Hi. The audio sound failed on my Asus P4S800D mother board, so I installed an internal sound card, that solved the problem except that there is still no windows start up & shutdown all the usual warning sounds. I have tried everything I can think of, can you help. Regards Joe
    Problem Solver:
  • 14 Answers
Check if you have right driver installed for your card ,and your integrated (realtek)chipset on your mobo ,than if its ok than go to,>control panel>sounds and audio devices>audio ,and check if your sound card is as a default audio device in the sound playback section ,and if this is 5.1 or 7.1 card check if your speakers are plugged into the right connectors and check advanced options to set up what kind of speakers you have plugged
Posted on Apr 09, 2008
I need a sound card
This is the Downloads page for Asus:
http://support.asus.com/download/download.aspx
In the Search box type your motherboard model: P4S800D-X. On the next page click on your model (P4S800D-X), select your operating system and you will be redirected to download page.
If I could be of further assistance, let me know. If thishelps or solves the issue, please rate it and give a testimonialfor my response.
Mar 21, 2011 | ASUS P4S800D-X Motherboard
I have ASUS M2N--68 mother board. its sound driver is not getting indstalled in Win Xp SP3. Urgent help required..
hi shreyash, do you having on board audio card mean go to bios and check weather you have disable , if it was disable mean enable it.
If you using internal or external sound card mean, go to bios Disable your onboard audio card , so only your internal or external sound card will work.
And i will give original Asus mn2 motherboard driver , install it and check it once. copy and paste the link i have given below
http://www.asus.com/product.aspx?P_ID=0pKBwEIE8tqMT4j7
or click here
After page get loaded scroll down, click download in tab and select your OS and download your Drivers.
Good luck
Jan 11, 2011 | ASUS M2N-MX Motherboard
My audio doesnt work cant install audiodriver for windows7
The only drivers ASUS has available for this board are for XP and earlier. If they don't work with Windows 7, you have two options. One is to install a PCI audio card in an open slot. Any new board should work with W7. The other is to use a USB sound adapter so you don't have to open the computer case. Either of these methods will get your sound back.
Nov 19, 2010 | ASUS K8V-MX Motherboard
I want to download the sound driver of asus p4s800d
Hi, go to the website “touslesdrivers.com”. Click the link “mes drivers” on your left / click “lancer detection” at the bottom” . Now the website will propose you to allow installation of a pluggin (active x) to scan your laptop for proposing drivers. Pls allow.
Then choose the ones which are missing & follow hyper link to download the exact latest driver for your hardware. Well, that’s it. Ur problem will be surely solved.
Feb 10, 2010 | ASUS I-A16C Sound Card
Windows service pack3 no work audio onboard ccard
sp3 is no in world it is pirated..so don't use it
Sep 10, 2009 | ASUS P4S800D-X Motherboard
Asus P5GC-mx mother board with realtek sound issue
Hi Brother
I had that problem and it was difficult to resolve, which made me frustrated those Mother Board
But I after several tests and found the following tricks
1 - after the preparation of the system (Windows)
Put the CD in CD or DVD the system and careful, but do not process definition Automatic
Will go to Device Manager then drive up date LAN and Vega will work no problems
But the sound card will search in CD or DVD and not work then go to auto ran and install realtek audio and setup it and Follow the instructions then Restart the system
Congratulations
Has been the definition of sound
Mar 31, 2009 | ASUS P5GC-MX/1333 - Motherboard - micro...
Not able to install sound device
Hi Ms.Geetha
First what you need to know what brand of sound card is ..,
This you will be able to know from Control panel -> sounds and Audio devices option
once u know the Type, U can down load it from net or
the very easiest is to take any Mother Board CD from some of ur collegues and run the
setup.exe from [sound] Folder in the CD
I think the soundcard present on ur mother board is not Avance AC'97, Xp comes with default drivers of Avance AC'97 Drivers.
this will solve ur problem...,
Dec 13, 2008 | Computers & Internet
Mother board sound card
You need to download audio driver either from the manufacturers web site or from download.com.
regards
Jan 30, 2008 | ASUS P4S800D-X Motherboard
Audio driver installation failed from mother board cd
The most common solution was this: open device manager click "system devices" disable "microsoft UAA bus driver for high definition audio" uninstall "UAA bus driver" make rescan devices (Note: Not all had this step. You may want to skip it.) D.W. install realtek driver the realtek driver includes the UAA driver too.Hope this helps.
Aug 29, 2007 | E-Mu 0404 Sound Card
ASUS P4S800D sound card problem
Check to see if your audio header is hooked up correctly on your motherboard if your using the front panel audio, if your not using the front panel audio then make sure the audio header has the two jumpers on them!! Check your mother board manual for proper procedure to hook up! If that still doesn't help then it could be a faulty sound device! You can fix this buy purchasing a new sound card! hope this helps! regards, babb
May 05, 2007 | ASUS P4S800D-X Motherboard
Computers & Internet Logo
78 people viewed this question
David Payne
David Payne
