Question about Dishwashers
Soap dispenser doesn't always open and the tub doesn't always pump out the last rinse.
  • 30 Answers
Check the supply voltage going to soap dispenser and inlet solenoid valve, if no voltage replaced the timer
Posted on Jun 04, 2010
The last few times I filled the rinse dispenser and ran the dishwasher I notice the arrow showing the rinse aid is almost empty. Impossible. What is going on with this?
THE ANSWER IS YES. FROM YOUR DESCRIPTION IT SOUNDS LIKE THE DISPENSER PUMP OR RESERVOIR IS LEAKING. YOU NEED TO REPLACE THE WHOLE SOAP DISPENSER. ALTHOUGH DISH WASHERS NEED THE HELP OF RINSE AID IT IS ONLY DISPENSED A DROP OR TWO AT A TIME DURING THE FINAL RINSE CYCLE PART OF THE WASH. HOPE THIS HELPS AND THANK YOU FOR READING THIS.
Oct 07, 2014 | KitchenAid Dishwashers
Soap doesn't always dispense on any cycle. oap drw
Hello Bruce - The drawer requires two valves to open to dispenser: the bleach valve and the wash valve. If one fails, it will not fill the softener compartment. If there isn't any cold water supplied to the unit, it will not rinse the softener or the detergent. Possibly the washer may have a faulty water valve or an incorrect water supply to the unit. Also, if the softener dispenser cap is not installed properly, that can cause it to not rinse out as well. Because it could be a number of any one of several underlying causes, I personally recommend contacting a professional to properly diagnose and repair the unit.
May 29, 2013 | Frigidaire GLTF1670A Front Load Washer
Rinse agent not dispensing
Hi I will try and explain how it works , if you look at the cover for the rinse it has small slots on it as the water splashes around inside it and this makes the agent come out if this cover is blocked or dirty it won't let any come out .. I always tell ever one to use less soap then the box says to use and always use a premium type soap , not the wal-mart brand , think about t if you have to clean your dishes after they are washed then why have a dishwasher ? I always say that is what teenagers are for
Dec 10, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Ecomax 400 400-17 Glasswasher is not drying glasses completely. Streaks left on glasses
It sounds like the rinse aid has run out or is not dispensing. streaks on glassware is the usual symptom of this. Check and refil the dispenser. On the final rinse, open the door and you should see soap foam , which will let you know the rinse aid has ejected, or alternatively, if you havent had to fill the dispenser in a long time, I would say its not ejecting. these are not usually repairable and you will have to purchase a new rinse aid dispenser from the manufacturer. I always suggest usung " finish" rinse aid, its the best.
Jul 31, 2011 | Hobart Dishwashers
Soap dispenser door not always opening, rinse aid not being consumed
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Mar 31, 2011 | Maytag Dishwashers
I just bought a washer and dryer that were used and the previous owner was a smoker. Now all my clothes smell like smoke. Any advice the get the smell out of the machine?
Hello, W/D here.
For a single odor, I would recommend a neutralizing sequence. Use one box of baking soda. Fill the soap dispenser as you would with powdered soap, and pour the remainder into the wash tub. Fill the fabric softener and bleach dispenser cups with an odor remover such as Odor-Cide or Febreze. Add 1/2 the normal amount of detergent for a normal load directly into the tub. Run the washer on the hottest, longest cycle available, with the longest, hottest rinse cycle available (usually this is the sanitary cycle). When the cycle has finished, run another sanitary cycle with 2 cups of bleach in the tub, fill the soap dispenser, bleach dispenser and the softener dispenser with bleach also.
After this cycle runs, run another, normal cycle with white vinegar in the tub and dispensers. This can be a normal cycle.
After all of these cycles, one last regular cycle with about 1/2 the normal amount of detergent in the dispenser should get all of the smell neutralized in the machine.
Best regards, Woobie ‰ Dog Please take a momentto rate our solutions so that we may improve in helping others. Thanks.
Feb 24, 2011 | Washing Machines
Water coming out of soap drawer
Some washing machines, can flood water out of the soap dispenser when a hose gets blocked (usually with un dissolved soap powder) .Water flooding out of the front of a washing machine's soap dispenser can also be an indication of overfilling or a partial pump blockage if it does it when spinning.
Black gunge in the top of the soap dispenser can cause water to spray towards the front and leak. Take out the soap dispenser drawer and look at the roof of the soap dispenser. If it's covered in black gunge, blocking some of the water holes, it could be causing problems. In extreme cases you have to replace the dispenser.
Feb 05, 2010 | Hotpoint First Edition WMA22 Front Load...
Soap-not residue-still on clothes
Wow that's a strange one.
Are you pouring the soap into the tub onto the clothes or using a soap dispenser? If using a dispenser, it may be malfunctioning, try pouring soap directly into the tub under the waterfall while it is filling.
When the machine is agitating are the clothes on top being drawn under the water? Usually this occurs as a rolling motion from the edge of the tub towards the agitator. If the top layer of clothes have an air bubble trapped in them they may not be submerging into the water. Any soap on top may not be dissolved.
Finally, if you are pouring soap into the tub, make sure you are not spilling any onto the inside of the lid or in the softener dispenser. It could get trapped in the lip around the edge of the lid and be spilling onto the clothes when you open the lid at the end of the cycle.
Do you have the same problem if you use powder soap?
Nov 12, 2009 | Washing Machines
Removal of washing machine soap dispenser - Indesit
hi sue,
i've check the web and i found thatt you just have to pull the soap dispenser towards you. if some clips are rising when you pull it, gently press it down and continue pulling it.
tnx 4 using fixya,
drcool
Sep 13, 2008 | Washing Machines
Bosch dishwasher SHU66C02UC - Rinse Agent issue
Does soap draw open at right time?
Same solenoid opens soap draw as injects rinse aid.
Turn up hardness counter ?
Any blockages in dispenser unit its-self?
OTHERWISE CALL IN THE PROFFESIONALS !
Apr 09, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
47 people viewed this question
Top Dishwashers Experts
