Question about Dell 926 All-In-One InkJet Printer
Hello I am Marvin, I have a Dell 926 all-in-one printer that will not feed the paper threw to print, you can hear and see movement but the paper won't feed, how do I solve this problem??
    President:
  • 1,561 Answers
If the paper on your printer will not feed through, the cause is a broken drive belt. If the wheels that push the paper are not turning it is either drive belt or the motor on the printer is bad.
You will need to replace the drive belt on your printer because when the drive belt on are weak, it will not be able to feed paper through, just as in your case and atimes the problem could also the motor that drives the belt.
But i advice you change the printer drive belt first and see, i believe it should fix the problem.
Take care.
Posted on Jun 04, 2010
  • Sulaimon Jimoh Olayemi Jun 04, 2010
    Before you replace the belt, ensure you have carried out the following to be sure they are not the cause of the problem, but if you have, then you can go ahead to replace the drive belt on your printer.
    Turn off the printer.
    Remove any paper trays. Inspect them for wrinkled or damaged paper.
    Open any other doors that give access to the printer's paper path and to
    the toner or ink cartridge.
    If necessary, remove the toner or ink cartridge. Place it in a bag or
    away from light to avoid damaging it.
    If you find a piece of jammed paper, remove it by holding it with both
    hands and pulling firmly. The goal is to keep the paper from
    tearing. If several pieces are jammed together, try pulling out the
    middle piece first to loosen the jam.
    Replace the toner or ink cartridge and paper trays, close any doors you
    opened and turn the printer back on.
    If these is been carried out to ensure that it is not paper jam, then you can go ahead to replace the drive belt.
    Take care.
My dell aio 926 wont print it makes the sounds but paper is blank i uninstalled and reinstalled and cleaned cartridges with cloth says there ink for 43 papges help me
Maybe it has not ink for the color you want to print or the printhead is clogged. In this last, you should change the printhead.
Thanks.
Dec 11, 2010 | Dell 926 All-In-One InkJet Printer
I keep getting paper jams. Even if I put one sheet of paper in at a time, the paper keeps jamming and won't print.
Hi
I live in the mid west - during our significantly humid days my 926 wouldn't pull in any paper. I tried a lot of home grown techniques but none worked. I finally raised the air temp in my office which tended to dry out the paper and that worked. Of course your problem could be a broken gear or a worn out feed tire - also something stuck in the printer.
Aug 12, 2010 | Dell 926 All-In-One InkJet Printer
Paper jam on Dell Photo 926
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 18, 2010 | Dell 926 All-In-One InkJet Printer
Dell photo aio Printer says Error:2200 Will only feed paper half
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Hope that helps!
Aug 26, 2009 | Dell 926 All-In-One InkJet Printer
Printing too small on my Dell 926
Please check the paper settings of the printer. for example If the paper selected is A3 and the printing matter is on A4 then this problem may occur.
I hope this will solve your issue.
Good Luck.
If my solution proves useful please accept it.
Regards
Arjun
Mar 30, 2009 | Dell 926 All-In-One InkJet Printer
Dell Photo 926 printer no longer feeds paper correctly
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 04, 2009 | Dell 926 All-In-One InkJet Printer
printer wont print anything. computer says no print documents pending even though ive clicked print a few times and on different programs and internet pages as well. printer will print only if i copy something press print test page from the printer itself but it doesnt print anything from the computer
Oct 15, 2008 | Dell 926 All-In-One InkJet Printer
Dell printing problems
Try fanning the paper and see if that works.
Jun 30, 2008 | Dell 926 All-In-One InkJet Printer
Dell 926 All-In-One InkJet Printer Logo
56 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
