Question about Cobra 29 LTD CB Radio
Ant light turn on whith lineal amplifier - Cobra 29 LTD CB Radio
  • 3 Answers
Your antenna light alerts you of high S.W.R.
Say your S.W.R. is fine, maybe 1.5:1, and so the antenna light is not on when the amplifier is off.
1.5:1 means 4% reflected power. With just the radio this is less than 1/4 watt. However, turn on the amplifier and 4% is much more and the radio may think the S.W.R. is higher.
That's one option, which may not be a problem. Another possibility is the S.W.R. actually increases which could be from a amplifier which is not true 50 ohms and/or lack of grounding for the increased power level. amduke@mail.com Communications Solutions
Posted on Jun 05, 2010
What is the lineal ft of a counter top 25 ft long by 3 wide?
Lineal feet are straight line feet.
You answered your own question.
25 feet.
Square feet are the surface area.
25 feet X 3 feet are 75 square feet.
Apr 18, 2017 | Cars & Trucks
How many sq. ft. in a Linear Ft
This is a kind of shorthand way of specifying flooring quantities. You can have X lineal ft of a standard size floorboard, and this will result in a certain area where the area = X times the width of the board as laid.
So we need the laid board width to answer this question.
Sep 25, 2015 | Building Materials
What does it means when the red light on the amp turns on ?
it shows that there is overload one out put or any short of wires happening or speaker mismatching has been put purely dc .if ant of these happens the red lights indicates danger/warning check ground wire also should be very strongly connected.
Aug 08, 2011 | Mmats D210005 Car Amp
I have a connex 33tlm3 works good whith litllie ant squels whith big could something be tuned up to much
Hi jeremy, my name is John. Welcome to FixYa. I think you are saying you are trying two different antenna,s. With the big one, sounds like you have a high SWR. or a bad ground. Make sure that your antenna is grounded good and nothing is blocking it. You will need a SWR meter and a three foot jumper to check this. How to check this is take one end of the coax jumper and run it to the radio and the other end to the meter where it is marked radio. Now take the antenna and put it in the other fitting marked ANT. Set the dial on the meter to SWR SET then turn off all your modulation,MIC GAIN, POWER MIC, now key the MIC and adjust the needle where it says calibrate all the way to the edge of the scale, not going past the edge, with the MIC still keyed up, turn the switch to SWR. that reading you see on the scale is your SWR. If it reads a three (3) or over, it is to high. Depending on your antenna, there are adjustments. Thanks for choosing FixYa...John
Dec 08, 2010 | Connex 3300 240-Channels Base CB Radio
Kicker Amplifier v. Pioneer Head Unit
GET RED POS+ LONG WIRE 2 BATTERY 2 WERE UR AMP IS GANA GO CONECT IT TO THE AMP POS+ (2)GET NEG- WIRE CONECT 2 WERE THE NEG- IS ON THE AMP THEN THE OTHER END OF SAME NEG- WIRE FIND PLACE NEXT 2 AMP WERE U COULD SCREW NEG- TO CAR METL CLOSE 2 AMP (3)GET LONG REMOTE ANT. WIRE CONECT IT TO WERE THE REMOTE ANT CONECTION IS ON AMP THEN SEND IT TO UR PIONEER IS AND FIND REMOTE ANT . ON UR PIONEER HEAD AND CONECT IT SO IT SHOULD BE CONECTED TO UR AMP LAST PART GET THE LONG RC PLUUGS AND CONECT TO UR AMP THEN RUN THEM TO UR PIONEER HEAD WERE THE RC PLLUGS INPUT IS THEN IT SHUD BE DONE!!!
Mar 13, 2010 | Kicker KX500.2 Car Audio Amplifier
I have kikcer amp 1500.1 is workin good for one year whith 4 memphis 15'' and one day just goin in the protection mode when i turn the radio up can you help me please
sounds like your amplifier does not have the power that your subs need check the rms out put on your amplifier and check how much rms your subs can handle if your amplifier has less rms power then your subs theirs probaly your problem that what happens when it kicks in to protection you could in up fring your out put chips in your amplifier not trying to say that the problem but check your rms power make sure the amp and subs can handle the same power
Oct 31, 2009 | Car Audio & Video
Keeps on diagnostic after i turned it on and had it completely wired what should be the problem
have you checked the power ant wire? usualy oarnge this needs to be hooked to a power source that is not on when the power of your vehicle is not on (usualy a fuse block)
May 11, 2009 | Performance Teknique ICBM-895 Car Audio...
Kole kx2-1440 wiring da amp up right
It is correct to connect the amp turn on wire to the amplifier remote. 5V is sufficient to turn most amplifiers on... It should be 12V optimally.
If the amplifier is not turning on with the ant. remote, the problem is with the amplifier.
Dec 30, 2008 | Kole audio QX1-2400D Car Audio Amplifier
Aftermarket amp installed on 2006 silverado
connect the remote turn on any wire that goes hot when the ignition is tured on
Jun 01, 2008 | Car Audio & Video
Problem no sound
If your KENWOOD unit is experiencing audio problems (NO Audio), but do have audio when TUNER is selected as the source, you may have problems with your installation.
NOTE: If using an external amplifier or the unit was installed using a separately purchased wiring harness for your specific vehicle, please check the following
If Using an External Amplifier
The P.CONT or REMOTE terminal on the external amplifier requires a “turn on” signal from the stereo. This terminal should be connected to the BLUE/WHITE P.CONT wire on the Kenwood harness and not the solid BLUE ANT.CONT wire.
If Using a Vehicle Specific Harness
The vehicle has a factory installed amplifier and requires a “turn on” signal from the stereo. Make sure that the BLUE/WHITE P.CONT wire is connected to the vehicle specific harness and NOT the sold BLUE ANT.CONT wire.
The solid BLUE ANT. CONT wire is used to trigger a power antenna ONLY when the tuner is selected as the source. Using this wire to “turn on” an external amplifier or factory installed amplifier will only allow it to work when TUNER is selected. Please refer to your instruction manual for proper installation. If you are not completely comfortable with installing the unit yourself, we recommend that you seek assistance from a professional installer.
Apr 10, 2008 | Kenwood KDC-MP438U Car CD/ MP3 Player
Cobra 29 LTD CB Radio Logo
83 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
