Question about Emerson EWC27T3 27 in. TV/VCR/DVD Combo
TV picture Have Emerson TV/DVD/VCR combo, 27". Across the top of screen is black bar approx. 1". Next is 3" of screen that looks like the top of the picture has inverted on itself, writing from satellite or ball game score is chopped off or upside down. ????
  • 979 Answers
This set will need to be serviced by a tech shop as you have a problem called "vertical foldover"...accordianman
Posted on May 08, 2008
I have sound but no picture. The screen is black
can you see any any menus or the volume bar or channel indicator?
Make sure all your audio and video cables are hooked up correctly to inputs on the TV and to the same set of hookups. For example all of the VCR cables hooked into video 1 and all of the DVD cables in video 2.
Also check that you haven't hooked up the video to the tv's output. Some sets output audio and/or video for external devices such as recording setups or home theater sound systems.
Oct 17, 2009 | Zenith TVBR2742Z 27 in. TV/VCR Combo
Ewd2202 dvd/vcr combo when i put a vcr tape i can
the video heads are probably dirty.there is a steel drum 1/2 inch thick that you can see if you look thru the front lid where the tape loads.the video heads are little black spec looking things on the bottom of the drum.the easiest way to clean the drum for a novice is to put isopropyl alcohol on a piece of 2 inch square paper.hold the paper very lightly against the drum with your right index finger.turn the drum from the top,anti clockwise.you will see some black stuff on the paper.do the same with a piece of dry paper.otherwise the tape will stick to the drum if still wet.DO NOT use a q tip,as it will get caught in the heads and break them.
sometimes,just running a new blank tape for 15minutes will dislodge the particles and the picture will re appear.if you have recently rented a movie,and saw lines running across the screen,and noise from inside the machine,it is damaged tape going across the heads and drum and it can wipe out the picture just like that.run a blank tape first and then clean the drum if you have to.
Jul 07, 2009 | Emerson EWD2202 DVD Player/VCR
Need code for Emerson TV,DVD,VCR Combo
you can set up any like this
1. turn on what ever you want set up
2. press and hold set up tell light blinks or stays lit
3. push what you are trying to set up t.v. or dvd ect.
4. push power on/off tell it turns off
5. push enter when it turns off
Thank you for useing fixya please rate me
Feb 12, 2009 | RCA Universal Remote 3 Device Remote...
I don't know if you guys even need this advice anymore, as it's 1-2 years late, but if your universal remote has a VCR setting, the Emerson 13" CRT TV/VCR combo I have operates under that mode.
The code I used was 002. These may also work: 278, 184, 479, 000, 121, 211, 037, 043, 061, 208
Remember, program your remote as if you were setting up a VCR (and NOT a TV). For instance, on my GE universal, I hold the "code search" button down until I get a steady light. I hit VCR, and then I entered 002. Works like a charm.
Mar 25, 2008 | RCA Universal Remote 3 Device Remote...
Help me connect my components...
on the remote it should say menu it would probably be in the pitcher side set it to 4.3 or 4.5 or so on it is the setting you need ok hope that help
Jan 03, 2008 | Akai LCT2785TA 27 in. LCD Television
Emerson EWC27T3
Your vertical coupling capacitor is going bad, without a schematic you don't know which cap this is. Might I suggest that you get a schematic from the vendor or from one of the site on the web that carry schematics. To fix this problem you need to know which cap is the vertical coupling capacitor.
Sep 08, 2007 | Emerson EWC27T3 27 in. TV/VCR/DVD Combo
Convergence problem
This is a vertical problem it seem like the vertical coupling capacitor has gone bad. If you do not have experience in electronics "DONT TRY TO REPAIR THIS SET" because of the danger involved, take it (The TV set) to a qualified TV repair shop in your area.
Jan 29, 2007 | Emerson EWC27T3 27 in. TV/VCR/DVD Combo
Picture is hourglassed shaped
your unit has a problem in horizontal circuit particularly deflection and pincunshion circuit. pls have it check by a qualified service technician.
Jan 15, 2007 | Emerson EWC27T3 27 in. TV/VCR/DVD Combo
Emerson EWC27T3 27 in. TV/VCR/DVD Combo Logo
229 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
