Question about Garden
How do I adjust the float on a Nikki carburetor? Numbers on the carb. are 83666 B220011 and on one end ''34B''.
rwvanlue
  • 486 Answers
SOURCE: I have a Snapper yard cruiser with a 15HP Kohler
Correct that there are no adjustments, but try cleaning the carb jets first, as many times a small amount of debris in the fuel can cause a performance problem. A replacement carb will be close to $200, and NO carbs will be adjustable. A gasket kit is available if you need. Contact your local Briggs dealer to procure the part.
Try cleaning the jets first.
Fuel Starvation - Float Bowl Carburetor
1) remove air filter assembly
*be cautious of tearing the mounting gasket. If it does tear, you HAVE to replace it. It is part of the priming system
2) remove the float bowl fastener. This is the main jet
3) carefully remove the float bowl, the rubber o-ring/gasket will not be able to be used if it is removed, you WILL have to replace it
4) using a spray 'carb cleaner'
spray up thru the center of the carburetor
spray and clean the main jet with cleaner and 'tag' wire
(tag wire is very thin, and can be used to clean the hole in the center of the main jet)
5) clean any debris from inside the bowl or carb body
6) re-install bowl and center bolt, air filter assembly
*if you need gaskets, your Briggs dealer can supply. The kit is cheaper than individual gaskets, and all the parts needed to finish the above repair are in the kit.
Posted on Nov 21, 2009
  • 277 Answers
SOURCE: The screws do not have a flat head? How do I adjust the carb?
if you have plastic caps on the screws you have to pop them off to turn the screws. some screws have a slot and some don't.
for the one's that don't use a pair of needlenose plyers to turn them.
Posted on Jun 23, 2010
  • 6468 Answers
SOURCE: what direction float assembly fits into carb.
it goes with the needle valve sitting into the little step on the float
Posted on Mar 26, 2012
SOURCE: need assembly diagram for nikki Carb 79778
You will find a lot of pictures and diagrams
nikki Carb 79778 Google Search
Posted on Mar 31, 2016
Testimonial: "Thank you; I will visit those sites, but none of them that I found earlier helped."
gregg201
  • 40859 Answers
SOURCE: mikuni carb adjustment for float in milimeters
Hi, Dave for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $10 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
View topic Got some problems with floats height
yamaha fzr adjusting carburator floats
yamaha FZR 600 carburator doing much better
1989 2000 Yamaha FZR600 FZR600R Thundercat Service Manual Repair Manuals...
Posted on May 16, 2016
What is the float adjustment on the carb I know how I just need the measurement on it
Search Results
    Adjusting Carburetor Float Level - YouTube
    ? 2:06
    https://www.youtube.com/watch?v=aiexehn33kg
    Oct 9, 2013 - Uploaded by Mike Nixon
    How to adjust a carburetor's float level. ... Motorcycle Mikuni CV Carburetor Cleaning for Suzuki, Honda, Yamaha Tutorial - Duration: 30:56.
    Motorcycle Carburetors ' Float Height Setting ' Fix.com
    https://www.fix.com/blog/motorcycle-carburetor-float-height-adjustment/
    Oct 17, 2014 - Learn about carburetor parts, how they work, and how to adjust thefloat height to fix your bike from running rich or lean.
Jan 11, 2016 | UM Motorcycles
Tip
Float valve overflowing on a motorcycle
My Yamaha wr250 was leaking fuel out of the overflow badly. I cleaned the seat, changed the valved, adjusted the level. Nothing worked. In the end, it turned out the seat was damaged due to age. Yamaha did not sell a new seat for it, you have to buy a new carburetor. Here is a tip that is easy to do to resolve it provided you have already replaced the float valve, adjusted the float level, and cleaned the carb.
Items needed:
a small tube of lapping (valvegrinding) compound(Available at your local auto store)
1 can carburetor cleaning fluid.
About 5 Q-tips (If your float valve seat hole is bigger than a normal Qtip, you can purchase oversize ones at any drug store)
High speed drill
remove the carburetor, bottom bowl, float, and valve.
Put one Q-tip at a time in the drill
Apply a dab of lapping compound to the end of the tip(about twice the size of a b.b.
Stick it in the float valve seat and letter rip for about 10 seconds. The Q-tip will take on the shape of the float seat and lightly polish the seat smooth again. You might want to do this a couple of times the first time to ensure it takes.
Once you are satisfied that all scars are removed, take a can of carburetor fluid and spray out the seat. Ensure that all the lapping compound has been removed.
Put the carb back on. Try out the bike and see if you can get it to leak. If it does, repeat the process. I had to do it about 5 times to get mine to completely stop.
Final Note. This tip is provided for people that have already replaced the float valve, adjusted the float level, and cleaned the carb. If you cannot purchase another seat for your carburetor, without buying a new carb. this beats that hands down, but I strongly suggest you do the first three steps first. Anything goes wrong, your not out anything anyway.
Ride hard, or stay home.
on Aug 28, 2010 | Motorcycles
1996 750 katana suzuki how to set floats?
- Now days some carburetors are produced which are fixed and no adjustment is provided.The float is made up of whole plastic like material.
Some floats have the copper/metal notch for the adjustment of fuel level.
- Take the carburetor assembly out.
- Remove the fuel bowls.
- Place the carburetor assembly with the floats upward towards yourself.
- Float level gauge and active data list (taken from the workshop manual) is required to carry out the adjustment. But you can simply adjust the float level correctly without any gauge.
- Hold the carburetor assembly at your eye level in such a way that the carburetor No. 1 is in front of you. Behind is No. 2 carburetor, then behind is No. 3 and then the No. 4. Or we can say that the carburetor No. 1 hides the carburetors 2, 3, and 4.
- Examine carefully the floats of all the individual carburetors be parallel to the surface of the carburetor where the float bowl face is seated and tightened.
- Adjust the float level by bending the float notch towards the needle valve (to decrease the float level and to raise the float) or away from the needle valve to increase the float level (to lower the float).
Apr 16, 2015 | 1996 Suzuki GSX 750 F (Katana)
Nikki carburetor Throttle plate sticks
Try installing the throttle plate in the opposite direction, upside down.
Jun 22, 2013 | Briggs & Stratton Garden
Flooded carburetor
remove the needle and seat assy and clean out material that stops the needle from doing the job. Check the condition of the needle and replace if necessary. Ensure seat is tight and the float level is adjusted properly.
Apr 28, 2013 | Troy Bilt 175HP Manual 42" Riding Mower
What direction float assembly fits into carb.
Mar 24, 2012 | Briggs Stratton IC Horizontal OHV Engine ...
Briggs and straton 205412-0187e1 runs on full choke only rebuilt carburetor due to surging now it only runs on full choke
This engine came with 2 different carbs. Walbro and Nikki. The Nikki carb has a very fussy float plate! I fight them often! Usually there is a problem with the odd gasket that lifts the flat plastic plate and causes a very low fuel float level in the carb so the only way it stay running is to have the choke on. The main fuel jet on both carbs is up inside the threaded area of the bowl nut. When the main fuel jet clogs...and it only takes a speck of something you also get the symptom of having to use the choke to keep it running.
http://www.partstree.com/parts/dispdiagimg.php?src=r&ilFN=D%3A%5CEMPARTweb_52%5CCatalog+Data%5CEMP_IMG%5CBRG%5Cimages%5C6359%5C0004.TIF&ilSC=10&ilIV=0&ilBR=0&ilIF=G&ilRE=8&ilSH=0&ilEG=0&ilRO=0&ilSC=24
Main fuel jet is item 117 Nikki or Screwed into item 142 Walbro of the of the above link depending on which carb you have.
The plate I am talking about on the Nikki carb is item 135. The fussy gasket is 137A.
THE threaded area is where all the main fuel supply is drawn from the float bowl. All that must be free of obstructions. Until this is clear and orifices / jets are not obstructed; your going to be running on choke....
Thanks for choosing FixYa,
Kelly
Aug 20, 2011 | Briggs & Stratton Power Products 5,550...
Its a briiggs and stratton 16.5 hp model #313777 0112-E1. I'm gettin gas in my oil and am pretty sure float is sunk and it won't start at the moment. The carb bowl spins clockwise and counterclockwise but...
You need to determine if you have a Nikki or Walbro carb. The Nikki bowl is held on by two phillips head screws and the Walbro bowl is secured by either a single bowl nut or a anti-backfire soleniod (two wires going to it). Your problem is probably the seat in the carburetor. We see very few float problems since most of them are plastic.
If you have a Walbro with the anti-backfire solenoid you will need to get a slim 1/2 open end wrenc the access the "flats" on the solenoid to unscrew it.
The brass seat is replaceable in the Walbro along with the needle. If it's a Nikki, you may need to replace the carburetor.
Hope this helps
Feb 14, 2011 | Garden
I have a Snapper yard cruiser with a 15HP Kohler and Nikki Carb. THis Carb has no way to adjust Idle or High Speed fuel mixture. Since this engine repeatedly stalls with any load on it ecold or hot, I...
Nov 21, 2009 | Garden
Garden Logo
292 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
