Question about Bosch HBL8450UC Electric Single Oven
Bosch 800 Series 30" Wall Oven & Cooktop, Layout of back of Oven?
Help - need details on layout for electric hookup for BOSCH HBL8450UC 30" Wall Oven and for gas hookup for BOSCH NGM8054UC 30" Cooktop (cooktop will sit on counter above oven). Appliances haven't arrived yet and need detail on placement of electric hookup on back of oven and for size/placement of cutout on top/back of oven allowing gas line to feed up into cooktop. Bosch installation pictures leave a bit to be desired & we're running gas & electric now. thanks, bk
dutchman05
  • 487 Answers
SOURCE: timer clock on bosch double oven
Please follow this link and download the instructions.
Manual
Please rate me as FIXYA
Posted on Apr 29, 2008
barkencoa
  • 3463 Answers
SOURCE: bosch convection double oven,ovens won't heat,only broilers work
If it is fan assisted then check the fan element, it is located behind a panel at the rear of the oven compartment.
Plz rate my\solution.
Thanks.
Posted on Dec 17, 2008
barkencoa
  • 3463 Answers
SOURCE: bosch hba34b520
Yes, it is o/k to have a single oven connected to a 13 amp power supply supplied with a 2.5mm cable.
A lot of single ovens already come with a 13 amp plug fitted, so you can plug it straight into a 13 amp socket.
If there is no covenient socket nearby, then you can wire the 2.5mm cable srtaight into the oven terminal block.
I must stress that this only applys to a single oven and not a double one.
Plz rate my solution.
Thanks.
Posted on Jan 14, 2009
SOURCE: Bosch Oven Door Problem - doesn't close at top
On our oven (Bosch Evolution 700 Series HGS7152UC), the problem was getting worse and worse. I found it is was worsening simply because the hinges had started to come loose. I removed the door as suggested above, and although there are no adjustment screws on this model I tightened the now-loose hinge mounting screws. For each hinge there are three screws altogether: two (phillips heads) on the bottom of the door and one (torx head) on the inside wall of the door. After tightening those screws it is a lot better, only leaks as much heat as it did when it was new which is tolerable. Still a bad design.
Posted on Dec 09, 2009
barkencoa
  • 3463 Answers
SOURCE: Our Bosch electric oven is 5 years old. We
Either you have not refitted the door back correctly, or the door hinge springs are weak, a common problem.
This being the case, then the only solution is to replace door hinges.
Posted on Feb 11, 2010
A F04 Err is flashing on my Bosch double oven. Please can you tell me what this means?
The only F04 error on a Bosch oven is with the Bosch 5000 Series wall oven. On this model, the problem is with the door latch. Unplug (or turn off at the circuit breaker) the oven. Turn it back on after a few seconds. When the power comes on, the oven should do a self-test of the lock mechanism. If the error persists, you'll need to do some diagnostics to determine if the lock is faulty. The problem could also be with the wiring or the control board didn't register the correct signal from the lock sensor.
Please add a comment with the model number of the wall oven for more assistance and any possible parts lists. You may want to call for service if you aren't comfortable doing this work. You probably need to get the oven out of the wall cavity for some of the diagnostics.
I hope this helps.
Feb 24, 2017 | Bosch Ovens
OVEN WONT HEAT CORRECT TEMP
Should be procedures to test/adjust temp in owner's manual
Oct 16, 2013 | Bosch HBL8450UC Electric Single Oven
I just had a Frigidaire electric Single Wall Oven (FGEW2745) installed under a Bosch gas cooktop. The cabinet maker didn't allow enough room for the oven so my contractor had to lower it. However, as...
Any handle you replace on the oven will certainly void its warranty, especially if you have to drill the door to fit it. Generally the oven handle is designed for the oven, and as such most manufacturers dont make different door handles for them. Most likely you will need to get a different oven altogether, or void your warranty and find a suitable handle and attach it to the oven door yourself by some means.
Hope that helps.
Feb 24, 2011 | Frigidaire FGEW2745KB FGEW2745KW Electric...
I am trying to find the KW rating of the HBL3550UC so that I can rough in the electric. They couldn't even tell me that info at the store. Thank you.
hi could not find kw rating but found it needs 30- 40 amp supply. it will tell you the kw on therating plate located around the door area.
Jul 23, 2010 | Bosch 300 Series HBL3550UC 30" Double...
Praveen i want to purchase bendix of opel astra
where are you?
what year is your astra?
wich engine does it have?
the brandof your starter?
Mar 31, 2009 | Bosch 300 Series HBL3550UC 30" Double...
Bosch HBL8450UC Electric Single Oven Logo
180 people viewed this question
Top Bosch Ovens Experts
ashburton
reliableservice
Are you a Bosch Oven Expert? Answer questions, earn points and help others
