Question about Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM W/1HP PUMP
Whenever I bump the filter I get blow back of DE. I've checked the tube covers and don't any cracks in them. I'm wondering how to check to find which one of the possible tubes might be bad or do I need to replace all of them?
2 Suggested Answers
jharwell668
  • 640 Answers
SOURCE: I replaced the diaphragm gasket
There are several things to check when correcting DE leaks in these pool filters. If you have already replaced the diaphragm gasket and tightened the screws, check for an opening or tear in one or more Flex-Tubes. Replace them one or all as necessary. Make sure that you have the proper amount of DE and that you don't have holes in your grids.
Posted on Mar 17, 2011
What would cause earth to blow into pool after pumping down pressure
DE filters are a picky item. if you have too much media, it will blow off. make sure to follow the instructions when doing a bump or replacement of media.
Jul 07, 2014 | Jacuzzi Avalanche 60 Sq. Ft. D.E. Filter...
My Amana french door/bottom freezer is leaking water. Did the procedure with hot water the drain in back of the freezer, although it seemed clear of ice. That didn't help. The leaking stops when I...
Two possibilities:
1. A cracked plastic tube. These will leak whenever there's a call for water - either the chilled water dispenser, or re-filling the icemaker tray (two seperate tubes). Pay particular attention to anywhere the tubes are clamped to the chassis; anywhere they're routed near or under the refrigeration unit; and near the solenoid valve - especially if there's a tight loop in the tube there.
2. A bad (leaking) connection where one of the tubes exits the water valve. Again, these will leak whenever the valve is activated.
Those plastic tubes don't last forever. I've replaced many of them for the same symptoms. They're known to simply deteriorate with age.
Manuf's make good money selling replacement tubing kits.
Aug 15, 2011 | Amana AFB2534DE Bottom Freezer French Door...
2008 Honda CRF 250 R blows oil out of the breather hose
Hi, Devenbandazi and the usual suspects are:
1. Oil tank/system overfilled.
2. Faulty breather valve.
3. Engine breather hose bent, pinched, kinked etc.
4. Air filter has too much "pre-oil".
5. Crankshaft seal failure allowing transmission fluid to migrate.
6. Blow by drain tube cracked/split or filled to capacity.
For more information about your question and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Losing oil from crankcase breather hose 06 crf 250r
HELP NEEDED CRF250 Putting Lots of Oil Out Valve Cover Breather
Honda 2004 CRF250R Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
HONDA CRF250R 2006 Owner Manual
Jul 18, 2011 | 2008 Honda CRF 250 R
I replaced the diaphragm gasket and when I bump the filter some DE still shoots out into the pool. all the tube sheet hex screws are all tight. Paul
Oct 03, 2010 | Hayward EC-40 DE Pool Filter with pump
I have Hayward EC-45 filter leaking DE into pool via return line every start up. Checked all troubleshooting causes (tube tears, bad gasket, cracked tube sheets, loose bolts, o-rings, etc. All looks OK to...
If D.E. is returning to the pool, it's usually because you have a tear in the grids or the backwash valve is not working properly and returning D.E. back to the pool.
Aug 24, 2010 | Hayward 1.5 Hp Northstar High Performance...
Hi I am having trouble getting consistent power. I have taken it apart and cleaned it thouroughly only to find that the problem still remains. Any suggestions?
Try bumping the filter. You might have D.E. coated with normal accumulation of pool dirt, algae, etc. Your pool filters pump strainer or skimmer baskets could be clogged. Make sure there are no obstructions in your impeller. Finally, check the cover gasket, hand knobs, hose, clamps, etc. Replace or tighten as necessary.
Jul 03, 2010 | Hayward EC-40 DE Pool Filter with pump
Blowing oil out the dipstick
Check the pipe from the top of the engine to the intake it may be clogged up. If the engine is low in power or it is burning oil then it could de broken or worn out pistons, cylinder's or piston ring's.
Sep 09, 2009 | 1992 Chevrolet C1500
We have an an Infinity DE filter. It's blowing DE back into the pool. We've replaced the filters.
Most likely the "fingers" inside the filter housing are worn out and causing the DE to blow out the return line to the pool.
Jun 12, 2009 | Hayward EC-40 DE Pool Filter with pump
Open Questions:
See all Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM W/1HP Questions
Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM W/1HP PUMP Logo
78 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
