Question about NEC Electra Elite 32D-1 Corded Phone
Extensions Is there a way tp program the phone to pick up other extensions in the office?
Call Pickup Direct
Upon hearing ringing or voice
announcement at another
telephone:
1. Lift the handset.
2. Dial the Call Pickup Direct
code 67.
3. Dial the station number of
the telephone to be
answered.
4. Converse.
Posted on Apr 24, 2008
Need to change extension numbers
Guessing you mean add or change extension numbers under the buttons, since you don't "add" or change extension numbers on the phone. From your set, press program dial 99 and the button you want to program. then , dial 1+ ext number and press STORE.
Do that for all the buttons you want to change then pick up the handset and drop it back down to exit programming.
Apr 10, 2013 | Panasonic KX-T7433B Corded Phone
Old Norstar phone-one line seemingly tied to one extension
You most likely need to call in your tech who looks after the programming there.
Needle in haystack, sticky button, bad programming, glitch in system, answer dn etc.
Dec 10, 2012 | NorStar M7310 Corded Phone
Panasonic KX-T7420. There are several of these phones in our office, I would like to know how to reset all extension numbers at each phone and create new ones.
Reset? How about you just program new ones over the old? I'm guessing you mean intercom DSS buttons, so you dial PROGRAM 99, press the button and dial 1+ the new extension STORE. Keep doing that to all the buttons you want to program and then pick up the handset and drop it back down again when you're done.
Carl
Dec 23, 2010 | Panasonic KX-T7420 Corded Phone
I have 1 extension that will not go to voice mail. I have tried the *713 and a 2 digit number between 00 and 99 and it still just rings endlessly. When I make an inner office call to this ext... it picks...
What happens when you TRANSFER an outside call to that extension? If that works, you have Intercept issues which is handled with programming. If it still does not transfer, you have CF issues, started by a *710x command for both internal and outside calls.
Carl
Aug 11, 2010 | Panasonic KX-T7633 Corded Phone
How can we transfer phone in internal office call
You could press the HOLD button and tell the other person to pick up...making sure that you only press it once. You could press the TRANSFER key and dial the 3 digit extension of the other phone, or you could program a DSS button (PROG button 1+ext STORE) on a left side button (the ones with lights) and just press that button without pressing HOLD.
Three choices. Pick one.
Carl
Apr 21, 2010 | Panasonic KX-T7730 Corded Phone
Programming extensions in the phone
If you have manual(z), they should. One, the OM (operating manual) will tell you how to set up your personal programming.
The buttons on the left side of a 7730 have lights, the buttons on the right do not, so they are programmed differently. Left side is DSS, right side is PF (personal feature). If you have spare left side buttons, press PROGRAM the button and dial 1 plus the ext number and STORE. The light will now follow the activity of the extension you programmed.
The buttons on the right have no lights, so you can only put in extension speed dial numbers. For that, press PROGRAM, the button, and dial the 3 digit extension number and STORE.
Depending on the system your phone is connected with, you can just press the button to dial, or you have to pick up the handset or SP-PHONE and select intercom (if not selected) and it will dial that extension, or if the system is a TAW, TD or higher, just press the button.
Carl
Dec 03, 2009 | Panasonic KX-T7730 Corded Phone
Extension cant answer in night service
This is a programed feature for the phone system. You will need to have your vendor reprogram the system to either allow for more rings, or simply turn the night service option off when still in the office.
Oct 14, 2009 | Mitel 5212 IP Phone
I have three questions regarding the Avaya One-X Quick Connect G11 PSTN Gateway. 1. Can it be programmed to ring all phones and if noone answers then go to extension 200 voicemail? 2. Can you get rid of...
1. Can it be programmed to ring2.gif all phones and if noone answers then go to extension 200 voicemail?
Yes, you need to browse to the gateways IP and look at the destination of the lines. If a single extension is the destination, you need to make a group, put all the phones in it, and then point the lines to that group.
2. Can you get rid of the dial 9 to get an outside line and just grab available line when handset is picked up?
No, unfortunately you can not.
3.How do you eliminate noise and echo in the background when on a call?Also has some bleeding over, someone else in the office could hear meon the phone when they were on the phone.
Make sure the gateway is grounded to a good ground. if the problem persists, you can try to upgrade the gateway and phones.
Oct 09, 2009 | Avaya ONE-X QUICK OFFICE EDITION TRUNK...
Panasonic phone
This system will have to be programmed to allow line 1 to ring on that particular set. When you pick up line 1 now and it dials out it is dialing the last number you called from the phone.
May 28, 2009 | Panasonic KX-T7730 Corded Phone
Can not pick up line on incoming calls from one extension only
That's what happens when you plug in the system and don't program it. You need to review ICD groups.
By default, the phone connected to the first extension is the master phone and the only phone that rings.
Carl
Aug 08, 2008 | Panasonic KX-T7630 Corded Phone
NEC Electra Elite 32D-1 Corded Phone Logo
216 people viewed this question
Top NEC Lands Phones Experts
Craig Butler
Craig Butler
Oloyede Monsuru
SC Spike
Level 1 Expert
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
