Question about Brother Office Equipment & Supplies
I have new 1012 daisy wheel and new ink supply and it doesn't print. I have no manual.
  • Brother Master
  • 3,594 Answers
Go to brother.com, click on support you will find a manual there.
DickyO
Posted on Jun 05, 2010
How do i change the font on my GX-6750 Typewriter
The Font or letter size is depends to your printing fonts or daisy wheel. Buy a different Font size of daisy wheel or printing wheel.
Jul 07, 2014 | Brother GX-6750 Typewriter
How do i set a new daisy wheel for the ML 100
1. Open the top cover.
2. Pull the lever towards you to release the daisy wheel lock.
3. Remove the cassette daisy wheel by pulling it out of the machine by the protruding "ear' on the top right.
4. Insert the desired cassette daisy wheel into the slot and press down gently.
5. Slide the lever back to its' original position to lock the cassette daisy wheel in place. Make sure to press the lever firmly.
6. Close the top cover.
7. Press [CODE]+[RESET] to move the carrier to the previous position.
(make sure the daisy wheel cassette is not inserted backwards. The "ear" should always be on the upper right.
improper insertion of the daisy wheel may cause malfunction and incorrect printing.
It is not necessary to remove the cassette ribbon when replacing the daisy wheel.
Please check the shape of your daisy wheel cassette before replacing the daisy wheel. The daisy wheel cassette type "B" cannot be used with this machine.)
Dec 22, 2010 | Brother ML-100 Typewriter
My typewriter does not print. I do not have a manual or instructions for this typewriter. Is there a code I will need to insert in order for it to print...delayed or otherwise? Thank you!
Check that the daisy wheel is properly installed and if the ribbon has been used up. Try pressing and holding CODE and then press Reset. (This needs to be done after the daisy wheel, correction tape or ribbon is replaced.)
The daisy wheel has a protruding ear that should be on the top right. To remove, open the cover, pull the lever towards you and lift the wheel by that ear. To reinsert, insert the wheel in the slot and press down gently. Then slide the lever forward to lock the wheel in place. Then close the cover and reset the carrier (CODE+Reset). Make sure that the ear is to the top right when you reinstall the daisy wheel.
The amount of ribbon left can be determined by looking through the viewing hole on the right hand side of the cassette when the cover is open.
The manual is available here: http://www.brother-usa.com/manuals/default.aspx?PGID=10&R3ModelID=ML100 as a PDF.
I hope this helps.
Nov 09, 2010 | Brother ML-100 Typewriter
I purchased a Prestige 1012 daisy wheel so that I could print with a 12 pitch. However, when hitting the appropriate keys (Alt 4 or Alt 5) to change the pitch, there is no change. It remains in a 10...
I could be wrong but i believe it is code 4or 5 to change the pitch.
Go to brother.com, click on support, poke around in there and you will find a manual.
DickyO
Oct 21, 2010 | Brother GX-6750 Typewriter
I have a LaserJet 1012 and it has always worked. It is now printing blank pages despite having a new ink catridge. How should I fix this? Thanks.
Just pick the strip from the cartridge, SEE the cartridge booklet or refer to user manual about replacing cartridge
May 07, 2010 | HP LaserJet 1012 Printer
How do I replace the daisy wheel on my Brother GX6750 ?
There's a small handle a little towards the right of the print head. Pull it towards you to free the Daisy wheel, lift the daisy wheel up and drop in a new one. Always power off before you do this or you have to reset .
Dec 12, 2009 | Brother GX-6750 Typewriter
Change font size on my bother ML 100
A typewritter is not like a computer. It is a mechanical device, that works by pressing an embossed letter in the daisy wheel through a inked tape into the paper.
The only way you can change either the font type or the font size is by buying and replacing the daisy wheel by another one with different font type/size letters.
To get to know more about your typewritter and accessories that might still be available to it, download Brother ML-100 Typewriter User's Manual
Click on "Go to View/Download Page" and in the new page click the "View/Download" button.
Look for page 16 (last page) of the manual for a list of cassette daisy wheels.
Aug 22, 2009 | Brother ML-100 Typewriter
My typewriter is a Smith Corona Word Smith. I cannot get the daisy wheel to align
From the manual of Sr Smith Corona WordSmith 100:
Changing The Print Wheel
1) Move the print carrier to the center of the platen using the SPACE or BS
key.
2) You will see a lever on the right side of the carrier. Pull this lever toward you and
lift out the daisy wheel.
3) Place the daisy wheel into the slot with the characters facing the platen.
4) Push the lever back into position.
5) Press the CODE + = (SETTING) key.
Here is the link for the manual:
http://www.google.pt/url?q=http://www.smithcorona.com/pdf/WS100Man.pdf&ei=26RzSrjIFZmOjAer4KS9Bw&sa=X&oi=spellmeleon_result&resnum=1&ct=result&usg=AFQjCNHgeBMa_etCetMv9Vq-BDehtTGprQ
Jul 31, 2009 | Brother GX-6750 Typewriter
I have a Brother WP-2000 word processor and when I changed the Daisy Wheel the letter typed is not printed and another letter or symbol is printed. How do I align the daisy wheel so this does not happen
Turn the typewriter off, remove the daisy wheel.
USUALLY there is a small rectangular slot in the daisy wheel that points up.
Insert wheel and turn on.
Make sure your spacing is NOT set to PROPORTIOAL SPACING
Nov 20, 2008 | Brother Office Equipment & Supplies
Not typing the correct letters
The ML-300 needs to be reset each time the Daisy Wheel is removed or replaced or if the Keyboard Switch changes position. According to Brother, if this is not done the typewriter will print incorrect characters. Try these steps: 1) Open the Top Cover. There is a lever directly behind the Daisy Wheel. Pull the lever back towards you. Remove the Daisy Wheel by pulling it up and out. 2) Verify that it is the Standard Daisy Wheel that came with your machine and not a Symbol or International Daisey Wheel. Write down the Pitch (10, 12, or dual pitch 1012) printed on the wheel. 3) Reinstall the Daisy Wheel (the plastic top ear goes to your right.) Push the lever (step 1) forward. 4) Press the ALT key plus the PITCH key and the number 1 key simultaneously. Verify the Pitch setting is the same as is printed on the Daisy Wheel. 5) Press the CODE key plus the RESET key and the letter Q key simultaneously. This will reset the typewriter mechanism and align (or time, in technical terms) the carriage mechanism. Check if the typewriter prints correctly now. If still incorrect, perform these additional steps. 6) Verify the three position Keyboard Switch (inside the top cover, on the right side, at the bottom) is in the I=Standard position. The other positions are: II=International and III=Symbol. 7) If the Keyboard Switch is in the correct position, slide it to position III and then back to I. (This will clean the switch contacts in case they are dirty and not making good electrical contact. 8) Press the CODE key plus the RESET key and the letter Q key combination again to reset the typewriter mechanism. Check if the typewriter prints correctly now. If still incorrect, the only other things I can think of is that: 1) an incorrect Daisy Wheel is installed that does not work in the ML-300. Brother sell a "B type" Daisy Wheel with two plastic ridges/raised slots below the center of the Daisy Wheel (viewed with the raised top tab on your left.) The B type are incompatible with your machine. 2) the typewriter has failed and needs repair.
Sep 28, 2007 | Brother ML-300 Typewriter
19 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
