Question about Chapin 26021 Pro Series Poly 2 Gallon Sprayer ()
How do I open it a Round up sprayer?
I am borrowing a 2 gallon round up sprayer and don't know how to open it to re-fill. How do I open it? Does it unscrew?
How do you refill?
Remove all pressure by keeping the hose open until no pressure is left. place pump handle down toward tank. Turn count counter clock wise to unscrew. Take assembly out of tank then fill tank. Reinstall in reverse order.
https://www.chapinmfg.com/sprayers
May 24, 2014 | Chapin 2 Gallon Spectracide Sprayer
Ortho heavy duty sprayer
I hjave a 2 gallon Orthor Heavy sprayer and the Handle will not let flud through. How can I repair this handle? Or can I purchase a replacement?
FRED
Oct 27, 2011 | Garden
I have the Ortho Dial and Spray and am applying the Round-up Weed and Grass Killer. States a 6 oz feed rate per gallon and that this should cover 300 sq.ft. I pour 24 oz into the container which should...
I'm sorry to hear about the problems you had with the Ortho Dial N Spray. This hose end sprayer empties about 2.1 gallons per minute, so you will need to walk fairly quickly to cover area you're wishing to apply product to. Please give Ortho a call at 877-465-5160, and we will be happy to assist you further.
Hilary @Ortho
Sep 03, 2011 | Ortho Dial N Spray Hose End Sprayer
I borrowed a Roundup (max fill 2 gallon) sprayer. It was working fine, but I needed to refill the tank. Now I can't get it to spray. There seems to be plenty of pressure.
Look for particulate matter that plugs the spray nozzle. Remove the tip and test for flow. Sometimes older spray has particulate matter that comes out of solution.
Jul 28, 2011 | Garden
I just want to know how much of roundup to put in the tank, you use air to disperse the weed killer?
Yes I do use it, you can put about 1qt of round up for every gallon of water. This should kill your weeds, for most precise mixing instructions check the bottle label.
Thanks.
Jul 28, 2011 | Roundup 2 Gallon Pro Garden Poly Tank Pump...
I'm not sure how to fill the thing. It's a 2 gallon sprayer, yet when I open the top (i.e. remove the pump mechanism), there is a chamber, but it only holds about 1/4 gallon. How do I get the...
it sounds like you unscrewed the pump assembly. that chamber is actually part of the pump and sometimes they do separate. try to remove what you called the chamber. if that is part of the pump then it has to come out before you can put the pump assembly back together.
May 25, 2011 | H.D. Hudson 2g Yard N Garden Sprayer
How do i fill my hudson sprayer
On the link below page 2 will tell you how to fill your sprayer.
http://www.hdhudson.com/PDF_files/poly-sprayer-instruction-sheet.pdf
Good Luck and please rate 4 thumbs up for the free answer.
Jun 27, 2010 | Eliminator Hudson Sprayer - 1 Gallon,...
Instructions for using ortho tree sprayette
The Ortho Tree and Shrub Sprayette has a fixed mixing jet set to a 24:1 ratio. 5.3 ounces of spray concentrate in the jar will mix to produce 1 gallon of diluted spray. The jar has a capacity of 42.7 ounces, so you can spray up to 8 gallons with 1 filling. If you look at the side of the jar, you will see two filling scales. On the left is the diluted spray capacity, and on the right is the concentrate scale. So you will see 8 gallons opposite 32 ounces, for instance.
You must dilute concentrates to the 24:1 mixing concentration. So if your concentrate says 1 ounce/gallon, and you want to spray 6 gallons, put in 6 ounces and add water to the jar to the 32 ounce level.
Mar 16, 2009 | Garden
Chapin 26021 Pro Series Poly 2 Gallon Sprayer () Logo
655 people viewed this question
Top Chapin Garden Experts
Nick Olsen
Are you a Chapin Garden Expert? Answer questions, earn points and help others
