Question about Audiovox Audio Players & Recorders
Audiovox 144D2420 satellite receiver won't reactivate.
I have an Audiovox 144D2420 satellite receiver. Sirius technical support has told me that this unit, once deactivated has issues being reactivated with their service and that they can't help me. They say that the only solution is to purchase a new unit. Is there anything that can be done to reinitialize the receiver or is this a dead unit?
SOURCE: Clarion SIRIUS Radio Receiver - Not Receiving All Subscribed Channels
My DX445 does the same thing. Here's my method for fixing it, it should work for any similar Clarion receiver:
1. If possible, make sure the radio is turned off when disconnecting the battery. If the radio turns itself on when the vehicle is restarted (for example after jump starting or battery disconnect for a few seconds only), turn the radio off.
2. Disconnect the battery by removing the negative battery cable from the battery. Leave it disconnected.
NOTE: Car batteries can be dangerous things. If you're unsure how to do this safely, get an experiences mechanic to help you.
3. Reset the radio. On my radio this is done by removing the faceplated, and pressing a tiny button for 30 seconds. Your radio may be different.
4. After waiting at least 20 minutes, reconnect the battery.
5. My radio displayes 'System Check -- Press Power'. After pressing the power button, the display reverts to the clock.
6. Turn on the radio. It should work fine on the broadcast bands.
7. Select 'Sirius'. The radio should display 'Updating'. Don't touch anything until the radio finishes its update phase. When it's done, it should tune to Sirius channel 1 and play as normal.
8. This should restore normal tuning. reset your presets and preferences.
What seems to happen is that the radio gets stuck in a 'Category Select' condition, but not all the categories will load, and manual tuning will not allow, say, Radio Classics to play when the radio is stuck in Pop mode.
On occasion (maybe 1 time out of 10), the radio hangs while doing the 'updating' in Sirius mode. If this happens, just shut off the radio and start over. I've never had to do the brute force reset more than twice since I stumbled on this method.
Posted on Dec 09, 2008
SOURCE: Sirius Problem
The sirius unit does not have any channels in the unit.
You need to refresh the radio (XM allows you to do it online, I dont know about sirius) and leave it powered on for about an hour for it to update the channel list.
Posted on Mar 13, 2009
efs_perpends
  • 1996 Answers
SOURCE: have deactivated mouse on acer5520G how do i reactivate it
Support Solutions from Acer:
Product
Notebook Acer Aspire 5520 G
Issue
Mouse / Touchpad not working
Solution
If the mouse/touchpad is not working, ensure that it is turned on. Press and hold the blue "Fn" key located in the lower left hand corner of the keyboard. and tap the "F7" key one time.
Fn-F7
A message should flash across the bottom center of the screen stating "touchpad enabled".
If this does not address the issue, the notebook may need service.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on May 17, 2009
  • 89 Answers
SOURCE: Can't reactivate Sirius service for '05 Nissan Frontier
you need to call sirius radio.I had the same problem with my XM.i called and they fixed the problem.
Posted on Oct 03, 2009
SOURCE: Sirius Satellite Stiletto 2
My Stiletto got the same problem at around the same time. I have been reading many stiletto owners problems and see many of the same problems erupting at around the same time-mid to late February. I just spoke with a Sirius Representative who said the Stiletto 2 has been discontinued. Seems like a conspiracy to me.
Posted on Mar 27, 2010
Can i get a car kit for my audiovox sir-pnp3 144-2453 receiver?
There was a car kit and a boom box that were made for the sir-pnp3. I do have both. It allows one to move the radio from the car to a home.
Search for the sir ck3 adapter. It is available on amazon. http://www.amazon.com/Audiovox-SIR-CK3-SIR-PNP3-Satellite-Receiver/dp/B0006FZYJ6
Jan 29, 2013 | Audiovox SIR-PNP3 SIRIUS Radio Receiver
My radio is showing aquiring signal.how can i get it fixed
I heard these have a common problem with the antenna line breaking within the radio. I had it happen and replaced the radio. It's a shame since I'm sure I could have fixed it. I think it happens if the radio ends up hanging from the antenna lead. Any electronic tech or engineer should be able to check continuity from the antenna jack and find/fix it.
Jan 22, 2013 | Audiovox SIR-PNP3 SIRIUS Radio Receiver
I have audiovox Sirius radio from 2004 and still works fine. I am having a problem finding a frequency setting while driving from phila. Pa. To Newark de. Can you help me with a frequency setting that...
I use a wired fm modulator that the fm antenna passes through. When the sirius radio is on it blocks the regular fm signal preventing local signals from interferring. Do a search for wired fm modulator and you should find one. Mine actually fit inside the dash on my pickup.
Jan 06, 2013 | Audiovox SIR-PNP3 SIRIUS Radio Receiver
I need a car power plug
Looks like people are selling them on ebay for about $7.
http://www.ebay.com/itm/Car-Power-Adapter-for-Sirius-Audiovox-SIR-PNP3-SIRCK3-SIR-CK3-Satellite-Radio-/200849636300
Mar 05, 2011 | Audiovox SIR-PNP3 SIRIUS Radio Receiver
My Sirius radio, factory installed in a 2008 VW R32, won't activate, even after a "soft boot". Sirius mentioned having the dealer do a "hard boot". What is that?
I hope this post finds everyone well who is having difficulties with Sirius Radio's trouble shooting advice to reactivate service. I tried to reactivated my service and had experienced all the problems that everyone has had on these forums. This is what works. It took me a lot of phone calls and I want to get the word out to everyone (regardless of Make, Model or Year of Vehicle)
First, a soft reboot does nothing and there is no such things as 'reseting' the electric system in your car. Second, there is no such thing as a 'hard' reboot to your sirius radio. All a soft reboot will get you is cold legs when you have to hold your car door open for 30 seconds in the middle of winter. All a hard reboot will do is cost you a lot of hard earned money at the dealership. Best case scenario is that your dealer replaces your entire radio and charges you $500+.
WHAT YOU NEED TO DO: Call Sirius Customer Service and ask for Technical Support. Explain to them you are having difficulty obtaining an activation signal. The technical support technician did the following (and it was the most intelligent thing I heard from Sirius)
1. Go turn on your Sirius Radio and tune to Channel 184.
2. The technician put a "dummy" ESN in on my account, refreshed and then re-entered my original ESN back into my account and then re-sent the activation signal. **NOTE** Make sure you write down your original ESN number before you ask to have them do step #2....there is no way for them to recover your original ESN if they put in the 'dummy' ESN and refresh.
3. Within 10 seconds of putting doing step #2, my Sirius Radio said, "Updating Channels" and worked great.
Takeaway from My Experience: I believe that once you let your Sirius Radio Service relapse and/or do not renew your subscription, a signal/frequency is sent to your radio to block service or reactivate your service. The problem must be an internal issue on Sirius where the only fix to stop this signal is to completely clear (or zero) out your original ESN, enter a dummy ESN, refresh and then re-enter your original ESN and then send the activation signal.
I hope this helps everyone.
Sep 02, 2010 | Sirius Satellite Radio Receiver
Reactivated Sirius Radio today. Display shows P1, p2.p3, etc with flashing channel 184. Unit will not work. Tried soft reset with Sirius, still no luck. Sirius said to go to the dealer and have them do a...
Disconnect negative wire from vehicle battery; wait minimum of 1-hour, then reconnect.
Turn on satellite radio, call Sirius tech support to have them resend activation signal. Stay on line with them since it may take them 2 - 3 tries.
Aug 27, 2010 | Eclipse SIR-ECL1 SIRIUS Radio Receiver
If I buy a
Yes, many of the channels are now the same and you will pay a little bit more for an additional package called "Best of XM" to add some XM-specific channels to your Sirius radio.
Dec 31, 2009 | Audiovox SIR-PNP3 SIRIUS Radio Receiver
How do i unlock or modify audiovox sirpnp2
call up Sirius and see if they have any manuals for that model to see if they can unlock it for ya or just have Sirius erase the reciever and start fresh by them reseting Hope this helps
Cheers
Johnthetr870
May 15, 2009 | Audiovox SIRPNP2 SIRIUS Radio Receiver
Antenna not detected
Call Audiovox support. After waiting an hour I was told the unit (pnp2) was faulty and I was to call customer service to arrange a replacement. Mine is on the way to NY.
Jan 15, 2007 | Audiovox SIRPNP2 SIRIUS Radio Receiver
394 people viewed this question
Top Audiovox Audio Players & Recorders Experts
John
John
Chinmay Joshi
Chinmay Joshi
Computer Links
Are you an Audiovox Audio Player and Recorder Expert? Answer questions, earn points and help others
