Question about Canon imageRUNNER C3220 Color Copier
Can I put a CPR-21 toner cartridge in the Canon imageRunner C3220 instead of the GPR-11?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 127 Answers
Do not attempt to use another toner... use only the GPR-11
Posted on Jun 05, 2010
E000020 01b0
Yellow Drum Cartridge or bad toner. If your using generic toner it can cause this code. If generic toner is used drum cartridge unit will have to be replaced and Canon Genuine toner used instead. Yellow seems to be more suseptable to this than the other colors for some reason.
Nov 25, 2011 | Canon imageRUNNER C3200 Copier
How do you replace the toner refill cartridge? we can't get it to release from the carrier portion.
Leave the drum/ toner cartridge in the copier. Open the front right access door and rotate the blue hook ring clockwise. Gently pull out the cartridge and reverse the process. You may want to put newspaper below the area so that if toner is spilled it can easily be cleaned up. There are also picture instructions on the toner cartridge box. This uses GPR-10 toner only.
Jun 15, 2011 | Canon imageRUNNER 1310 Copier
To replace the Canon GPR-11 black drum, do you just take the old one out and put the new one in? That is what we did and there is a band of black toner printing on the top of each sheet.
The new toner cartridge snap's into the top of the Hopper > just look on the box on how to install it. Once you have pulled the tab till you can read "STOP" push the slid back in and release the toner cartridge and you are done...... Put the empty cartridge into the "G" file
Oct 01, 2010 | Canon NP 6035 Copier
Toner will not insert into copier. Image runner 2018. Generic GPR-18 cartridge used.
Stay away from the generic toner. They are nothing but trouble and can make a bad problem even worst. If there is generic toner loaded in the machine, the toner hopper unit should be vacuumed out by a tech. But if this is your first attempt to install generic toner and you have been using original canon toner you should be able to install it as long as nothing is broken.
May 20, 2010 | Canon imageRUNNER 2018 Copier
Toner cartridge wont come out.
Try removing the corresponding drum unit below it first. If you remove the waste toner bottle you will then be able to pull down the plastic handle and drop the small door that covers the four drum units. Try and remove only the same colour as the problem toner first. Now try and push the toner back in and then remove it. After, slide the drum unit back in. Good luck
Jul 23, 2009 | Canon imageRUNNER C3200 Copier
My canon c3220 is giving me a "ghosting" effect on b&w copies any ideas?
Did you change ink cartridge? If yes you need to go thru a print set-up cycle to reset the printer
Jun 12, 2009 | Canon imageRUNNER C3220 Color Copier
Canon imagerunner c2880 (GPR-23)- Waste receptacle
i dont know about any counter to reset,the message is displayed when there is waste toner in the sensor window of the waste toner bottle.That window can also be cleaned.
Jun 09, 2009 | Canon imageRUNNER iR C2880 Color Copier
Best place to buy toner
ebay 1st i can alsosuggest southeastern wholesale when they have some ask for darryl 931-268-6601
Dec 31, 2008 | Canon imageRUNNER C3200 Copier
Canon Image Runner C3200 GPR 11 Drum Units
error code eo-20 on canon pc740 without replacing drum/toner unit
Nov 05, 2007 | Office Equipment & Supplies
Canon imageRUNNER C3220 Color Copier Logo
82 people viewed this question
old marine
old marine
