Question about KitchenAid KGYS850LT Gas Dryer
Does not stay hot
Kichen aid gas dryer model kgys850le0 heats up then gets cold does not reheat and i can smell gas from outside vent
    President:
  • 1,430 Answers
The problem is the dryer coils have failed. They tend to fail as they heat up. They are inexpensive and easy to replace. Try these videos http://appliancehelponline.com/gdryertroublevideo.html
http://appliancehelponline.com/gdryertroubleshootge.html
Posted on Jun 04, 2010
Dryer wont heat for more than 10 minutes when cold
did you clean the vent line?THAT COULD MAKE IT RUN HOT THE AIR CAN'T BLOW OUTSIDE,BUT WITH THE DRYER HAVING HEAT WHEN IT STARTS AND THEN AFTER LIKE 10 MINUTES NO HEAT IT SOUNDS LIKE YOU HAVE BAD GAS COILS,WHEN THE COILS ARE STARTING TO FAIL THEY WILL WORK FOR LIKE THE FIRST 10 TO 20 MINUTES AND WHEN THEY HEAT UP NO GAS,WHEN THE COOL THEY WILL WORK AGAIN,I WOULD CHANGE THE COILS AND CLEAN OUT THE DRYER AND VENT LINE,THIS SHOULD BE DONE ONCE A YEAR SO YOU DON'T HAVE A FIRE AND YOUR CLOTHES WILL DRY ON TIME,EVERYONE THINKS SOMETHING IS WRONG WITH THE DRYER AND ALL THAT HAPPENS IS THE VENT LINE AND THE DUCT WHERE THE LINT FILTER SLIDES INTO FILLS WITH LINT AND THE AIR CAN'T BLOW AROUND GOOD ANYMORE,ALSO WITH A SHOP VAC VAC UP THE LINT WHERE THE BURNER AND MOTOR IS AND THEN SET THE VAC UP TO BLOW AND BLOW THE MOTOR AND GAS BURNER OUT,DO THIS AND YOU'LL HARDLY HAVE ANY PROBLEMS WITH THE DRYER
Sep 30, 2017 | Whirlpool Cabrio WGD6400SW 7.0 Cu. Ft. Gas...
Gas Dryer wont stay lit.
It may be your dryer vent piping. If the piping from the dryer to the outside of the house is clogged with lint (which happens periodically) the dryer cannot get rid of the heat generated by the gas burner. When the temperature reaches a certain level the high limit switch opens and shuts the burner off. The switch closes again after the dryer cools down. Check the lint filter and all the vent piping for any obstructions and clean out thoroughly. This should solve your problem. Hope this helps.
Jan 14, 2014 | Whirlpool Cabrio WGD6400SW 7.0 Cu. Ft. Gas...
I have a Sears Kenmore Gas Dryer Model Number 110 72612101 Serial Number MM2606191 that appears to be over-heating. All my clothes come out smelling like burnt rubber and/or dry cleaning compound. If I put...
I suspect the vent is the issue with your dryer. It sounds like the air is not moving to the outside well and is keeping the interior too hot. The filter housing may also be plugged. Make sure the vent is clear all the way to the outside. Be certain that the hose is not kinked or crushed behind the dryer and is as short as possible. You may change the operating thermostat as well.
Kelly
Mar 21, 2011 | Kenmore Dryers
AFTER DISCONECTING THE GAS FOR TILE WORK IT NEVER WOULD REHEAT
So long as its heating a little, try removing the venting, and see if there an improvement. a clogged vent will greatly reduce if not stop all heat . dont forget to check where venting exits the home outside also becomes clogged.
Now restart it - it should work.
Jul 21, 2010 | Whirlpool LER4634J Electric Dryer
My kenmore series 80 model # 110.74852400, takes forever to dry. the flame comes on, but doesn't seem to stay on for long. please help. thank you
my kenmore dryer ignites runs for awhile then wont reheat. let it sit for a few minutes and it will heat again for awhile
Apr 20, 2010 | Kenmore 72802 Gas Dryer
My Whirpool Duet Gas Dryer is no longer heating up.
This is probally the coils. They tend to fail as the dryer heats. There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru the troubleshooting. It's a different model but the testing of the parts will be the same.
Mar 24, 2010 | Whirlpool LGR5636L Gas Dryer
Gas dryer get hot but than goes cold
This sounds like a problem with your fan motor. The dryer is getting too hot and the gas is shutting off until it cools down. That fan keeps the dryer cool by moving the heat to the clothes in the drum.
You can easily check this by feeling for air flow in front of the exhaust vent outside. No air movement = fan problem = heat shut off in 10 minutes. Good luck
Dec 05, 2009 | Dryers
Natural gas dryer running too hot
I suspect you have a blocked air vent. A blocked vent will make you dryer run hot. Most vents get blocked by lint near their exit to the outside. There's usually a screen at this location to prevent small animals from crawling into your house. Often this screen gets clogged with lint. Most vents are designed to allow removal and cleaning of this screen from the outside.
Jun 07, 2009 | Maytag Neptune MDG5500AW Gas Dryer
FRIDGIDAIRE GAS DRYER MODEL # GLGR642AS2 IS NOT DRYING CLOTHES BUT GAS IS IGNITING. THANK YOU. DON
Hi Don,
So let me get this straight, you are getting heat from the gas burner and the drum rotates but your clothes remain wet? You can check a few basic things to identify where the problem lies.. First off, have you checked the lint trap and cleaned it? Secondly, have you checked your vent system ( meaning : are you sure it is not clogged anywhere in the duct or at the end where it exits outside? If that's OK.. when your system is drying clothes.. do you get hot air flow at the end of that duct? If not, your blower may not be working ..You need to move that hot air out of the tub for the system to dry. Heat, Motion to move clothes, air flow from the blower and an unimpeded path via the vent duct to outside.. Hope one of these things to check gets you going. Regards...
Sep 03, 2008 | Dryers
Maytag dryer does not maintain heat and clothes smell
Check coils on burner assembly. Often when a dryer heats initially and then stops heating a coils has gone bad.
Nov 09, 2007 | Maytag MDG7600AW Gas Dryer
KitchenAid KGYS850LT Gas Dryer Logo
Top KitchenAid Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Oloyede Monsuru
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
