Question about Estate TAWB600JQ Top Load Washer
How do i level my washing machine tawb600jq - Estate TAWB600JQ Top Load Washer
    President:
  • 1,430 Answers
CLOTHES ARE STILL DAMP AFTER SPIN CYCLE
dry them for a little longer if they are not dry
Dec 06, 2012 | Estate TAWB600JQ Top Load Washer
Hello my washing machine has stooped... it will keep washing but will not rinse or spin out.. please help
sounds like you have aproblem with the lid switch , that will keep yoor unit from spinning after the wash cycle then it goes to a rinse cycle as long as the unit cant spin it then can't rinse.
Mar 10, 2011 | Estate TAWB600JQ Top Load Washer
Water continues to drip after washer has stopped?
The fill valve has dirt in it and it will not shut off completely... kind of the opposite of these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Sep 25, 2010 | Estate TAWB600JQ Top Load Washer
How do u remove the safety which is under the lid of the washer
the washer lid is held in place with spring clips, use a putty knife to pry the lid up gently and expose the switch
Jul 29, 2010 | Estate TAWB600JQ Top Load Washer
Does not progress through cycles. Washer will fill and agitates, but must be moved manually to each succeeding cycle (drain, rinse, spin, etc.) Wherever it is set in the cycle, it remains there.
It sounds like a defective timer. The timer is behind the dial that you use to set the cycles. You will need to remove the screws that hold the top control panel down. Once these screws are removed the panel will flip up. Then you will be able to get to the timer. Verify that there are no loose connectors causing the problem. Also blow out the timer with compressed air to clear out any dust that might be causing a malfunction. Otherwise you may need to replace the timer.
Dec 19, 2009 | Estate TAWB600JQ Top Load Washer
Wash Machine Drainage problem
i am a recently retired appliance engineer of 20 years, slowing down the flow of water from any electrical washing appliances can be dangerous and will cause extensive damage to the appliance in question, at the very least it will stop half way through the cycle every time the only way to remedy this is to rectify the drain, or at least sort out another waste water outlet sorry
Sep 21, 2007 | Estate TAWB600JQ Top Load Washer
How to open door
how did you get the clothes into the washing machine in the first place?
Sep 16, 2007 | Estate TAWB600JQ Top Load Washer
My washing machine will not fill on cold water but works on the other cycles
Check first the filters on the inlet water line (both sides). Then, if problem still exist - check that the inlet water valve works(it is an electromagnet valve, located at the pipe's entrance to the machine)). If it doesn't work,test that it get power. In case it get power and doesn't work, it should be replaced. Good luck!
Sep 15, 2007 | Estate TAWB600JQ Top Load Washer
Washer Won't Agitate
I would make sure that the washer is properly leveled, and ensure that all sensors that check if the door is closed are working properly.
Sep 07, 2007 | Estate TAWB600JQ Top Load Washer
Estate TAWB600JQ Top Load Washer Logo
Top Estate Washing Machines Experts
Dan Webster
Dan Webster
dweatherby
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
