Question about Lowrance Boating
GPS screen froze..shows flashing 0.00 tried soft
Lowrance LCX 28HD suddenly.... GPS screen froze..shows flashing 0.00 tried soft & hard resets.....System Setup Page....Satellite Status..does not acquire....original date of FEB/2002 showing and unable to correct time display...says I need a location first....but can't do until I set clock for satellite tracking..and can't do!
  • Owen Ridgeley Jun 04, 2010
    Just looking for a second opinion!
  • 2,272 Answers
Many users face this same problem of GPS screen getting freezed.Mostly doing soft reset and hard reset solves the problem.But if the problem is same then there is a 30gb hard disk in the Lowrance LCX 28HD GPS that has to be checked.In some cases the connection of the hard disk gets loose or short internally causing the freezing problem.
Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Posted on Jun 04, 2010
    As I had called Cabella's for a price quote on new GPS...the advisor on products suggested that I try to install the latest version 2.5 update, which I had downloaded on computer. He thought that might solve the problem.
    If in fact I try that, I'm thinking it will be obvious if the hard drive is faulty.
    What are your thoughts?
    Guru:
  • 1,049 Answers
There is most likely a short in the unit. Could be humidity from the air, water intrusion, or small pests. It normally can't be repaired and you will have to replace it or send it in under the warranty.
    Thanks for your comment. As the warranty has expired and the "bench" fee is like $400...thinking might be better to buy a "stand alone" unit for approx $600. At least...it will come with a 2 yr warranty.
  • NA NA
    NA NA Jun 07, 2010
    Rather than do nothing or paying a hefty service fee. You could open the GPS and look for physical corrosion or damage to the internal components. Integrated components can't be fixed, but frayed wires and dirty contacts can. Also, while I don't know if this works for prolonged exposure to moisture. I know with recently soaked electronics you can get the heavy moisture out by blow drying the device for about 30 minutes and then draw the rest out by submerging the equipment in uncooked rice over-night. (Seriously) If you have a short caused by water trapped inside of integrated components this might fix it provided the components have not already been damaged by corrosion or electrical discharge and you would confirm that the device is no longer working because it is not properly sealing out moisture. Of course, even if this works, you would then need to find a way to re-seal the device again before using it on your boat, but that beats buying a new GPS.
Comes on white screen then off just for a second
If possible, try to restore the device to the newest firmware on it using your computer using this firmware:
http://www.lowrance.com/en/Products/Marine/Large-Screen-SonarGPS-Chartplotter-Combos/LCX-18C/Downloads/LCX-18C-Software-Update/
OR
Do a soft reset. This may resolve your issues and will also keep your data on the device.
Do a soft reset by:
1. Having the device already off
2. Press and hold the PAGES key
3. Press and hold the PWR key
4. Release both buttons when the USA map appears
If neither of those work, try a hard reset. This will however delete all stored data off your device.
To do a hard reset:
1. Have device off
2. Press and hold the ZIN&ZOUT Keys at the same time
If none of these work, contact Lowrance at 1-800-628-4487
Mar 05, 2011 | Lowrance LC X-18c GPS Receiver
When turning on the Lowrance the depth indicator will only register 0.0 and continues flashing the number. The Lowrance is a LCX-17M. We tryed the Lowrance on another boat with a working transducer...
here is the link to your the lowrance web site. the trouble shooting guide says that if you tried to it on another boat than you might need to take it in for service. but there is a section that explains how to do a soft reset on the unit. you might try that.
http://www.lowrance.com/en/Support/Troubleshooting-Guide/Depth-Reading/
please rate and comment on your experiance with fixya.
Aug 15, 2008 | Lowrance LCX-18C
Gps will not start up
Hello :
I recommend you to reset your device to fix the problem .
Here is how to reset your GPS :
1. Turn unit OFF
Here is how to hard reset your GPS . But be careful because Hard Reset (Deletes stored GPS Data such as Waypoints and trails)
1. Turn unit OFF
PLEASE DON'T FORGET TO RATE !
Apr 16, 2010 | Lowrance LCX-15MT GPS Receiver
Gps module not responding
Hello :
I recommend you to reset your device .
Try this for soft reset :
1. Turn unit OFF
If soft resetting didn't work , then I would recommend you with hard resetting . Here is how to hard reset your device . But Hard Reset (Deletes stored GPS Data such as Waypoints and trails) .
1. Turn unit OFF
Apr 16, 2010 | Lowrance LCX-25c GPS Receiver
Lowrance LCX 28c HD with Navionics HotMaps Premium SD chip. Chip worked fine last fall but when I went to use yesterday the Lowrance would not read the chip.
I had the same problem with my handheld Lowrance Hunt C. After installing the card and locking it in place, I had to slide the card "out" toward the locking mechanism. It barely moves, but worked after that. Whenever I load the card, I now slide it out or wiggle it and it works every time.
Apr 20, 2009 | Lowrance Lcx 28c Hd 7" Gps Fish Finder...
Im trying to change my lowrance lcx depth from feet to meters
Press MENU MENU. Scroll down to SYSTEM SETUP. Press the rigth arrow. Scroll to UNITS OF MEASURE. Navigate to depth and select METERS.
Feb 23, 2009 | Lowrance LCX-27C GPS Receiver
Hi i have had the lcx- 15 since 2001. i would like to update the software. plus the latest manual.
Here's the link to then manual => http://www.lowrance.com/en/Downloads/Manuals/
There are 3 manuals (pdfs). The first is the manual, the next two are addendums.
http://www.lowrance.com/upload/Lowrance/Documents/Manuals/LCX-15MT_0133-49.pdf
http://www.lowrance.com/upload/Lowrance/Documents/Manuals/LCX15_0133-70_add_031402.pdf
http://www.lowrance.com/upload/Lowrance/Documents/Manuals/LCX15_0133-71_add_032802.pdf
Here's the link to software updates page => http://www.lowrance.com/en/Downloads/Product-Software-Updates/
Here's the link to the most current software available from Lowrance =>
http://www.lowrance.com/en/Products/Marine/Large-Screen-SonarGPS-Chartplotter-Combos/LCX-15-MT/Downloads/LCX-15-MT-Software-Update-310/
Please leave feedback. Thanks in advance.
Dec 07, 2008 | Lowrance LCX-15MT GPS Receiver
Lowrance LcX 27C
You need to get a MMC card for it to show Canada.
Jul 02, 2008 | Lowrance LCX-27C GPS Receiver
We have a X23 Lowrance. It was working OK then it just went to flashing 0.5m with bits of blue colour over the screen. We have switched it off and then on again, but still flashing 0.5m. Can you help?
First check and clean the transducer. Make sure it's level and clean of any dirt oil or fuel. You can do a hard or soft reset also but you'll lose all stored data and it will reset all of your settings. You can find out how to do a hard or soft reset on Lowrance hompage. www.lowrance.com I would get you the exact address but their web site is a little messed up this morning.
Jun 25, 2008 | Lowrance Iway 500c GPS Receiver
Lowrance LCX-19C GPS Receiver Problem
It sounds like you may have to send it out for service, but before you you do there are a few things you can try.
Low voltage can cause erratic behavior. Since you already wired directly to the battery, check the plug for corrosion.
Try unplugging the transducer cable to see if the display still behaves erratically. You wont see depth readings but you should still see the screen going black. If no erratic behavior with transducer unplugged then problem is in the transducer cable or the plug. A common source of failure is at the plug because the added stress of plugging and unplugging cables can cause the socket to twist slightly which can cause a short.
Make sure you have the latest software update.
How to see if your LCX-19C is already using version 1.8.0 software:
  1. Press the MENU button twice on your LCX-19C.
  2. Select SYSTEM SETUP.
  3. Select SOFTWARE INFORMATION.
  4. The software version for your unit is located under the line that says "LCX-19C" (ex. "Version 1.8.0").
  5. If your version is the same version listed above, there is no need to download the software.
If it is lower than 1.8.0 you can download the update from this link: LCX-19C UPDATE
Copy it onto a blank MMC card and install it in your GPS. The GPS should prompt you on how to install the update.
If you need to send the unit in for service click this link: LOWRANCE SERVICE
Mar 15, 2008 | Lowrance LCX-19C GPS Receiver
Boating Logo
64 people viewed this question
Top Lowrance Boating Experts
Phil Walker
Phil Walker
Jerry Greenberg
Jerry Greenberg
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
