Question about Black & Decker Cst2000 12 - Volt Cordless Grass Hog 12" Trimmer/Edger with Auto Feed Spool Afs
To operate the Black & Decker Trimmer/Edger, there is a two stage trigger. Mine dropped and the top switch is jammed. How do I fix it?
  • 3,247 Answers
I believe the trigger is part of the battery handle assembly and you cannot buy these separately. You will have to replace the whole battery handle which is not available anymore according to black and decker service site.
See
exploded parts view
Item 1 is the battery handle. You must have dropped the lower trigger which is inside the handle. I suppose you can open the screws as you would do to get to the battery and once the handle assembly is opened find out where the microswitch sits (this is the bit where the trigger must be pressing). The top switch must only be a mechanical interlock to block the trigger switch. You may have to look for an old unit in the junkyard and salvage the trigger from it.
Alternatively extend the microswitch and improvise your own trigger from another model. see
http://www.ereplacementparts.com/black-and-decker-cst800-volt-cordless-string-trimmer-parts-c-4167_9518_9519.html
Please post a comment
Posted on Jun 04, 2010
Black & Decker battery operated weed eater/edger not working at all.
you probably need to take the base apart ,mine had a loose wire on the motor on the end of the shaft,about ten phillips head screws ,there is one screw on the gaurd,good luck
May 31, 2012 | Black & Decker Grasshog 12 Inch 18 Volt...
Parts for Black & Decker 14" Grass Hog Xp Trimmer/Edger
Easily, the best place and discounted parts place for this Black and Decker trimmer is eReplacementParts.com
Oct 06, 2010 | Black & Decker 14" Grass Hog Xp...
Black and Decker 2 HP Lawn edger
Ditch that old switch, and buy a better quality switch from HomeDepot or RadioShack that will suit your need. I personally ran into that same problem and brought a 2HP GP switch from HomeDepot. It works way better, than that stock swicth. ( It may require a little modification to the body though.)
Mar 28, 2010 | Black & Decker 14" Grass Hog Xp...
The automatic line feeder dosen't work
You can have mine. It wastes line by feeding automatically way too often. Black & Decker sells Junk!
Dec 14, 2009 | Black & Decker 14" Grass Hog Xp...
I have a Black & Decker electric trimmer. Do I change the guard around or leave it where it is to do trimming? It is on the bottom--should it be on the top and how do I switch it?
You are talking about a string tirmmer, right? Leave the guard where it is; it's there to protect your feet and legs from getting hit with twigs, rocks...anything the trimmer might kick up.
If you are using it as an edger you can keep the guard where it is, just flip the trimmer to do the edging.
Sep 13, 2009 | Black & Decker Leaf Hog 12-AMP Electric...
Describe your Black & Decker
You can order these thru black and decker at blackand decker.com
Sep 12, 2009 | Black & Decker 14" Grass Hog Xp...
How do I use the B & D edger and trimmer
This is for a MCCULLOCH TRIMMAC 210, 21CC (petrol/gas Line Trimmer).
http://safemanuals.com/user-guide-instructions-owner-manual/MCCULLOCH/TRIMMAC%20210-%2021CC-_E
Operation of this and other Line Trimmers are all the same with some exceptions with optional attachments.
Aug 31, 2009 | Black & Decker 14" Grass Hog Xp...
Describe your Black & Decker Grasshog
The push lock on the string feeder Is sticking. Pull it off, clean it out and put it back on.
good luck
Aug 07, 2009 | Black & Decker Grasshog 12 Inch 18 Volt...
Black & Decker Cst2000 12 - Volt Cordless Grass Hog 12" Trimmer/Edger with Auto Feed Spool Afs Logo
62 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
