Question about Power Acoustik GOTHIC OV2-1800 Car Amp
I have two amps my power acoustic ov2-1800 stays in protect mode when i turn my car on, and my other amp is a JL Audio and it goes in and out of procect mode randomly??? Any insight???
  • 447 Answers
You have a short. Check all power connections to both amps, all the way back to the battery. Then check to make sure speakers are connected properly
Posted on Jun 04, 2010
What can I do when my amp goes into protect mode? A6450 class a/b Jl audio
Check your speakers wiring to make sure they are not touching. This will make your amp go in protection mode.
Mar 10, 2015 | Jl Audio Car Audio & Video
Why my jl audio 1400d amplifier stays in protective mode?
Check for a speaker wire that come come of , Or a loose grond wire on the amp or where ever you have the ground wire connected two,
Oct 31, 2012 | Jl Audio Car Audio & Video
Jl 1000/1 goes into protective mode with low frequency
Do you have a capacitor????? If not, when its up loud and hitting hard it might be going into protection because of a voltage sag....If it goes below 11.8v they will usually do that.....Get a multi meter and put on the hot and ground of your amp when its playing loud and see what the voltage is dropping to.....If its going below 12v, thats your remedy...gd luck....
May 02, 2012 | Jl Audio 1000/1 Car Audio Amplifier
I have a 1200 watt G-Max sub amplifier and it just went into protect mode
Turn down the volume or power settings on it since its pulling too much power and shutting off for a few sconds to keep from blowing. Depending on the amp and speakers your using dont bridge the channels. If it won't come out of protect mode then unhook everything and just hook power, ground, and remote and wee what happens. If it comes on again and stays on then amp is blown.
Aug 11, 2010 | Jl Audio Car Audio & Video
I have a JL total mobile audio T500.1 mono amp and it was playing then all the sudden it stopped and the power light which is usually green is now red and stays red and no sound comes from the subs any...
This happens when the amp goes into protection mode. 90% of the time, it means there is a short or has another issue inside the unit and has to be fixed or replaced. Hope this helps and good luck!
Jul 09, 2010 | Jl Audio Car Audio & Video
Power protect light stays on my amp its a power acoustic ps2-820
Unplug all the speaker wires and try it again, if the amplifier turn on
yo have a bad speaker, if the ampliier still in protection mode, check all the fuses in the amplifier and near the battery,
if they are ok you have a bad amplifier
good luck
Apr 01, 2010 | Power Acoustik PS2-820 Car Audio Amplifier
How can i make my jl audio 12w3-d6 into a 4 ohms
it depends if the amp is mono or stereo and if it is bridged. if it is bridged the amp cant handle the speaker the best way is to lower the level on the amp or connect it to only one channel. also you might want to check your ground cable use a thick one and make sure its making good contact with the chassis. this happened to me. luck
Sep 12, 2009 | Jl Audio 12W3 Car Subwoofer
Jl audio 250/1 thermal light
Disconnect all speaker wires from the amp and disconnect the RCA cables from the amp. If it still goes into protect mode, use a multimeter to confirm that you have 12v on the B+ and remote terminals. Place the black meter probe on the ground terminal of the amp when measuring the voltage. If the voltage is sufficient and the amp goes into protect, it will have to be repaired. JL only accepts repairs from authorized dealers. You'll have to find one in your area or you'll have to find a repair shop willing to work on JL amps.
Let me know if you have any other questions.
Oct 15, 2008 | Jl Audio 250/1 Car Audio Amplifier
Why does my amp stay in protect mode?
The most common reason an amplifier goes into or remains in protect mode is shorted output transistors. To eliminate other possible reasons for it to go into protect, read the following page.
Troubleshooting - Amp in Protect Mode
Aug 03, 2008 | DHD NTX-2139 Car Audio Amplifier
Jl audio E6450 cutting out
hi, have you figured out whats wrong with ur amp ...i have the same amp ....and as soon as i finished the connections ...and connect the remote on wire,,, the amp goes on ...making a ticking sound with the green light blinking and the red light staying solid on ...whats the problem please help ....how can i fix this ......my amp is a jl e6450 ....im using a panasonic cd player with a built in amp ....and thats the cd player im trying to connect to the jl amp ...please HELP
Nov 01, 2007 | Jl Audio E6450 Car Audio Amplifier
Power Acoustik GOTHIC OV2-1800 Car Amp Logo
87 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Jose Velazquez
Jose Velazquez
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
