Question about Sharp AR-164 Copier
My copier reports H4--00 error - Sharp AR-164 Copier
    Guru:
  • 1,049 Answers
It's a fuser error, but sometimes it gives a false code. First zero out the error to make sure the problem is real. To reset, enter buttons "clr", "exposure", "clr", "exposure", and the display will blank, then enter 14, and press "prnt" button. Afterwards, hit "clr" several more times to get out and that's it.
If it doesn't fix the problem you will actually have to replace the fuser.
Posted on Jun 04, 2010
  • starman66 Aug 10, 2010
    Used it on my Olivetti d-copia 120d. Just use the arrow keys (up/down keys) to enter 14 (since it has no numerical keypad). Nice one to remember. Many thanks for the solution.
How do i switch report error on
On panel press setup key>scroll to fax functions with the help of arrow buttons,enter > reports,enter >error report enter>make it on.. If you want sending report or received report just go to that, make it on...Note that every report you will loose one page as well as consuming of expensive ink.. Instead of this you can choose polling report, it will give you entire report includes sending,receiving & error...reports..
Jan 30, 2012 | HP OfficeJet 4255 All-In-One InkJet...
Error report
Hello sir; Let's do a reset;
1, press "#","interrupt", "c", "interrupt" keys.
2, enter 14 then press start.
3, if this is helpfull, please give me a good rating.
Feb 12, 2009 | Sharp AR-5316 Advanced Digital Imager...
How do i print the fax log and error report??????
The fax log or Journal is printed automatically after every 50 communications (tansmissions and receptions). If you want to print a copy of the journal;
Select Fax mode and press <Information> icon on the upper right corner of the touch panel.
Press <Print Journal>
An error report is printed whenever the transmission or reception has failed.
If Transmission result report is on, a report is printed every time so you have a record of whether it was successful or not.
Good luck and please rate me, thanks.
Jan 27, 2009 | Ricoh Aficio 2022 Black and White Copier
Cannon laser 3175 ,after copies it print activity report
yes you can go into additional fuctions button then go into reports and turn off error reporting and activity reporting, or its under communication settings
Jan 13, 2009 | Canon imageRUNNER C3200 Copier
How do i retrieve fax report from hp 4215 all in one
1 Press Setup.
2 Press 1, then press 1.
This selects Print Report and then selects Automatic Reports Setup.
3 Press ! to scroll through the following report types:
– Every Error: prints whenever there is any kind of fax error (default).
– Send Error: prints whenever there is a transmission error.
– Receive Error: prints whenever there is a receiving error.
– Every Fax: confirms every time a fax is sent or received.
– Send Only: prints every time a fax is sent.
– Off: does not print fax reports.
Note: If you select Send Only, you will also receive error reports if there is
any kind of error generated.
4 Press OK to select a report
More information? you can download manual here
http://h10032.www1.hp.com/ctg/Manual/c00095626.pdf
Sep 05, 2008 | HP Officejet 4215v All-in-One Printer
Confirmation page
You can configure your HP all-in-one so that it automatically prints error and confirmation reports. If you need printed confirmation each time a fax is sent, follow these instructions before sending any faxes and select Send Only. To set automated report options from the control panel Press Setup. Press 2, and then press 1. This selects Print Report and then selects Fax Report Setup. clip_image001.gif Press to scroll through the following report types: Every Error: prints whenever there is any kind of fax error (default). Send Error: prints whenever there is a transmission error. Receive Error: prints whenever there is a receiving error. Every Fax: confirms every time a fax is sent or received. Send Only: prints every time a fax is sent indicating whether the fax was successfully sent or not. Off: does not print any error or confirmation reports. Press OK to select the report.
Jul 29, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Konica 7020 copier
35-9 is a low temperature error in the fuser.If the fuser has a problem it will not make a copy period.Sorry. Mrbonz
Jul 20, 2008 | Office Equipment & Supplies
Avoid printing Transmission Verification Report
You have to change the fax menu settings. Here you can compute the machine to avoid the error reports (see manual chap. fax settings)
Jan 07, 2008 | Brother MFC 420CN All-In-One InkJet...
Error reports
error report msi.photogallery shows up when trying to dwnld software from disc
Nov 25, 2007 | HP OfficeJet 6110 All-In-One InkJet...
Sharp AR-164 Copier Logo
430 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
