Question about Whirlpool GHW9400SU Front Load Stacked Washer / Dryer
We have a GHW9400PW front loading washer, purchased May 2006. Water is dripping from the fill line spot, within the rubber gasket by the front door. It fills the washer until it over flows onto the floor. It doesn't happen all the time but if we do not use the washer for a few days it over flows. Do a need a repairman or can I fix something myself?
  • 7 Answers
SOURCE: Front load washer fills up with water
Jamesbestor,
The water fill selenoid had junk in it holding the valve open or the seat in the valve is damaged.
Turn off the power and water, remove two screws on the back of the machine and remove the lid.
On the back left top corner are the water fill selenoids. Remove these and disassemble by undoing the 6 or 8 screws ( depending upon model ) holding the unit together. Clean and reassemble, it should take care of the problem. If not, replace the selenoid.
Posted on Feb 15, 2009
GasPipe
  • 11 Answers
SOURCE: fills on its own door open or closed
I would bet the water inlet valve is weeping. It may not seal shut every time. It could have a piece of rest stuck in it also. It's cheap and easy to replace. The part # AP3128776.
Posted on Feb 23, 2009
  • 20 Answers
SOURCE: Whirlpool LXR9245EQ2 top loading washer tub won't fill
try taking the knob off and see if the nut is tight on the timer,it might if came loose
Posted on Jun 20, 2009
bozcro
  • 867 Answers
SOURCE: whirlpool duet washer fills with water when not running
one of the control valves (hot or cold) is not closing the water supply, most likely leaking so the electronics are good. one of the valves needs replacing, but if you dont want to spend the money just shut the water supply off at the water supply taps.
Posted on Jul 17, 2009
marka19
  • 1430 Answers
SOURCE: Whirlpool Duet:drum fills up with water when machine is off.
Your problem is the water inlet valve has failed part # AP3128776 This is fairly common especially if you have hard water or well water.
Just enter that # at www.appliancehelponline.com
Posted on Mar 24, 2010
When I start the washer, it fills just fine with no problems but once it starts the cycle, it gushes water from the bottom of the door
Check the bottom of the plastic inner door. If there is a crack or a gouge, have it replaced. Also check the rubber door boot for holes above the water line
May 09, 2014 | Maytag Neptune MAH5500B Front Load Washer
GE front load washer model #WBVH6240FWW leaks when filling at top and drips down side of front ballancer
Check the big rubber seal around the door for any holes or tears. Had the same problem, my husband had a screw in his pocket that torn a hole in the gasket.
Sep 27, 2009 | GE WBVH6240F Front Load Washer
Our Maytag Neptune Front load Model MAH6700AW seems to alway have a wet or damp spot underneath or in front of the door. Where should I start looking for the leak?
the door has a series of small holes in the front bottom lip of the door gasket these are for drainage if they get clogged the door will drip water clean them and, remember to use HE soap
May 11, 2009 | Maytag Neptune MAH6700A Front Load Washer
I have a kenmore front load washer model number 4174104200 and water is leaking onto floor.
Can you describe WHERE the leak may be coming from? If the leak is coming from the front area of the washer, it may be the door bellow (rubber gasket), or the drain pump. You will need to open the door and pull back the folds in the rubber gasket and inspect for cracks or tears in the rubber. To inspect the pump, you need to remove the bottom panel under the door and look for any leaks inside the unit. The drain pump is in the front, directly under the wash tub. Also check all hose connections. If the washer is leaking from the rear area, check the fill hoses and drain hoses for cracks or holes. Make sure all hose connections are tight. The fill valve is another possiblity too. You will need to remove the top panel to view the valve to ensure it is not dripping. Please verify your symptoms and let me know. I hope this helps.
May 01, 2009 | Washing Machines
Black mold growing on gray rubber boot inside door.
Leave washer door slightly ajar after use to air out any moisture. Should prevent any future mold.
Apr 10, 2009 | Frigidaire Affinity ATF7000E Front Load...
Kenmore Elite HE3t door leaking (Model 44936)??
If the unit leaks during use with a constant drip from the 6 o'clock location between the seal and the glass on the door the solution is to change tha door seal. it is quite difficult to do I would recommend you call a local service company.
Dec 16, 2008 | Kenmore Elite 45986 Front Load Washer
Washer tub slowly fills with water
Is your problem a SLOW FILL problem, or a problem with WATER DRIPPING FROM THE RUBBER DOOR SEAL - or BOTH? If you have a slow fill problem, this is generally caused by a bad fill valve, which can be attributed to hard water deposits or well water mineral deposits. Sometimes the fill valve can be removed, cleaned and reinstalled, but most of the time a new fill valve is required. If you are experiencing water leaking from the rubber door seal (bellow), it may be time to replace it. Sometimes the seal can develop a wrinkle or crease where it meets the glass, which can cause leaks. Water dripping from the door when you open after washing a load is normal. Water dripping during a load is NOT. The bellow may also have started to rip or tear inside the door which may not be noticeable until you pull the folds of the bellow back and look underneath it. I hope this helps.
Jan 17, 2007 | Kenmore Elite 45986 Front Load Washer
Whirlpool GHW9400SU Front Load Stacked Washer / Dryer Logo
54 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
