Question about Toshiba Satellite A105 Notebook
Screen the screen will get a line across and the screen then freezes not allowing me to do anything unless i grab the top left corner and hold it sideways but i have to hold it here to do anything, it will completely freak out and just send lines and the screen jumps or blacksout during this time, how do i fix this
    Problem Solver:
  • 14 Answers
Generally these problems are related to laptop hardware, so taking it to an authorized service provider may be the only option available. Usually it will require a trip to a service center and part replacements will probably be required. If you just purchased it recently and if it's within your retailer's return policy it would be a good idea to seek a replacement.
If you can provide some more detail about the problem I might be able find a fix or at least provide some more detail. Here are some questions that might help:
1) When does it happen? Is it on start up? Does it happen randomly while using the system?
2) When did this problem start? Has it always been an issue or is it a recent occurrence?
Posted on Apr 12, 2008
    Genius:
  • Toshiba Master
  • 1,689 Answers
You have to send the computer for service. There is a break on the circuit board of the screen or on the mother board, or there is a problem with one of the ribbon cables.
Using the computer like you are can make other damage, and thus increasing the cost of the repair, depending on the nature of the short or open that is occuring!
You may be lucky, and only the ribbon cable assembly has to be replaced. If it is the screen or the mother board that has to be replaced, then the cost will be high.
Laptops can have this type of problem from being handled roughly, dropping, or from a lot of opening and closing of the screen. Most of the time, these computers are very reliable and are trouble free for many years.
Jerry G.
Diagonal lines at 45 degree angle from left top to right bottom of screen
db:: 4.31::Diagonal lines on tm2 screen? fz - Hivmr
www.hivmr.com/db/fzap9jk8dp87mcjk3cc9jsp7fzxk7pz1
There are faint 45 degree diagonal lines covering my brand new tm2 LCD ... with some static looking diagonal lines going from bottom left to top right. .... DB:3.01:Dv6113 Us - Computer Freezes Showing Diagonal Lines On Screen aj ... Also there arediagonal lines that run across the screen at about a 30 degree angle.
3M Privacy Filter for Laptop diagonal-14.1" viewing screen ...
www.amazon.com/3M...diagonal-14.../B00006B8A9
Amazon.com, Inc.
Rating: 3.8 - ‎1,617 reviews
Amazon.com: 3M Privacy Filter for Laptop diagonal-14.1" viewing screen ... Premium 14.0 Inch Privacy Screen for Widescreen Laptop or Computer Monitor .... 3M™ Privacy Filters create a 30-degree cone of vision so on-screen data is .... You'll also notice a large "3M PF14.1W" printed in the top right hand corner of the filter.
FZ190: Faint Diagonal lines on screen? ' NotebookReview
forum.notebookreview.com > ... > VAIO / Sony
Jan 27, 2016 | Computers & Internet
LN46B610A5FXZA Gray Horizontal across full Screen with color vertical lines in lt corner and center of screen
Sounds like a panel defect. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1000 posts to different brand TVs now. Pull up older posts there.
Oct 26, 2012 | Samsung LN46B650 46/49.5 in. LCD HDTV
Very thin black vertical line moving across tv screen left to right on tv
The screen voltage to the picture tube is more than normal. Adjust it by the help of screen pot-meter integrated with Line Output Transformer. Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu at the left top corner or the display window. It will make search easy.
Aug 05, 2012 | Panasonic CT-20SL14 20" TV
I have a Mitsubishi 55"
This set has a convergence problem. You should only need to replace the IC. Part is STK393-110. It sits on the middle board behind the large heatsink. Use a heat transfer compound to ensure repair lasts. If you have no experience soldering (or unsoldering) please use a professional for the work. The traces are fragile and I have fixed many mistakes local DIYers have committed. Goodluck.
Jan 20, 2011 | Mitsubishi WS-55511 55" Rear Projection...
My screen has shrunk down to one long strip and the page is reduced I can't read anything?
Without seeing the page, I can only assume that it has reverted to a condensed version, liberating your workspace. If you look down at the lower right hand corner of the page, you will probably notice three small diagonal lines in the very corner... grab this area with your mouse (click and hold left mouse button depressed while stretching the page to the desired dimension.
Hope this helps.
Nov 24, 2010 | Facebook Social Network
When on internet content is not full page on a imac 24"
Click and hold the bottom right corner of the screen with the tiny 45 degree angle lines on it. While holding down the left click pull this to the right and down. If the screen if not full left then grab the browser just to the right of the Green button and pull it where you want it to be.
Oct 25, 2009 | Apple iMac 24" Desktop
Seven boxes puzzle
1 2 3 4 5 6
. . . . . . 1
. . . . . . 2
. . . . . . 3
. . . . . . 4
. . . . . . 5
. . . . . . 6
first box is the 4 corner dots at top on left hand side
Biggest box is 4th across on first line 1st across on 3rd line 3rd across on last line and 3r up on last line on
next box bottom left hand 2nd across 3up, 1st 2up, 3rd across 2up, bottom line 2nd frm left.
next box is just about inside biggest box, slightly smaller
next box is also inside biggest box again smaller
th other 2 boxes are the same size of the one in the left bottom corner, 1 inside biggest box and then you should find the last on no bother.
Hope this helps
Feb 11, 2009 | Nintendo Professor Layton & the Curious...
Screen lines on MacBook.
Sounds like dropped pixels.  My first guess is the computer has been dropped on its corner, with the pixel dropout radiating diagonally from the corner.
My saint bernard sat on my g3 lombard, and I have vertical pixel dropout because of it, from the top of the screen to the bottom.
And no, it is not normal for a macbook to have lines across the screen.
Linda h.
Mar 19, 2008 | Apple MacBook PC Notebook
Red line across the top
Uh oh, time for convergence board work...accordianman
Jan 12, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Toshiba Satellite A105 Notebook Logo
42 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
