Question about LG WM-2277HW Front Load Washer
LE error code
Hello, can you send me the pictures of sensor position and installation? I hope I can fix it before I call for the service. Thanks.
  • 487 Answers
You dont need to call the service I will give you the link. The LG service manual does not give you the part number but sears parts list does
It is part 351 part number 6501KW2002A
http://www.searspartsdirect.com/partsdirect/retrieveSubComponentPartsAction.action?diagramPageId=00002&componentDescription=DRUM%20&%20TUB&documentId=K0712012&modelNumber=WM2277HW&productCategoryId=0153200&brandId=3204&modelName=WASHER&backToLink=Return%20to%20Sub%20Components
Order and your problem is gone
Posted on Apr 15, 2008
My lg wm0742hga front load washer machine over fill of water.
Hello Felipe;
My name is Peter. I am a retired field service appliance technician.
The LE error code stands for "Locked Motor Error." This is one of the more common error codes on LG washing machines. Ii is a fault condition. Read your manual where it explicitly tells you to use only High Efficiency (HE) detergent. Although, regular detergent is less expensive, using other than HE, you are going to continue to have problems. Such as premature drum bearing failure.This is an expensive repair.
In the LG washer, the LE error code is usually caused by the burned out hall effect sensor, Part Number: 6501KW2002A.
1.) Unplug your unit and remove the back cover.
Be absolutely certain that the HALL EFFECT SENSOR is installed correctly. Three white plastic tabs on the STATOR (motor) securely hold the sensor in the correct position. If any of the *three plastic tabs* were damaged during an attempt to remove the old sensor-this will require replacing the STATOR ASSY
Also, Check for any black marks on the wires or burns or broken wires.
Dec 04, 2014 | LG WM0742H Front Load Washer
LE error code
Hope this helps.
Error Code Condition
Error Code IE Condition Inlet water supply error
Error Code UE Condition Unbalanced load
Error Code OE Condition Drain error
Error Code FE Condition Water overflow error
Dec 16, 2017 | LG WD14311RD Front Load Washer / Dryer
Model LG EM1832cw stopped spinning, a code LE displayed, any suggestions
Hello & Welcome to FixYa
LE error in your LG front load washer is displayed when either the motor is not working or the control board thinks that the motor is locked up. A Hall Effect sensor is used in these washers which monitors the speed and direction of the motor and then forwards this information to the control board. Hope you understand by now that this LE error is displayed when there is an issue with the motor or when the Hall Effect sensor sends wrong signal to the control. Conclusion is you'll have to check both motor and hall sensor and replace the part# that is bad, usually I have seen the sensor going bad. Please get back to me if you have any other questions.
Kevin
Oct 07, 2011 | LG Washing Machines
My 7 year old LG Front Load Washer Model # WM1812CW displayed ERROR CODE LE(Overload in motor): how can I fix this problem ? The rinse cycle begins, shortly thereafter, the machine stops and the LE code...
Kevin
Aug 29, 2011 | Washing Machines
LG WM 1485FHD with LE error code. Stope washing after 5 or 10 mins and can't get it to complete cycle
Kevin
Jun 14, 2011 | LG WM-1485FHD Front Load Washer
I have an LE code on my washer. I tried resetting machine by unplugging. I still get the code. I also tried running the machine without anything in it. It still stops and give LE code. What should I do?
LE error in your LG front load washer is displayed when either the motor is not working or the control board thinks that the motor is locked up. A Hall effect sensor is used in these washer which monitors the speed and direction of the motor and then forwards this information to the control board. Hope you understand by now that this LE error is displayed when their is an issue with the motor or when the hall effect sensor sends wrong signal to the control. Conclusion is you'll have to check both motor and hall sesor and replace the part# that is bad, usually I have seen the sensor going bad. Please get back to me if you have any other questions.
Kevin
Feb 03, 2011 | LG WM1815CS Front Load Washer
LE in display
Hello,http://136.166.4.200/contents/Laundry/WM2277/WM2277xx_Service_Manual.pdf page 18 of this service manual elaborates on the LE error code and what to check.. Hope this helps you..
Thanks
May 30, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
ERROR CODE LE ON LG FRONT LOAD WASHER
LE is a locked motor error. Not to worry as 95% of the time it is just a bad hall sensor (the motor position sensor). For your model the part number is 6501KW2002A.
May 28, 2010 | Washing Machines
LG Front load washer LE error code
You can order parts by your location by CLICKING HERE
Nov 21, 2008 | LG WM-1832C Front Load Washer
LG front load machine with LE code and no spin
LE is a locked motor error. Not to worry as 95% of the time this is just a bad hall sensor (motor position sensor). It is very easy for a technician to replace and the cost is very small.
Hope this helps, please rate my solution.
Oct 25, 2008 | LG WM-2077C Front Load Washer
LG WM-2277HW Front Load Washer Logo
198 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
