Question about Dishwashers
I have an AEG Favorit 665i dishwasher that needs a new motor. Are they still available ? Thanks
  • 8,197 Answers
Yes the motor is still available. You can order it on the link below.
http://www.expertappliance.com/partfinder.php
Posted on Jun 04, 2010
AEG Favorit Integrated Dishwasher failing to heat the water. has the element gone? and how do you get at it?
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Mar 23, 2011 | AEG 23 in. Favorit 50750Vi Built-in...
We dont know how 2 turn it on just moved house n no instructions aeg oko favorit dishwasher
Looks like what you need is available at
http://www.serviceforce.co.uk/pdfs/U20206.pdf
Good luck with the new house. Hope the dishwasher works well for you.
Try to run it with dishwasher cleaning kit (no utensils) to make sure everything is clean - that way you will get more life out of it. The cleaning kit (usually Finish) is sold in the supermarket in the detergent section.
Jan 31, 2010 | AEG 18 in. Favorit 54750Vi Slim-Line...
AEG Favorit 665i. Lower arm does not turn
im not sure about this if the upper arm is working ok,because the lower arm gets the pressure first then sends it to the upper arm,if the water pressure to the machine is ok then the lower arm is at fault take another look at the lower arm something is not right with the lower arm.adrian;;
Jan 22, 2010 | Dishwashers
The LED display on my AEG F88070IM is blank but
yes a new display is the most likely solution but check connections from input to lcd display card 1st..
Jan 04, 2010 | AEG 23 in. Favorit 88070IM Built-in...
AEG OKO FAVORIT 6050 trips earth leakge
This is typical of a water leak onto electrical connection OR the electrical element has shorted internaly . Check this with a Ohm meter and itshould show the problem
Dec 20, 2009 | AEG 24 in. Favorit 60830 Free-standing...
Antiflood system triggered-how to reset on aeg favorit 35080vi
Hello everyone. Have just fixed a problem with my aeg dishwasher thanks to this site. My anti flood switch in, so I unpluged, pulled the machine out, tilted it, wiggled the outlet hose, which I think was a little kinked and way hay it works. Thanks FIX YA. Good luck everyone. Carolyn
Feb 08, 2009 | AEG 23 in. Favorit 88070IM Built-in...
AEG Favorit 50730 Dishwasher
The dishwasers have heat (inductive) elements in line with the top sprayer hose and is about +/- 15 cm long and has an electrical push on clip at the side of the device.
Oct 26, 2007 | AEG 24 in. Favorit 50730W Free-standing...
Integrated dishwasher door fitting
open the front door. On each side of the inside of the door are various long screws, unscrew these and the old door will fall off. discard the old door and follow the same steps in reverse to put the new door on. It took me 10 mins to do. Hope this helps
Apr 12, 2007 | AEG 23 in. Favorit 50750Vi Built-in...
Dishwashers Logo
43 people viewed this question
Top Dishwashers Experts
