Question about Motorola Mobility MOTOKRZR K1 Cellular Phone
K1 KEYBOARD LIGHTS
Hello, I've got a Motorola K1, buy the lights of the keyboard don't turn on when opening the lid. Should I activate specifically ?
    Brigadier General:
  • 7,752 Answers
Replace the flexcable for this to work or mster reset the phone.
Posted on Jun 09, 2008
Can not pair my Vibe VE 1089 bluetooth keyboard with my iPad mini.
The manual for the Vibe iPad Bluetooth Keyboard Folio is completely wrong. To turn on the keyboard, press and hold the button above the word "charge" in the upper right hand of the keyboard. Blue lights beneath the word "power" and beneath the Bluetooth symbol should flash. In order to pair the keyboard, press the same button above "charge" and hold for a shorter time. The light beneath the Bluetooth symbol should flash.
Feb 06, 2013 | Apple Ipad I-pad
My keyboard is locked and 3 lights above the number pad are lit
Examine your keyboard to ensure your "Number Lock" key is not activated.
This activation is indicated by the key being lit up.
If the key is activated, press it to deactivate the lock.
The number lock key will deactivate an entire segment of your keyboard
Start, click Run, and type regedit to open the Windows registry editor.
In the registry, open the below folders.
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
Within the keyboard folder, you should have a string value named "InitialKeyboardIndicators" with a value of 0, 1, or 2. Below is the explanation of each of these values.
0 = Num Lock is turned OFF after the logon.
1 = Disable Num Lock.
2 = Numlock is turned ON after the logon.
hope this helps
Oct 03, 2012 | eMachines Computers & Internet
Clean my laptop keyboard stisky
LOL, you shouldn't eat and drink over your laptop. Count your blessings that you didn't shorten your motherboard out. The best way to clean it is to probably take it apart from the computer.
Remove the power cord, remove the battery, then turn the laptop over and start removing screws from the bottom. Look inside the battery case and there might be screws there, specifically there might be some with the icon of a keyboard. Once you have the screws removed, turn the laptop over and open the lid, then pry off the strip that is over the keyboard just under the lcd screen. Once you remove it you might see more screws that hold the keyboard in place so remove them. Once all screws are removed, lift the keyboard gently because there will be a cable underneath it. Remove the cable that is attached to the keyboard and then you can clean it. I would use something like a toothpick or Q-Tip cotton swab and maybe some rubbing alcohol. You'll have to hold keys down that are around the key you want to clean to get under the key you want to clean that is stuck. Once you've cleaned it press it repeatedly to make sure it does not stick.
Apr 18, 2012 | Computers & Internet
Keyboard mapping
Your numlock is turned on. There is more than one way to turn it off.Find a USB keyboard, and plug it in. Then push the numlock key on the USB keyboard to turn it off.OR, if you don't have access to one of those, hold down the fn key (lower left hand corner of the keyboard) and press the key with numlock or number lock written on or near it.
Mar 01, 2012 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Spilled some red wine in my Toshiba Satellie L640 and now some of the keys stick or don't work so I would like to clean it. 1. How does one do this? 2. Is it a bad idea to do this? I'd rather not...
Hi.
You can try cleaning the keyboard but the keyboard has to be removed first before you attempt to clean it. That hopefully will work, however please be aware that if the wine has gotten between the keyboard membrane then it could cause the keyboard to type other characters not assigned to them or others as well as their own when you reinstall the keyboard.
To clean the keyboard first we have to remove it. Turn the laptop off and close the lid, remove any AC power that's connected. Turn the laptop over and then take out the battery.
In the battery compartment remove the 2 screws holding the keyboard bezel down that are circled in the picture below. (the keyboard bezel is thin piece of plastic that runs the length of the laptop above the keyboard)
When the screws are removed turn the laptop back over, open the lid and carefully lift up the keyboard bezel and remove it from the laptop like in the picture below.
Next you have revmove the three screws securing the keyboard in place like in next picture.
Lift up the top side of the keyboard and rest it on the palm rest/touchpad. Be very careful as the keyboard is still connected to the motherboard like in this picture below.
Now you have to remove the keyboard. In order to remove the keyboard you'll have to unlock the connector and release the cable.
Look at the next picture and lift up the right side of the locking tab so it opens up at a 90 degree angle as shown and carefully pull away the ribbon cable
Lift the keyboard away from the laptop and then get a clean, warm, damp cloth and start to wipe the top of the keyboard. Don't try to remove the keys as you can damage the cradles and also they are very hard to put back on.
Keep on rinsing the cloth with clean warm water and wring it out a bit. Keep on repeating this until the keys release and become springy again.
Once you are happy with keyboard just reinstall the keyboard by reversing the steps above.
When you have re-assembled the laptop turn it on and open a notepad or text document and see if the keyboard is typing all the correct characters for the printed symbol. If some are not working or are typing multiple characterst then you will need to replace the keyboard. Click on the blue link below for an idea.
http://shop.ebay.com/?_from=R40&_trksid=p5197.m570.l1313&_nkw=Toshiba+Satellite+L645+keyboard&_sacat=See-All-Categories&clk_rvr_id=242175125553
Hope this helps, good luck.
Jun 20, 2011 | Toshiba Satellite L645D-S4036 Notebook
Am using Win XP When I turn the pc on with recovery disk inserted the Press Any Key to boot from cd" screen comes up but pressing any key does not get a response then it continues on to the sign in...
OK! Lets troubleshoot this together.
First thing we want to do is verify that your keyboard & mouse and plugged into the correct places and are powered up and able to work.
Turn your computer on and look at your keyboard and tell me if any lights are on to show that it has power and is operational.
Watch the keyboard lights until the computer gets to the login page and tell me if the lights come on and stay on? Or do the lights turn on for a moment and then turn off again?
If you do not see any lights, please clarify if there are NO LIGHTS on your style of keyboard or if there are lights but they are not lighting up.
If your keyboard has lights and they are not lighting up at all, then turn off the computer and unplug the mouse and keyboard and swap them around. Then turn the computer on again and tell me if the lights come on and the mouse and keyboard become operational.
Once we verify this we can continue to the next step of troubleshooting. Please report what you find and I will help you solve this.
Nov 08, 2010 | IBM NetVista PC Desktop
No power to the vaio
perhaps you cracked the board? I know I woulda broke it in half. A lil more info would help
Mar 08, 2008 | Computers & Internet
Motorola key board does not light up when it is flipped open
you have to change the flex cable(ribbon).take it to a technician
Feb 10, 2007 | Motorola Mobility RAZR V3
Motorola Mobility MOTOKRZR K1 Cellular Phone Logo
67 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
