Question about Sport & Outdoor - Others
I need a forward, reverse switch for a minn kota trolling motor weedless 35, 4 speed, 17 lb thrust. where can I buy one?
  • dmoore96 Jun 04, 2010
    I don`t need a new motor, I just need a forward, reverse switch for a weedless 35 4 speed minn kota trolling motor. where can i buy one?
    I won`t know if it will help or not until i can get the part. Thanks, I will try that number
  • 1,284 Answers
Hi, you have to contact Minn Kota Motors on 800-227-6433 to make a request for the parts and you will either be sent the parts or you will be directed to there nearest store around you to purchase it...
Take care
Posted on Jun 04, 2010
    President:
  • 567 Answers
Hi thanks for asking, you can buy forward, reverse switch for a minn kota trolling motor weedless 35, 4 speed, 17 lb thrust from
http://www.reelreports.com/store/Minn-Kota-Model-35-Boat-Trolling-Motor---17-Lbs-Thrust-140393963372.html
Thank you
I need to find an owner's manual for a 2005 minn kota riptide weedless wedge 2 80 lb thrust
Have you inquired with a local dealer? Iam sure you can get one off internet.
Sep 14, 2017 | Minn Kota Boating
Only have a model number and need to order a Minn Kota electric motor propellor
Minn Kota go by the thrust which is mentioned on the top plate. I got mine off Craigs List as well.
  • Minn Kota Prop Compatibility Chart - TrollingMotors.net https://www.trollingmotors.net/blogs/selection/86967623-minn-kota... Minn Kota Prop Compatibility Chart Minn Kota Prop Charts. ... Minn Kota with a serial number and they can recommend a compatible prop for your older Minn Kota motor. ...
  • Minn Kota Motors www.minnkotamotors.com Prop Selection & Part ... Electric Anchor Winches; Shop All; APPAREL. ... A combination of a Minn Kota motor and foot controlled rudder steering allow you truly ...
  • Trolling Motor Replacement Props - Minn Kota www.minnkotamotors.com/Accessories/Trolling-Motor-Accessories/... Minn Kota builds the world's toughest ... Electric Anchor Winches; Shop All; APPAREL. Mens; Ladies; Youth; Shop All; WHAT MOTOR DO I NEED? LET US HELP YOU ...
  • Minn Kota Replacement Propellers - www.fishntech https://www.fishntech.com/minn_kota_propellers.html ... Minn Kota Electric Trolling Motor Replacement Propellers & Nut Kits, ... Minn Kota Replacement Propellers . ... Minn Kota Electric Trolling Motor Replacement ...
  • Minn Kota props replacement props for Minn Kota www.minn-kota.com/minn-kota/minn-kota-propellor/page/2 Minn Kota Replacement Props for propellor Weedless Wedge 2 Props ... Minn Kota MKP 3 Prop 2061151 ... MinnKota Trolling Motor Power Center $57.58; DeckHand Electric ...
  • MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ' ... www.ebay.ca/sch/...nkw=MINNKOTA+MKP+37+2091170+TROLLING+MOTOR+P... Find best value and selection for your MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ... MINNKOTA MKP 37 2091170 TROLLING ... MINN KOTA ...
  • Jun 08, 2016 | Minn Kota Endura 30 Freshwater Transom...
    Minn kota trolling motor has forward but no reverse
    Don't know what Minn Kota you are talking abut but my 55 pound Thrust one does NOT have a Reverse.... When I want reverse I swing the Prop all the way around so it is pulling the boat backwards..... I just checked it to refresh my memory......
    May 08, 2014 | Minn Kota Boating
    Is there any way to modify in order to get more power/thrust out of a mk 30lb other than stock? or can you take a moto guide 80 lb., bow mount foot control, shaft and motor and combine it with transom...
    Hey Chris,, you are starting a project (or wanting to) that is going to be problematic... It will be easier to go buy a new trolling motor with the money you are going to spend attempting this conversion... the newer trolling motors are so much more efficient...
    Trolling Motors Fishing Motors Electric Boat Motors MotorGuide Trolling...
    https://www.minnkotamotors.com/
    Jul 15, 2017 | Minn Kota Endura 30 Freshwater Transom...
    TOOK THE BOLTS OUT OF MINN KOTA AND CANT GET THEM IN. 2 SHORT.
    Hi!
    Here's a schematic:
    Max 74 Bowmount
    Make sure the end housing #7has a small mark in it pointed to the bottom (towards the skeg). The bolts can be a pain to line up!
    Also make sure the armature is all the way forward it can go....past the brushes is the toughest part to get through and lined up. Keep it up, you'll get it!
    Best of luck
    Mike
    Jul 05, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
    Minn Kota Model 35 24lb thrust transom trolling motor not getting power
    It might help to view drawings at http://secure.northlandmarine.com/MinnkotaTillerSteering.html.
    The spring loaded items are brushes. They carry current to the rotor/shaft/impeller causing them to spin. I have two Model 35s. One failed after a couple hours of use. The other was given to me because it did not work. Both suffer from water getting into the motor and causing corrosion and sticking brushes. Someone on another site commented that this was a common problem for Minn Kota.
    Jul 17, 2008 | Minn Kota Endura 30 Freshwater Transom...
    Sport & Outdoor - Others Logo
    801 people viewed this question
    Top Sport & Outdoor - Others Experts
    Bill Eager
    Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
