Question about Electronics - Others
Gears in the winch stripped out on my rockwood popup camper
chillmaster
  • 104 Answers
SOURCE: 2000 coleman mach
It is possible that the compressor has completley failed and is shorted to ground. The way you check is to access the compressor terminals where the wires hook up. After noting the location of each wire, remove the wires from the compressor terminals. Get a piece of sandpaper and shine up a small area on on of the copper pipes coming out of the compressor. Use an ohmmeter and check for continuity between each one of the compressor terminals and the copper pipe. If you have ANY continuity from any terminal(s) to the pipe, the compressor is dead and will require replacement. If not then check all of the wiring to and from the compressor looking for any possible shorts to ground (wire chafing, cuts, etc.) After that, check the run capacitor for the compressor. If the capacitor is failed, it will cause the compressor to draw locked rotor amps. Generally speaking, the quick way to tell if it is a capacitor or a short is to listen to the unit. If it trys to start for a couple of seconds and the pops the fuse, either it is the capacitor or the compressor is seized up. If it trips the very instant that it trys to come on, it is a short.
Posted on Jul 02, 2008
  • 10865 Answers
SOURCE: Need to grease the wheel bearings on my 1995
Hello. This is not too difficult but you do need tools.
You must remove one tire at a time to get to the wheel bearings which slide out. Then you clean off the old grease with a rag and regrease the bearing before you insert it back.
Posted on Aug 29, 2009
Testimonial: "Thank you so much - greatly appreciate it!"
motor1258
  • 6674 Answers
SOURCE: was given a roof top ac for a popup camper need help
Make and model of unit should be on base of roof assy, please reply with that so we can be sure we have right wiring info for you. Although they are pretty common, let's be sure.
Posted on Aug 02, 2010
  • 32 Answers
SOURCE: I need a manual for
Please have a look here: http://www.scribd.com/doc/15641976/Rockwood-Camper-Owners-Manual
Posted on Mar 14, 2011
  • 34 Answers
SOURCE: I need a owners manual
It appears that this particular owner's manual is not available online, unless this one is your model (this Rockwell manual is unmarked).
I am sure that Forest River Accessories would be happy to send you a replacement manual. I would suggest contacting them through the form on their official website: http://www.forestriveraccessories.com/t-contact.aspx
Posted on Aug 01, 2011
Need an owners manual for a 2004 Rockwood Premier pop-up, 2516G
Rockwood.com still carries a good bit of pdf manuals.
Sep 17, 2014 | RVs
Cant figure out how to roll the awning out on my 2009 rockwood 5th wheeler
www.rockwood-campers.com/rv/rockwood-5th-wheel.cfm
See if you can't get a manual for it. Camping world has some basic RV DVD that also show how to do it.
Jun 15, 2014 | Cars & Trucks
Rockwood camper manuel
Forest River appears to be the manufacturer so try them first for information
Jul 19, 2013 | Forest River 2011 Rockwood Ultra Lite...
I bought a 2003 rockwood popup camper. I hooked the water supply direct to the camper and the sink works shower works. I filled the resovor for the porta potti, and hooked the front battery up, but it does...
Hi cssweet12...
Look for a switch (inside cabinet,inside storage area, etc.) to turn the water pressure on from the pressure pump built into the camper..it will fill you toilet bowl with water one you have the system pressurized.
Trace your water line to locate your pump.
Please take time to rate me
Jul 07, 2011 | Home
I would like to get a rockwood 1983 model users manual.
May 05, 2011 | Sport & Outdoor - Others
I need a manual for a rockwood freedom m1610 camper its a 2006
Mar 14, 2011 | Computers & Internet
Electronics - Others Logo
202 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
