ScanMaker 4800 with ScanWizard 5, V. 5.76 I am importing to Adobe Photoshop 7.0 Everything works along fine then quits with error message: --Insufficient memory to start ScanWizard 5. Quit some programs and try again.-- I have no other programs open except ScanWizard and Photoshop. Tried everything to get it going again. Nothing works. Saw 4-9-08
  • Zirngibism Mar 02, 2009
    I click the Load ScanWizard 5 Icon, and it shows the opening screen for about a second, and up pops an error window entitled "EasyUI" saying "Insufficient memory to start ScanWizard 5.  Quit some programs and try again.
    My only option is to hit OK.
    I've rebooted my computer and tried loading it with no other programs running.  No luck.
MDoe
  • 156 Answers
SOURCE: windows xp problem
Hi
It seems you installed an outdated (16bit Program) for the ScanMaker 4. 16Bit applications/programs and generally DOS based (Windows 3.x and 95) and will not run properly from Windows XP.
First, check http://support.microtek.com/product_dtl_2.phtml?prod_id=23 and download and install Drivers and Plugins for Windows XP.
You may need new 3rd Party Scanner/Image Applications that work in Windows XP. However, if you still want to use the 16Bit application then you will need to run the program in 16Bit Compatibility Mode. To do this, right-click the program executable or shortcut, choose propertise from the drop-down menu, go to the Compatibility Tab and put a tick in "Run this program in compatibility mode for:" From the drop down menu, choose Windows 95 or 98 and apply.
Finally, check the the User's Guide or ReadMe file(s) (if you have it) for more info. Especially, check the recommended OS for the Applications.
I might be wrong, but i think ScanMaker 4 has a SCSI interface. If this is correct, then your laptop or port replica must have a SCSI port. NB: SCSI is not the same as Printer LPT Port.
Regards
Mike
Posted on Mar 23, 2008
  • 3422 Answers
SOURCE: Photoshop 5.5 & 6.0 wont open or install
The only way to fix this problem is to do a system restore.
To do a system restore go START>PROGRAMMES>.ACCESSORIES>SYSTEM TOOLS>SYSTEM RESTORE
NOTE:Please take a backup of all your important data first because you may loose them..
Goodluck,
Please don't forget to rate the solution..
Posted on Apr 06, 2008
  • 88 Answers
SOURCE: wireless mouse all of a
Nice mouse.
I've had some problems with wireless mice in the past, so I will just list the causes and see if one fits the bill for you.
1. Did you move the USB transceiver (this is the device that communicates with the mouse) from one USB port to another? If so, uninstall the mouse and reinstall it using the CD that came with your mouse.
2. Do you have any other wireless devices in the vicinity of your mouse that use a radio frequency rather than infrared, such as a wireless keyboard? If so, you may have a conflict.
3. Were you provided instructions on resetting the RF channel and/or ID code of the mouse? There is a small chance that the channels/codes between the mouse and the transceiver were scrambled and you may need to sync them again.
Hope one of these helps!
Posted on Jul 27, 2008
  • 11 Answers
SOURCE: Desktop screen freezes up when I 'right click' mouse on any ico
This sounds as if there is a problem with Webshots corrupting a specific dll file in the Windows system. I hate to say this, but that usually means a complete reinstall from scratch. I would recommend trying to backup all of the files and reinstall windows.
Posted on Jan 04, 2009
SOURCE: E-machine T2984 will not start
looks like the connections in your system are loose.
just do this remove all the connections hdd,dvd other pci card or graphic cards.any other extra things other than motherboards own. donot connect the hdd or dvd.
then take out the ram and the battery on the motherboard. wait for a while then place the battery back and then insert the ram. place the smps connection to the motherboard and then power up the system.
you should now get the display and warnings that no bootable devices are found.
and check the bios settings after a successful display.
after that connect the devices one by one and check their detecting in the bios then you can keep all the extra cards.
this problem might be causing because of the bad CMOS checksum. just reset the bios through the jumper settings or remove the battery then the system will work fine
Posted on Apr 22, 2009
Scanmaker 3830 driver for windows 7
this helped me with my scanmaker 3830 on windows 7 and windows 8 64bit too
You can download: ScanWizard 5 version 6.63 Here: ftp://microtek:microtek@files165.cyberlynk.net/microtek/pcfiles/drv_sw5_v6_63_ad.exe
Extract to folder on desktop. 1. Plug in your Scanner 2. Go to Control Panel (Windows 7,8 - 64 and 32 bit) 3. Go to Device Manager 4. Go to Imaging devices (or Other devices) 5. Find what windows have installed Right Click 6. Update Driver Software.. 7. Click - Browse my computer for driver software 8. Click - Let me pick from a list of device drivers on my computer 9. Click - Have Disk 10. Browse to your desktop or position where you extracted 6.63, point to "....drv_sw5_v6_63_ad\Disk1\Vista\AMD64\..." Pick any of INF files I picked first 11. You will see 4800 Scanner and USB 2.0 Scanner, I picked first 4800 then USB 2.0 and both works., install the scan wizard, restart the computer
Jun 25, 2012 | Microtek scanmaker 3840
Microtek scanner 3800
Extract to folder on desktop. 1. Plug in your Scanner 2. Go to Control Panel (Windows 7 - 64 and 32 bit) 3. Go to Device Manager 4. Go to Imaging devices (or Other devices) 5. Find what windows have installed Right Click 6. Update Driver Software.. 7. Click - Browse my computer for driver software 8. Click - Let me pick from a list of device drivers on my computer 9. Click - Have Disk 10. Browse to your desktop or position where you extracted 6.63, point to "....drv_sw5_v6_63_ad\Disk1\Vista\AMD64\..." Pick any of INF files I picked first 11. You will see 4800 Scanner and USB 2.0 Scanner, I picked first 4800 then USB 2.0 and both works.
I managed before to do it with simple install but well, it works .. ;)
Apr 27, 2010 | Microtek ScanMaker 3800 Flatbed Scanner
Microtek scanmaker 3800 windows 7 compatible
Apr 02, 2010 | Microtek ScanMaker 3800 Flatbed Scanner
I need driver for microtek scanmaker 3840
you can download it from
http://www.driverskit.com/freedownload/Scanner/Microtek/ScanMaker_3840_3830_3800_ScanWizard_5_5_93/14515.html
Feb 26, 2010 | Microtek scanmaker 3840
Scanmaker 3800 works perfectly with XP. Vista reports : scanner not readt check connections. Would appreciate a so;ution. Device Manager also reports device is working, No conflicts.
This works for Windows 7 I think it works for vista too:
Sep 07, 2009 | Microtek ScanMaker 3800 Flatbed Scanner
Adobe Photoshop Elements 7 Editor "stops working"
Even though this says Elements 6, it still works for 7. The only difference is the TWAIN file is at: C:\Program Files (x86)\Adobe\Photoshop Elements 7.0\Locales\en_US\Plug-Ins\Import-Export
http://kb2.adobe.com/cps/408/kb408846.html
Jul 15, 2009 | Adobe Photoshop 6.0 for PC
My microtek 5900 scanmaker needs new drivers for Vista 64bit OS
hi
I use Vista 64X . And ScanWizard 6.61 ( From Scanmaker 5950, i have 5900) works ok in photoshop.
tks
Apr 21, 2009 | Microtek ScanMaker 4900 Flatbed Scanner
Microtek scanner freezes when scanning large documents.
Try scanning using Scanwizard instead of using directly in Photoshop. If it freezes again, it might be some problem with your system since there's no indication of hardware conflict. Additional info like Microtek scanner model name and current Windows version. Normally, Adobe wont have any problem regardless the scanner model, as long the appropriate driver installed.
Mar 27, 2009 | Microtek ScanMaker 5950 Flatbed Scanner
Can't uninstall microtek 5900 scanner
This is a funny problem. Try & locate SCanwizard 5 files and delete them. Complete the registry deletion as suggested. Run scandisk. Install and uninstall Scanwizard 5.
Mar 07, 2008 | Microtek SCANMAKER 5900 Flatbed Scanner
How do I find instructions on How to download and install ScanWizard 5 software to my computer?
I found it here.. and there .. http://www.opendrivers.com/driver/233289/microtek-scanmaker-series-scanwizard-5-v6.11-windows-98-me-2000-xp-free-download.html http://kmkm.dk/scanner/MicroTek/33289/Microtek-ScanMaker-Series-ScanWizard-5-v6.11-Windows-98-ME-2000-XP.html
Dec 26, 2006 | Microtek ScanMaker V6UPL Flatbed Scanner
Computers & Internet Logo
120 people viewed this question
David Payne
David Payne
