Question about Blendtec Smoother Work Top Blender
How to change the blade
I have a blendtec  ICB-7  and need to know how to change the jar's
 blade.Thanks
  • Thomas Fox
    Thomas Fox May 18, 2015
    You cannot change the blade in your ICB-7 Blendtec jar. What you can do as of July 2015, is to buy the Alterna Jar, which has a replaceable blade which, if it does wear out, you can change. And the cost is less, significantly less if you just change out the blade. The Alterna jar is also a 2.5 liter / 80 ounce container by volume, and the knives are VERY sharp. More detailed info available on www.alternajar-store.com,
    Problem Solver:
  • 8 Answers
You can't. The Jars have perfectly balanced blades that cannot be changed. A replacement jar from Blendtec is cheaper than a replacement blade assembly from other manufacturers. 1-800-253-6383 is the customer service number.
Posted on Jul 28, 2010
  • Thomas Fox
    on www.alternajar-store.com you can buy a new Alterna Jar that fits onto the Blendtec blenders and comes with a replaceable blade assembly, which, if you do need to replace the blade anytime in the future, can be replaced for a significant lower cost than buying a new Blendtec jar. Plus the blades are sharpened, there are 6 knives, for multi-purpose use, and the jar is a 80 ounce 2.5 liter jar. The same jar also fits on Waring XT blenders and Vitamix Blenders (switching out the blade unit of course). See www.alternajar-store.com for more info. Thanks
Get a manual for blendtec ES3
i have blendtec blender model ES3 they have problem always showing overload?
Apr 06, 2012 | Blendtec Extra Carafe / Jar for the Total...
I have an ICB 3. The LED display lights up and when you touch the buttons it beeps but, it will not spin.
I called blendtec and got it figured out. The unit was in some locked mode and so I had to push the buttons 4-1-3 in that order to get it to work. The confusing thing is there's two invisible buttons between 1,2 and low, high. So the buttons go 1, 2, 3(invisible), 4(invisible), 5 (low), 6 (high). It mentions these options in the manual on page 18.
Jun 25, 2011 | Blendtec ABC Work Top Blender
Does anyone know how to reset a Blendtec ICB-3 to factory settings?
ust removing all power from the machine for 15 secs or more should reset it.You can contact Blendtec here, Not a solution I know sorry. The manual is here http://www.blendtec.com/Resources/A3-31E-BHMV/Connoisseur%20Manual.pdf
you can contact them here
http://www.blendtec.com/contactus.aspx
Jan 03, 2011 | Blenders
The blades on my blendtec jug are stiff, any way to loosen them?
What you need to do is turn them by hand each time you use it, before you put your food in. Sugars and other deposits are often left around the blade assembly when you mix smoothies and stuff. Often this sugar is difficult to clean. Turn them by hand first to break the sugar molecules, then when you are done I would add 2 inches of water and a drop of soap. Run it for about 20 seconds and rinse. That should help the next time you use it. It also helps to use it daily. It keeps the molecules from hardening.
Jul 28, 2010 | Blendtec Extra Carafe / Jar for the Total...
Blendtec replacement jar
You can also go to http://veggiesensations.com to buy blendtec total blender parts. Hope this helps!
Jun 30, 2010 | Blendtec Extra Carafe / Jar for the Total...
The rubber washer in the jar burned up
Happens occasionally. Call blendtec and they can hook you up if it is still under warranty. 801-222-0888.
May 19, 2010 | Blendtec Extra Carafe / Jar for the Total...
ICB-3 Blendtec unit is getting power but will not turn on
check thermal fuse internally , one time blown fuse. need a test meter to check this component , can be bought @ Radio Shack apx $ 8.00us
Mar 13, 2010 | Blendtec ABC Work Top Blender
There is a leak in the caraffe(or jar). It is at
Common issue with all of these carafe's. Once the jar starts to leak the bearings are shot and it is time to replace the jar. The bearings are non-replacable. Bad design in my opinion. I was able to get my last jar (I have been through 3 before the 5 year warranty went out) to last by hand washing and not putting it in the dishwasher, but after 4 years of use on this jar it failed too.
Nov 29, 2009 | Blendtec Extra Carafe / Jar for the Total...
What to do with the Total Blender when overload appears?
The product has a 3-year warranty:
A reading of “OVERLOAD” indicates an overload on the motor. Turn off
and unplug the unit. Plug in the unit and turn the motor on again to clear the
over-load condition. Check the blender jar for blockage. If overload condition
re-occurs, contact your Blendtec service agent.
Mar 25, 2009 | Blendtec ABC Work Top Blender
Blendtec blender jug split
I wouldn't fix the jar, just buy a new one. A crack, though rare, could possibly harbor bacteria. You could try using heat and melting it, but it wouldn't work as well. Your jar may still be under warranty, call Blendtec at 801-222-0888
Feb 24, 2009 | Blendtec Extra Carafe / Jar for the Total...
Blendtec Smoother Work Top Blender Logo
1,666 people viewed this question
Top Blendtec Blenders Experts
eyecam
Ross Keen
Are you a Blendtec Blender Expert? Answer questions, earn points and help others
