Archos 10 netbook running xp home won't run on battery
Hi my Archos 10 netbook running xp home - fully updated just purchased as new won't operate on the battery which permenantly indicates full charge.The original OEM battery is almost new - I have tried the obvious power option settings etc. and tried the static discharge procedure to no avail.
Please can anyone help ?
    Sergeant:
  • 356 Answers
Go to the manufacturer's support website and download the latest BIOS update for your motherboard. Follow the instructions in flashing the BIOS carefully.
Posted on Jun 07, 2010
Can not run netbook off battery even though battery shows fully charged' When charger is removed netboook will not turn on
Make sure the battery is fully inserted and clicks in to the netbook body. Your battery may also be showing that it's charged but is actually dead. Try a new battery and see if it solves your problem.
Jul 04, 2013 | Wolvol Mini NOTEBOOK COMPUTER Laptop...
Battery is fully charged, but netbook won't turn on unless plugged in.
I would say that you definitely need to purchase a new netbook battery. If it's only turning on when plugged in, then the battery itself doesn't have any more charge cycles.
Oct 10, 2011 | HP Mini 1033CL Netbook
I purchase s10-3 netbook. i had problem with its battery which only runs 2 hours if it is fully charged. please assist!
How long have you been using the netbook? If it's brand new, then your battery life is too short. First of all, remember the following for ensuring that your battery performance is optimal:
1. A new battery pack must be fully charged before it is put into use.
2. A new battery pack needs to be fully charged and discharged a few times before it starts performing at full capacity.
3. Batteries discharge when left unused. If you intend to store the netbook for a while, make sure that the battery is fully charged before you do so.
4. Fully drain and fully recharge your batteries every few months.
If your netbook is new, then try one or more of the following and see how your battery performance gets affected: 1. Turn down the LCD brightness of your portable device.
2. Use built-in power management on your portable device.
3. Turn off LCD or other unnecessary accessories when not in use.
4. Set screen saver blank to 1 to 2 minutes of your netbook.
5.. Add more RAM if you can, as this will reduce the usage of the hard drive which exhausts the power quicker.
Hope this helps.
May 24, 2011 | Lenovo Computers & Internet
Hi regarding my Archos 10 netbook with Intel Atom N270 1.6 GHz processor, Intel 950 GMA integrated 945GSE chipset and 1GB DDR2 apparently it is possible to upgrade to 2GB with this chipset in most cases....
Actually that limit was only in XP Starter Edition. Since you have Home you're in the clear. BTW it's better to add 2 new identical sticks, this way you won't get instability with the dual channel memory active and 2 different memory sticks.
May 30, 2010 | Computers & Internet
I can't connect to the internet on my ACER Aspire One aod150-1920 netbook running XP. I am connected to my home network (wifi, excellent strength) but IE, Skype, Mcafee won't connect. Laptop and desktop...
Most Acers use an IPN2220 Wireless card. If yours does and your router is using WPA or WPA2 (TKIP or AES) security then you'll need to update the driver by searching for it manually using the Custom button (Hardware) in Windows update (instead of Express). This driver is not part of XP service pack 2 or 3. In my experience if you don't update to the newest common form of home wireless security (WPA2 AES) then the older formats seem to become unreliable
Nov 02, 2009 | Acer Aspire One AOD150-1920 Netbook
SYSTEM WON'T STARTUP
The problem is in Operating System, better you newly install OS in your system. then your problem must be solved.
another suggestion ir your system is under warrenty, better you inform your dealer.
Thanks
Aug 13, 2009 | ASUS Eee PC 701 Notebook
Charging
look i have the same problem it taks so mush time to charge
it and you can onliy play with it like in a 1:00 hour only what it worng
Jan 11, 2008 | Archos 605 WiFi Digital Media Player
Not Recognised
plug in the charger while connected to your pc so the power will not run down
Jan 11, 2007 | Archos Gmini 402 Digital Media Player
Computers & Internet Logo
247 people viewed this question
David Payne
David Payne
