courtesy of ask me help desk...
FUSE PANEL INTERIOR
1 - 20 Amp (Yellow)Power Antenna Relay, Trailer Tow Relay.
2 - 15 Amp (Blue) Brake Lamps.
3 - 20 Amp (Yellow) Hazard Lamps.
4 - 15 Amp (Blue) Security Lamp.
5 - 15 Amp (Blue) Interior Lighting.
6 - 15 Amp (Blue) Security Alarm Module.
7 - 15 Amp (Blue) Security Alarm Relay, Security Alarm Module, Flash-To-Pass.
8 - 15 Amp (Blue) Overhead Console, Keyless Entry, Radio Memory, Clock/Chime Module, Power Locks, Power Mirrors, HVAC & VIC.
9 - 20 Amp (Yellow) Rear Wiper.
10 - 15 Amp (Blue) Radio Accessory.
11 - 15 Amp (Blue) Cigar Lighter.
12 - 15 Amp (Blue) Parking Lamps, Automatic Headlamps.
13 - 20 Amp (Yellow) Horn Relay.
14 - 20 Amp (Yellow) Power Lock Relays.
15 - 3 Amp (Violet) ABS Module & Relay.
16 - 20 Amp (Yellow) Turn Signals.
17 - 7.5 Amp (Brown) Heater & Air Conditioning Module.
18 - 15 Amp (Blue) Air Bag Module.
19 - 15 Amp (Blue) Interior Mirror, Auto Headlamps, Overhead Console, VIC/GDM Module, Heated Rear Window Relay Coil, Illuminated Entry Relay & Chime Module.
20 - 10 Amp (Red) Heated Rear Window Switch, Overdrive Switch, Speed Control.
21 - 15 Amp (Blue) Cluster, Security Alarm Module, Lamp Outage Module.
22 - 15 Amp (Blue) Air Bag Module, Speedometer, Tachometer, Telltales, Gauges.
23 - 15 Amp (Blue) Heated Mirror Feed, Heated Rear Window Switch.
24 - 7.5 Amp (Brown) Instrument Panel Illumination.
25 - 30 Amp Circuit Breaker Power Seats.
26 - 30 Amp Circuit Breaker Power Windows.
27 - 10 Amp Circuit Breaker Security Alarm Module, Front Wiper.
28 - 30 Amp Circuit Breaker Heated Rear Window Relay
Nov 27, 2009 | 1993 Jeep Grand Cherokee
Is there a way to shut off blue light
Hi my name is Eric,
I hope I can help you with your issue ,
Yes you can turn off the annoying blue power light, go into the menu and look for the item called blue eye effect on/off
Press the MENU button.
Press the ▲ or ▼ button to select “Setup”, then press
the ENTER button.
2 Press the ▲ or ▼ button to select “Blue Eye”, then press
the ENTER button.
3 Press the ▲ or ▼ button to select “Off” or “On”, then
press the ENTER button.
• Off : LED(Blue) will not come on when you turn the TV
on and off.
• On : LED(Blue) will come on when you turn the TV
on and off.
4 Press the EXIT button to exit.
If you feel good about my solution please click accept.
If you have more questions you can still respond,
I will reply asap
Thanks
Eric
Sep 14, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
Blue amp light lights for 2sec
bad head unit or look at your ground wire good luck
May 24, 2008 | Car Audio & Video
Sony XM-2200GTX Car Audio Amplifier Logo
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Philip Rowney
Philip Rowney
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
