Question about HTC Verizon XV6700 Cellular Phone
Can not align screen
I can't align the screen to get the phone to even open up to windows. Maybe you guy's can help me with this issue. I sure hope so thanks Dan PS is there a way to bypass this problem?
  • 821 Answers
Hello,definitely it's due to a jammed application,so all you need to do is just to get it working back by using the reset mode.this will automatically reinstall your phone.
In addition you can as well check if the battery is not bad,it could also be as a result of a bad battery that it's not going beyond that stage.if powered does it stay on after it does not get to the windows.
wish you good luck,
take care.
Posted on Jun 04, 2010
1999 Chevy S-10 and an alignment problem..
you have to look for: Free moving adjuster pins on the calipers, be sure none of the pins are seized up. This will throw off your steering capabilities. You should also look at your rears and make sure they are also free moving. perhaps if one of your rears is sticking it may cause drag to the front steering also causing it to turn off a bit. You would also need to check your tie rod adjusting nuts to see if they are still tightly secured or have loosened. Now I will take the chance to say, maybe the tire needs to be balanced. I know you had an alignment done but that is different from a wheel balance. maybe they forgot to balance one wheel ? I hope this information helps.
Dec 30, 2015 | Vehicle Parts & Accessories
Tracking, new tyres fitted and worn on inside in 6 weeks, had alignment done but they will not go straight, any ideas please
If they did the alignment correctly, you should be perfect. Now, on the other hand...any shop doing an alignment on a vehicle should be required to check all the suspension parts for damage and wear. Even a slightly loose ball joint or bushing needs to be replaced before such an alignment is done. Shops are notorious for shabby work nowadays and it is so hard to find a decent mechanic to do a job correctly. If your not happy with the job, bring it back and ask why it is doing this to the tires. I know it has been a while since you had the alignment down, but that is besides the point. Maybe the alignment guy was off that day and some other guy pretended he was an alignment guy, lol. When I get mine done, I love to sit in the window and watch them so called professionals do the work. They should give you a paper readout of the settings found and change to. But, most of all they should always check for worn parts that are almost always present. After and alignment, the mechanic better take it for a test drive. If that vehicle does not go straight down the road with hands off the wheel, it was not done correctly, period.
Aug 08, 2013 | 2005 Mitsubishi Outlander
My htc tytn II screen suddenly became unresponsive to the stylus or even my finger. I can only open my screen lock through the keyboard which worked but takes longer time to use. many commands can only...
Hi. You need to replace the digitizer. This happens to many touch screen phones from all brands.
you can purchase from:
http://cgi.ebay.com/US-NEW-HTC-TyTN-II-TILT-8925-TOUCH-SCREEN-PAD-DIGITIZER-/350435156469?pt=LH_DefaultDomain_0&hash=item51979021f5
After purchasing you can have it replaced in a cell repair shop or similar shop. Or you can chose to replace it yourself.
Thank you for using fixya.
May 24, 2011 | HTC TyTN II Smartphone
Touch screen is not responding on my x1
ur TOUCH PANEL IS FAULTY kindly go for warranty claim or tell me i can give u link for the out of warranty replacements
Mar 16, 2009 | Sony Ericsson XPERIA X1 Smartphone
Keypad not working
i have a lf cookie kp 500 and it is all touch screen and none of the keys work i can receive calls but cannot make calls or use any of the features
Oct 13, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
RESET phone solution.. pls help..
hi,
   u just do one thing..restart ur phone again..& when it asks u to set up ur windows..than tap on the black spot firmly ...u just need to tap on than spot only..nthing else after that leave..it will start processing..& ur phone will be on.
Thanks
Gizmo1
Oct 22, 2007 | O2 Xda Trion Smartphone
Screen alignment
tap the screen at target for few moment untill align screen does not go.it takes several attemp.after align screen disappear time & date setting option appear.set it.after this window will reinstalling.it takes few minutes.after this phone will be started.
Aug 23, 2007 | i-mate JAM Pocket PC
I-mate jam screen problem
Hi this problem can occure once in a whaile. you should do the "Align Screen" process. tap "start", then "settings", then on the Screen icon and in the generasl tab get to the Align Screen you will have to hit the target on the screen until the screen will be align again. hope this helped. Dagan
Jul 30, 2007 | i-mate JAM Pocket PC
K jam screen align does not work after hundred or so attempts
Well, folks i had the same problem with the damn i-mate K-JAM model but i have figured out its solution. Well screen alignment options will always come on ever reset whether it is hard or normal and further more it would be nail biting for most of us because it doesn't work at all. It seems like some sort of a bug either in Windows Pock PC edition or HTC manufacturing bug. Whatever u call it only we would be the victim of it. Here is the solution.
When the alignment screen comes Just Tag the {+} << in the exact centre it will then move to the top let corner of the screen again tag it from the middle and it will then jump to the lower left corner now don't tag it from the middle instead tag the lower left corner of the screen. It will then move to lower right corner of the screen now tag it again in the middle and finally it will fly to the top right corner now again instead of clicking in the middle just hit the top most right corner of the screen and now u r done. Screen is finally aligned whoops!
Sometimes even when the screen is aligned the touch pad malfunctions if this is the case with you u need to update the firmware like i did just search through Google the i-mate k-jam windows Pocket edition update.
Thanks
Jun 25, 2007 | i-mate K-jam Smartphone
HTC Verizon XV6700 Cellular Phone Logo
74 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
