Question about HP Laserjet M2727nf Multifunction Printer
HP 2727 scans first page as letter size and all other pages as legal size. I want all letter size.
Solution found: Change the scan default format to Tiff, but then save the document as PDF on the workstation. We think this is a newly discovered but unintended feature of the newest hp scanner software package.
Posted on Jun 12, 2010
  • Jarod Morris May 31, 2013
    I changed it to TIFF and still didn't fix this problem for me.
  • Jeff Theisen
    Jeff Theisen Mar 11, 2014
    Anyone find a solution to this problem? I think it started after a firmware update.
Unable to scan legal pages from feeder
Hi Nicole,
Improve the FixYa experience for everyone by voting.
There are two (2) things that I want you to try.
First, run the HP Scan Diagnostic Utility: CLICK HERE
Second, run the Microsoft diagnostic scanner. CLICK HERE
Hopefully, if you have a firmware or software problem, these two self-explanatory apps will solve your problem(s).
All the best,
May 08, 2012 | HP Officejet J4680 All-in-one Printer...
I need to scan then email a legal page size document, it is cutting of part of my pages?
Hi you need to go to scanner icon and click right mouse and choose the paper size to legal size. Otherwise it will scan in normaly paper siza which is a4 size or letter size.
Feb 21, 2011 | HP Computers & Internet
How can i adjust the printer to print out legal size paper?
Page size is generally set by the application that is sending the file.
Go under the "File" menu select "Page Setup" and verify that you have "Legal" set as the page size for the application.
You can also enter the printer driver, select printer properties and then set the page size to legal. However, if the application is set to "Letter" you will get a call to change the paper size.
Don
Jan 28, 2010 | HP DeskJet 970cse InkJet Printer
Printer wont print. It keeps saying PC Load Legal. The printer has paper in it.
Well the printer is telling you to load "Legal Size paper, which is 8.5" X 14" paper.
More than likely, the application you are using is telling the printer to print the page on legal sized paper.
If you want the document to print on "Letter sized paper (8.5" X 11") then in the application, go to the File drop down and select "Page Setup". From within page setup's window, change the paper size to letter and then re-print the job.
Don
Dec 16, 2009 | HP LaserJet 4 plus Printer
Canon 9080C not scanning 11x17 pages
The problem is probably in your scanning software, you have to tell it if you want to scan legal size, and if you leave it set for legal all the time it might put dark bars under the letter size docs. It depends on the version of software on your computer.
Sep 03, 2009 | Canon DR-9080C Path-Through Scanner
How to copy legal size paper
go to file menu and page click on page setup then click on paper now you select the letter size, A4 size, or Legal Size etc.
Jul 31, 2009 | HP LaserJet 3050 All-In-One Printer
Won't recognize legal size paper
I have a Brother MFC-8840Dn (full legal-size flatbed as well as document feeder). I use Windows XP Pro and a USB connection. I'm not sure my fix works with other Brother models or different Windows operating systems, but it's a way to start troubleshooting at least.
I've always been able to print legal-sized pages from word processing or spreadsheet programs and receive legal-sized faxes. But I never could make legal-sized photocopies or PDF scans. The image was always cut off at Letter size. The fix is a Brother Utility set-up setting:
*** Go to Start / All Programs / Brother / MFL-Pro Suite MFC 8840Dn / Scanner Utility. (This link may also be called something like Scanner Settings.)
*** At the "Maximum Scanning Size", select "Legal" instead of "Letter/A4".
*** Click OK and restart your PC for the new setting to take effect.
It's like magic -- I can now scan a full legal-sized PDF, whether on the flatbed or through the ADF. I also tried a compressed TIFF scan and it came out fine.
**** Make sure your software and/or Brother Control Center scanning configurations are set to Legal if that's what you want for the particular image scan. The Brother Utility setting simply enables the option of choosing the larger legal-sized paper, which then allows the full legal-sized image scan, You always have to set your software to make that choice, just as you would to make and print smaller images on Letter, A4, envelopes, etc. (NOTE: I always start scans through software on my PC, like Adobe Acrobat or PaperPort, and the Utility Setting fix is working fine. However, I just tried pressing the SCAN button on the front panel of the MFC itself with a legal-sized document on the flatbed and through the document feeder. I still got Letter-sized image scans. So, there must be another setting somewhere for starting scans directly from the MFC that I'll locate later.)
I was about to buy a different brand of scanner because of the frustration with legal-sized images. It's like having a new scanner now :) I hope this Utility Setting info helps you troubleshoot your legal-sized image problem.
Sep 04, 2008 | Brother MFC 9600 All-In-One Laser Printer
Tray output
You should configure TRAY 1 as Legal only.
and Tray 2 as plain letter.
Specially when you specify from what tray/paper type to print.
This can be easily configured from the Printer Properties within the Printers and Faxes section of the Control Panel.
Jan 26, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
Letter sized fax page overlaps onto 2nd page
Change your faxes DEFAULT font size to a lower setting... lt us know if it still does the same thing for the same amount of characters
Nov 09, 2007 | HP PSC 1510 All-In-One InkJet Printer
HP Laserjet M2727nf Multifunction Printer Logo
754 people viewed this question
Seeker5211
Seeker5211
