Question about Mitsubishi WD-57731 57" Projection HDTV
Closed Captioning Can not find manual. need to know how to put tv on closed caption
    President:
  • Mitsubishi Master
  • 1,779 Answers
It should be listed under the Audio or Features in your main Menu..
Posted on Jun 04, 2010
How do I turn on the closed captioning without remote?
Look for a button said Menu on the tv manual bottons on the bottom of the bazel frame of the tv.Push that button.Go into tv menu look for Captioning Functions.Have Closed Captioning CC1,2,3 or TEXT 1,2,3 turn it all off.Will have no more close captioning or black boxes,will pop up on ur tv screen.
Jan 06, 2011 | Orion STV2763 27" TV
Samsung LN-T4061F
To view the captions, all you have to do is turn on the decoder by following these simple steps:
  1. Access your TV menu screen using your remote or by pressing a button on the face of the TV.
  2. Select the closed captions heading. Several different caption options may appear.
  3. Select the "CC1" option.
  4. Exit the menu.
Closed captions should appear within approximately one minute of adjusting this setting. If they do not, review this portion of your television's operating manual or contact the manufacturer of the television set.
Public Television stations do not transmit Closed captioning
Apr 23, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Sharp Aquos LCD TV 52"
Does your cable company support CC?
Apr 08, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
I need closed caption
Tv air broadcasting shows have to say it,to have closed captioning or have to have a white small sign that said CC to be able to get closed captioning ok.Look for it in ur remote there a button that said CC pushes that button go to CC1,2,3..now u will get closed captioning.Or go into ur tv Menu find closed captioning functions turn it on like CC1,2,3...or Text 1,2,3.. on.Now ur tv are ready to get closed captioning,for the tv air broadcasting shows,that have closed captioning.
Dec 10, 2010 | Broksonic TV
Need to know how to put the tv on close caption
Captioned programs are marked in TV listings by "CC". so press the cc button on the remote and the closed caption option will be applied.press that cc button again to turn off the closed caption option.
1) Check the size and manufactured year of your television. If it was made after 1993 and is larger than 13 inches, it has a closed captioning system built into it. Otherwise, you may need to purchase a separate closed caption system, which are available at a number of online outlets.
  1. 2)Turn on your TV and access the menu for closed captioning. The precise location of the menu varies by television set. Most are accessible by pressing the "Audio" or "Set Up" menu on your remote, then scrolling down to the "CC" or "Closed Captioning" option. Check your owner's manual for precise instructions.
  2. 3)Turn the closed captioning option to the "On" position. It will then run closed captions for every program that broadcasts them. Newer sets may allow you to adjust the size, font and colors of the closed captioning letters to fit your individual tastes.
  3. 4)Tune to a particular program for a few minutes to make sure the closed captions are working. Note that while many broadcasts run closed captioning, not all of them do. If the captions don't appear, check your TV listing to ensure the program includes them.
  4. 5)If you're watching a DVd on your TV, access the DVD's "Set Up" menu. It should have captioned options, which allow you to show captions in English and possibly other languages as well.
  5. thanks.
Nov 11, 2009 | Televison & Video
How to activate "closed captioning" for a Proscan Full HD 1080P
Comcast's remote has nothing to do with closed captioning. It's on your tv remote. First, the tv has to be capable of handling closed captioning, and your's is- and second, the program must have closed captioning provided- current programs do, some older shows do not support closed captioning. Recheck your remote, and if necessary- look at the setup instructions that came with the TV- they should also be posted online at the Proscan support site.
Mar 26, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
How do I get to closed captioning on the TV?
You will need the original remote. The TV/CAP/TEXT button turns it on and off. The CH.1/2 button switches between channel 1 and 2 of the closed captioning.
Dec 08, 2008 | Orion STV2763 27" TV
Closed captioning
The closed captioning decoder circuit in your TV set may not be working, or the closed captioning information from the station may not be present. Start investigating by finding out if there is actualy closed caption from the station that you are tuned in to. If so, then call the tech support for your set to know if there is something that you missed in the set-up for the closed captioning. It may be very simple. If all of this does not work, then the closed captioning decoder in the set may not be working properly and require service.
Jerry G.
Jan 06, 2008 | Sanyo DP42746 42 in. Plasma Television
Closed captioning
I had the same problem. My DVD player was connected to my HD TV via a HDMI cable as was recommended by the DVD owner's manual. I removed the HDMI cable and attached the three video component cables. Bingo, closed caption crossed immediately.
Aug 09, 2007 | Funai MWC24T5 24 in. OLED Television
Mitsubishi WD-57731 57" Projection HDTV Logo
97 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
