Question about Sony FD Trinitron WEGA KV-27FS100 27" TV
How to program channel without remote - Sony FD Trinitron WEGA KV-27FS100 27" TV
    Novelist:
  • 144 Answers
First be aware that if you are using an antenna this television has an analog tuner which is no longer capable of receiving any digital signals which is the only channels being broadcast as of June 2009. If you have a cable or satellite receiver then here is the procedure for auto programing your channels. Make sure your active cable/satellite is plugged into Ant 1 (Antenna 1) on the back of your set.
On the front panel push the menu button until the "Channel" is highlighted. Then push either the plus button or the down button to highlight auto program.
Once that is done push plus or up and the set will automatically tune in all the available stations
Zashiban
Posted on Jun 04, 2010
How do i manually program my channels on older tv without a remote
Nothing you can do without the original remote. One cannot get into the setup pages. Replacement remotes usually don't work on this point either. They are missing this special setup button. In order to watch DVD, VCR, connect them with a SCART cable. When you switch on the player, the TV will detect this and go automaticaly to this input. If connected with RCA plugs, you can choose the input with the program Up/Dwn buttons on the TV set itself, going "lower" than channel 1.
Jan 04, 2014 | Philips Magnavox 20MT133S 20" TV
How to program channels
Cannot be done on this model without the original and correct remote.
Oct 14, 2012 | Sony KV-32S26 32" TV
Programming my tv with a remote
you can program the channel manually, just press the menu button in the tv panel. select preset and then manual fine tuning to tuned every channel you want to watch and then save it.to make a manual fine tuning, press manual then select channel you want to tuned and then press vol. up/down button to search right frequency channel.do this process in every channel you want to tuned. hope this can help.
Sep 15, 2012 | Haier HL24XLE2 LCD TV
Can i program sony flat screen tv with out remote
You might be able to program the channels, but you will need a remote for the time. Any Sony TV remote will work.
Apr 19, 2012 | Sony BRAVIA W-Series KDL-46W4150 46 in....
I have a mitsubishi tv model cs27200 and I dont have a remote. I got a universal remote but it wont bring up the menu. I need to program the channels for cable. I only get local channels without bringing...
You would need to look up how to program that remote to your specific tv. I would look up the owners manual if you dont have it for the remote...and follow the instructions for it. However, you will have to directly use the tv to program it to the cable. The universal remote will only change the channels and volume for you. Use your menu button to bring it up, make sure its set to cable and not antenna, and use your channel + and - to navigate through the menu and vol + to select your option
Nov 20, 2010 | Televison & Video
Need to change tv to channel 3 without remote!
go to menu and see if you have channel selection on go down thaT way. you should be able to program it in.
Feb 16, 2010 | Televison & Video
My daughter brought her tv home from college without the remote. I'm now trying to hook it up to digital cable. It needs to be on channel 3. When I try to manually change the channel to 3 using the...
The easiest will be to make sure that the cable box is on and sending out a signal to Channel 3 and auto-programming the set. Channel 3 is skipped because the last time it was auto-programmed, there was no signal on that channel.
Dan
Jul 10, 2008 | Televison & Video
PROGRAMING MY MAGNAVOX UNIVERSAL REMOTE CONTROL
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Jun 18, 2008 | Philips Magnavox Learning Universal Remote
Programming channels
Not knowing what TV you're talking about it's hard to say. Can we get a model number on the unit?
Dec 07, 2007 | Televison & Video
Sony FD Trinitron WEGA KV-27FS100 27" TV Logo
245 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
