Question about Acer Computers & Internet
Abnormal temperature of batterry - Acer Computers & Internet
  • 3,083 Answers
The fan vents on the computer are clogging up. Spray it out with some compressed air from Walmart (cheapest I've found). If that doesn't help, buy a small $7 fan from Walmart to cool off the "hotspot". Chances are that dust is clogging air flow so that the microprocessor fan can't keep up with the heat.
Posted on Jun 04, 2010
How do I get the fault codes up on a Panasonic split air conditioning system CUE24FKR
14.2.2 To Make a Diagnosis1 Timer LED starts to blink and the unit automatically stops the operation.
2 Press the CHECK button on the remote control continuously for 5 seconds.
3 "- -" will be displayed on the remote control display.
Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
4 Press the TIMER ? or ? button on the remote control. The code "H00" (no abnormality) will be displayed
and signal will be transmit to the main unit.
5 Each press of the button (? or ?) will increase error code
number and transmit error code signal to the main unit.
6 When the latest abnormality code on the main unit and
code transmitted from the remote control are matched,
Power LED will light up for 30 seconds and a "beep" sound
(continuously for 4 seconds) will be heard. If no codes are
matched, Power LED will light up for 0.5 seconds and no
sound will be heard.
7 The breakdown diagnosis mode will be canceled unless
pressing the CHECK button continuously for 5 seconds or
operating the unit for 30 seconds.
8 The LED will be off if the unit is turned off or the RESET
button on the main unit is pressed.
Diagnosis
display Abnormality / Protection control Abnormality
Judgement Emergency operation Primary location to verify H00 No abnormality detected - Normal operation H11 Indoor / Outdoor abnormal communica
tion > 1 min after starting
operation Indoor fan operation
only • Internal / external cable connections
• Indoor / Outdoor PCB H14 Indoor intake air temperature sensor
abnormality Continue for 5 sec. - • Intake air temperature sensor (detec
tive or disconnected) H15 Outdoor compressor temperature sensor
abnormality Continue for 5 sec. - • Compressor temperature sensor
(detective or disconnected) H16 Outdoor Current Transformer open cir
cuit - - • Outdoor PCB
• IPM (Power transistor) module H19 Indoor fan motor mechanism locked 7 times occurance
continuously - • Indoor PCB
• Fan motor H23 Indoor heat exchanger temperature sen
sor abnormality Continue for 5 sec. O
(Cooling only) • Heat exchanger temperature sensor
(detective or disconnected) H24 Indoor heat exchanger temperature sen
sor 2 abnormality Continue for 5 sec. - • Heat exchanger temperature sensor
(detective or disconnected) H27 Outdoor intake air temperature sensor
abnormality Continue for 5 sec. O • Outdoor temperature sensor (detec
tive or disconnected) H28 Outdoor heat exchanger temperature
sensor abnormality Continue for 5 sec. O • Outdoor heat exchanger temperature
sensor (detective or disconnected) H30 Outdoor discharge air temperature sen
sor abnormality Continue for 5 sec. - • Outdoor temperature sensor (detec
tive or disconnected) H33 Indoor / Outdoor wrong connection - - • Indoor / Outdoor supply voltage H38 Indoor / Outdoor mismatch (brand code) H50 Ventilation motor abnormality 7 times occurance
• Ventilation motor H51 Nozzle lock abnormality 2 times occurance
continuously - • Nozzle H52 Limit switch abnormality - - • Indoor PCB H97 Outdoor fan motor mechanism locked 2 times occurance
within 30 minutes - • Indoor PCB
• Fan motor H98 Indoor high pressure protection - - • Air filter dirty
• Air circulation short circuit H99 Indoor heat exchanger anti-freezing pro
tection - - • Insufficient refrigerant
• Air filter dirty F11 Cooling / Heating cycle changeover
abnormality 4 times occurance
within 30 minutes - • 4-way valve
• V-coil F90 PFC control 4 times occurance
within 10 minutes - • Voltage at PFC F91 Refrigerantion cycle abnormality 2 times occurance
within 20 minutes - • No refrigerant
(3-way valve is closed) F93 Compressor rotation failure 4 times occurance
within 20 minutes - • Compressor F95 Cool high pressure protection 4 times occurance
within 20 minutes - • Outdoor refrigerant circuit F96 IPM (power transistor) overheating pro
within 30 minutes - • Excess refrigerant
• Improper heat radiation
• IPM (Power transistor) F97 Outdoor compressor overheating protec
within 10 minutes - • Insufficient refrigerant
• Compressor F98 Total running current protection 3 times occurance
within 20 minutes - • Excess refrigerant
• Improper heat radiation F99 Outdoor Direct Current (DC) peak detec
tion 7 times occurance
continuously - • Outdoor PCB
• Compressor
Note:
"O" - Frequency measured and fan speed fixed.
The memory data of error code is erased when the power supply is cut off, or press the Auto Switch until "beep" sound heard following by pressing the "CHECK" button at remote controller.
Although operation forced to stop when abnormality detected, emergency operation is possible for certain errors (refer to Error Codes Table) by using remote controller or Auto Switch at indoor unit. However, the remote controller signal receiving sound is changed from one "beep" to four "beep" sounds.
Oct 13, 2017 | Panasonic Heating & Cooling
AR-5316 copier. How can I correct error CODE 4H?
H4 00: Heat roller low temperature detection
When the fusing temperature is lower than 150C° after 55sec from the start of warming up. When the warming up complete temperature is not reached in 30sec from reaching 150C°. When the fusing temperature is lower than 100C° after 20sec from ready start. When the fusing temperature is lower than 145C° when printing."
Cause: Thermistor abnormality Heater lamp abnormality Thermostat abnormality Control PWB abnormality Check and remedy Use SIM 5-02 to check the heater lamp blinking operation. When the lamp blinks normally.
Check the thermistor and its harness. Check the thermistor input circuit on the control PWB. When the lamp does not light up. Check for disconnection of the heater lamp and the thermostat. Check the interlock switch. Check the power PWB and the lamp control circuit on the MCU PWB.
Use SIM 14 to clear the self diagnostic display
Feb 05, 2016 | Sharp Office Equipment & Supplies
Code h 4 in sharp photocopier model ar5520n
Description Heat roller low temperature detection
When the fusing temperature is lower than 150C° after 55sec from the start of warming up. When the warming up complete temperature is not reached in 30sec from reaching 150C°. When the fusing temperature is lower than 100C° after 20sec from ready start. When the fusing temperature is lower than 145C° when printing." Causes Thermistor abnormality Heater lamp abnormality Thermostat abnormality Control PWB abnormality
Aug 08, 2015 | Sharp MX-3610N Color Photocopy, Print &...
Please how do I clear the H 4 display on my Sharp AL 2020 copier machine
Content
Detail
150C after 55sec from the start of warming
up.
not reached in 30sec from reaching 150C.
100C after 20sec from ready start.
145C when printing."
Cause
Check and remedy
operation.
PWB.
Use SIM 14 to clear the self diagnostic display.
Mar 06, 2013 | Office Equipment & Supplies
Error (H 4)
H4 00 Content Heat roller low temperature detection
Detail When the fusing temperature is lower than
150Cafter 55sec from the start of warming
up.
145Cwhen printing."
Cause Thermistor abnormality
Check
and
remedy
operation.
PWB.
Jan 15, 2013 | Sharp AL 1631 Copier
I have an System ERROR E001 following Error E808 on my canon 2016j copier and waht shal i do me out guys
E001 0000 Abnormally high temperature (detected by main thermistor)
The main thermistor detected an
abnormally high temperature (240 deg
C) during temperature control.
- Check the connector of the fixing film unit.
- Replace the fixing film unit.
- Replace the DC controller PCB.
E001 0001 Abnormally high temperature (detected by sub thermistor)
The sub thermistor detected an
abnormally high temperature (295 deg
E808 0000 Fixing drive circuit failure
- The heater does not turn on.
- A fixing drive motor failure was
detected.
- Replace the fixing drive motor.
- Replace the power supply PCB.
Feb 19, 2011 | Canon iR 2016i Black and White Copier
Error message of H4-00
H4 00 Content Heat roller low temperature detection Detail When the fusing temperature is lower than 150C° after 55sec from the start of warming up.
When the warming up complete temperature is not reached in 30sec from reaching 150°.
Cause Thermistor abnormality Heater lamp abnormality
Check and remedy
operation.
Good Luck do rate the solution if got help
Dec 06, 2010 | Sharp AR-5316 Advanced Digital Imager...
Canon ir 2016j
E003 0000 Abnormally low temperature (detected by main thermistor)
After the temperature detected by the
main thermistor has reached the
specified value, it does not reach the
specified value during initial rotation.
0001 Abnormally low temperature (detected by sub thermistor)
sub thermistor has reached the
Jan 09, 2010 | Minolta EP4000/5000 CS/PRO Copier
Display H and than 4.. please solve my problem with thanks.
call sercice and tell them that there is a problem with the Heat roller low temperature detection.
up.
Check and remedy
operation.
PWB.
May 06, 2008 | Toshiba e-Studio 161 Copier Copier
When I switch on the copier display H and than 4.. please solve my problem with thanks.
up.
Check and remedy
operation.
PWB.
May 05, 2008 | Toshiba e-Studio 161 Copier Copier
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
