Question about Whirlpool Duet GHW9150P Front Load Washer
I have a Gibson Washer Model GWT445RGS1 that has power to the unit. Nothing happens other than the door light comes on. No wash cycle and no spin cycle. Replaced the timer..not it. By-passed the magnetic switch in the detergent door...not it...any ideas. The unit had stopped just before the softner cycle when it stopped. Could it be the pressure switch?
  • 209 Answers
SOURCE: washing machine
just on the information you have given it sounds at first to be water leaking into the drawer from the solenoids, these could be jammed open slightly, (or one of them), with dirt, with machine switched off, remove the soap drawer and look in and see if any water is flowing in even just a trickle is too much, if so replace the affected solenoid, easy to do? start with that and see how you go on, if i have helped rate me please, thank you
Posted on Sep 14, 2007
gwshaw71
  • 83 Answers
SOURCE: Whirlpool washer
check your lid switch
Posted on Dec 07, 2007
rachael
  • 4 Answers
SOURCE: Washing machine stops mid cylcle
try pushing the door closed again, i have a problem with my machine that when i put a load on it starts then stops the light starts flashing then i firmly push the door (at the handle side) and it starts to work again, it might help!
Posted on Dec 17, 2007
jsrock516
  • 5911 Answers
SOURCE: Whirlpool LSR7133KQ0 no pumpout, rinse, or spin.
NO...the problem you are describing are the typical symptoms of a lid switch malfunction. The lid switch shuts the washer off when you open the lid while the drum is spinning. This is a safety feature to prevent injury from moving parts if you decide to add a garment or stick your hands in the tub for some reason while it is in operation. On some model Whirpool's the washer WILL work initially for the wash cycle, then stop when it gets to the rinse cycle. I would recommend you check your lid switch to make it is not loose or broken. Your washer is also equipped with a lid strike (a small plastic piece on the lid that activates the switch) make sure it is not broken off or missing. This will give the same symptoms of a broken lid switch.
If you require a replacement switch, they can be ordered on line at searspartsdirect.com, or you can go to your nearest appliance parts retailer. The part number for the switch is 3949247. The lid strike (if required) is part number 358684. If you need instructions on how to replace the lid switch, you can use this link if you like:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
I don't know how savvy you are, so I thought I would add the instructions just in case. I hope you find all this information helpful. Let me know if you require additional assistance.
Posted on Sep 25, 2008
  • 1294 Answers
SOURCE: Bleach compartment?
You normally use bleach to clean your washer. I have a washer nearly 15 years, never once put bleach, even for cleaning. Never cleaned it either, except dusting the exterior. I use powders for frontloaders. They seldom make these washers today, non-electronic. What they do today is make one to last about 2 years, then make you junk it & go for another - same story. Keeps their factories running........at your time & expense. Funny is'nt it, but absolutely true.
Posted on Apr 06, 2009
GE GFWS3500LOWW not starting on any cycle
GE Washing Machine GFWS3500L0WW Troubleshooting ...
www.repairclinic.com/...-/GE-Washing-Machine-GFWS3500L0WW-Tr...
GE Washing Machine GFWS3500L0WW ... Washer fills slowly · Washer leaking water · Washer won't start · Washer won't spin or agitate · Washer overflowing ...
Repair Help - Model Help Repairwww.searspartsdirect.com/ge/washer/model-gfws3500l0ww-repair.htmlRepair Symptoms for GE Washer Model #gfws3500l0ww. Shop Parts ... Slow or noagitation or spinning ... Not working at all ... Clean Washer cycle won't work.GE front load washer door latch Repairwww.appliance-repair-it.com/front-load-washer.htmlIf your GE front load washer has a door latch problem such as the door will not lock or... You should always use HE detergent on any front load washer. ... manually unlocking the door and pouring cold water into the tub then start a new cycle.GE Front Load Washer Service modewww.appliance-repair-it.com/GE-front-load-washer.html
Jan 28, 2016 | GE Washing Machines
Only Power and door light comes on - no wash cycle selection
To start the door sensor is faulty, in any case you have more than one problem. which is make and model?
Mar 02, 2008 | Washing Machines
Why won't my washer start a cycle? Start button LED just flashes. All other lights are steady. Door lock sounds like it engaged, but nothing happens.
There should be a way to enter the washing machine into service mode to view an error code. Check your user manual and then you should have your answer!
Jul 23, 2014 | Washing Machines
Service number kuds301xbl2
I would find the electrical breaker for this unit and shut it off for a minute, then re set the breaker thus resetting your unit.
Apr 28, 2013 | Maytag MDBH975AWS Stainless Steel...
HE2 front loadable washer doesn't move fm wash to rinse to drain
Sounds like the door lock. It will not advance to spin if it thinks the door is open. There is a instruction sheet inside the unit behind the lower panel. That will give the error codes for the flashing lights.
Sep 04, 2009 | Kenmore Elite 45986 Front Load Washer
Control lock light will not go off.
Do you have any error codes?
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
GE TOP LOAD WASHER DOES NOT AGITATE OR SPIN
ck lid switch can be acessed by pressing clips at front edge of front anel and pulling panel off
Nov 20, 2008 | GE WWSE5200B Top Load Washer
EQUATOR 3612CEE WASHER DRYER/NOT DRYING
First of all you may want to reset the unit, let me know if you need the procedure and after reseting if the unit the washer knob may go round and round all by itself, if this happens the door mode light will flicker in a particular sequence which once once counted we can understand exactly which part in the machine has malfunctioned which once replaced the unit should start to work properly.
Jun 08, 2008 | Equator EZ 3612 CEE Front Load...
Brand new Front Loader not washing
well if its spinning and not washing, that does sound like aproblem with unit and not what your doing, id call a service company to figure it out, thats why you bought new, not so youd repair it
Mar 29, 2008 | Washing Machines
Front loading frigidare washing machine
Check breaker only one breaker are function recock it the two breaker try to start it .
Jan 07, 2008 | Frigidaire GLTF1670A Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
74 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
