Question about Whirlpool 25.4 Cu. Ft. Side-by-Side Refrigerator w/Thru-the-Door Ice & Water - Satina Stainless-Look
Weird smell in Refrigerator
We have a weird kind of chemical smell in the refrigerator and freezer. Everything works fine, it cools, makes ice. Someone said it may be a thermostat, timer or something burned up. I don't know. The refrigerator is only a couple of years old.
  • 42 Answers
SOURCE: Whirlpool GC5SHEXN Side by Side Refrigerator burning smell
How long had it been plugged in when you started to smell the burn. What kind of burn do you smell, is it an electrical burning smell or a smoldering dust burning smell.
supertechks
Posted on Nov 22, 2007
  • 65 Answers
SOURCE: Ice maker stopped working
are the "fingers" of the icemaker pointed toward you and slightly up? if not the icemaker is internally broken . is the red light to the right blinking twice and then a one second pause? if not the emmitter is broken. is the black hose coming from the ceiling blocked with ice ? if so the water vave is broken allowing water to seep in hose and freeze. hope this helps.
Posted on Feb 16, 2008
SASSYBEAR
  • 148 Answers
SOURCE: Whirlpool Side by Side Refrigerator Wont dispense ice
if you lift out the ice bucket you will see the "gear" that turns the auger. The gear is metal but the part on the bucket is plastic and this can become stripped out. Also check that there is not ice frozen around the bottom of the bucket where an ice cube may have lodged the chute door partially open and melted some of the ice in the bottom creating a blockage.
Posted on Nov 11, 2008
  • 106 Answers
SOURCE: Plastic burning smell coming from bottom front vents.
u may need to unplug it then tip it enough to see under it to see if maybe a mouse chewed on some wires and try to rewire or electic tape on some bare wires
Posted on Mar 18, 2009
  • 18 Answers
SOURCE: Refrigerator Sounds Weird
The noise is caused by the bearings in the fan motor going bad. If not replaced soon, it will quit working, and could cause considerable damage to the compressor. Have a technician look at it.
Posted on May 29, 2009
Fridge side not working, freezer side is fine.making weird noisr
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Oct 23, 2011 | Kenmore 56983 Side by Side Refrigerator
The fan is making a weird noise and when i open the door it stops but when it stops in makes a loud noise and the temp on the fridge wont stay down but the freezer is fine what is the problem
You have a twin cooling unit and the refrigerator fan is getting clogged up with ice possibly due to a defrost problem. You will need to remove the back wall panel of the refrigerator to access the evaporator fan motor and clean it out of the excess ice buildup. Check the defrost circuits and also the defrost drain to make sure it's clear.
Jul 20, 2011 | Samsung RS2630SH Side by Side Refrigerator
My bottom freezer refrig. Kenmore 596.72214200 - suddenly smelled weird burning smell from back of frig., hear occasional clicking sounds. Everything seems to be working. Smell seems to happen when...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 31, 2011 | Whirlpool Refrigerators
Kenmore side-by-side has CHEMICAL SMELL ODOR inside.
You have a freon leak. With this only being 5 years old, iot's probably worth repairing, unless you are just able to buy a new one. I would have a local tech come out and check it before tossing it. I hope this answers your question and gives you some resolution. I hope to work with you again, so please record our name, email and phone number for future needs. Have a great evening!
Sep 09, 2009 | Kenmore 53642 / 53644 Side by Side...
Refrigerator and freezer musty, freezer burned smell? ?
they should be washed every2 months use baking soda and a box of fridge charcoal
thumbs up
Aug 17, 2009 | Frigidaire GLRS264ZA Side by Side...
My refrigerator is acting weird!
Hi. thanks for the question. I would check the fan motor, in the freezer. cut power to the fridge. remove back panel. replace the fan motor. clean all ice at the bottom of freezer. clean the drain ,from freezer to the back by the compressor thanks the appliance doc. please rate my answer.
Oct 05, 2008 | GE GTS22WCP Top Freezer Refrigerator
Ice and Refrigerator and Freezer smell like alcohol chemical
I believe that you might have a coolant leak causing the chemical odor. You really should get it checked out by a fridge repair-person because it's not healthy to breathe in the fumes.
May 21, 2008 | Hotpoint HSS25GFP Side by Side...
Orange light in the lower part of freezer
pants, don't worry about this, your refer was going into defrost. When this happens, the defrost heater turns on to melt the ice off the evaporator in the freezer comp. Last's about 20 minutes and sometimes you can see the glow and hear the ice hitting the heater...Catriver.
Jan 22, 2008 | Kenmore 53642 / 53644 Side by Side...
Whirlpool 25.4 Cu. Ft. Side-by-Side Refrigerator w/Thru-the-Door Ice & Water - Satina Stainless-Look Logo
284 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
