Question about Frigidaire GLWS1339CS Top Load Washer
Frigidaire GLWS1339CS Top Load Washer Does not drain after agitating. Does not spin either but don't know if that's because its not draining? Jumped the switch on recommendation of handyman, didn't help
  • Frigidaire Master
  • 43,501 Answers
If you are having a problem with your top load washer then check out this tip...
Washing MachineFrigidaire GLWS1339CS Top Load Washer - 2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on Jun 05, 2010
Why does my washing machine does not drain the water inspite of replacing with a new drain pump
Good Morning Friend,
I understand that your Frigidaire washer, model# GLWS1339CS, will not drain the water even if you program it to just drain. I also see that you just replaced the drain pump in your appliance. I suggest checking the drain hose to make sure it is not kinked or clogged. I would also check your home's drain system to make sure that it is not clogged either. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 21, 2014 | Frigidaire GLWS1339CS Top Load Washer
My washer does not spin or drain.
If the unit will agitate but not spin or drain I recommend checking the lid switch first. You should be able to hear the lid switch click as you slowly open & close the lid. If you don't hear a distinct click, replace the switch.
Here is the part you need.
Oct 13, 2012 | Kenmore 24032\24036 Top Load Washer
Washer will not spin. it will agitate during the wash cycle but not spin
Problems with a washing machine not spinning or not draining are often inter related..
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Feb 11, 2011 | Frigidaire GLTF2940ES Front Load Washer
Replaced the belt and still not agitating, switch seems good
If the machine fills, won't agitate, wont drain or spin, then you need to replace the lid switch.
if machines fills, wont agitate, will drain but not spin, then you need to replace the motor coupling
Feb 08, 2011 | Frigidaire FWS1339A Top Load Washer
Hi, my washer will fill, agitate, stop and not drain or spin.
Hi everyone, I found the solution to my washer problem. I checked the lid switch and it was ok, but the lid lock was damaged. I opened the lock and I solder it and the problem was solved.
I hope this info can help someone.
May 25, 2009 | Frigidaire FWS833A Top Load Washer
Washer won't drain or spin
top loader ??? or front loader??? if top loader you have broken your lid switch, will fill, agitate, but when it comes to drain/spin for safety reasons if the unit doent recognize the lid closed it will not advance...if yo have a front loader then i would suspect that something has gotten into the pump assy and preventing drainiing of water therefore will not spin
Mar 02, 2009 | Kenmore Washing Machines
Frigidaire Top Load Washer
Hello vohra_sam
welcome
You said , Water will not drain out
Usually this is the answer
Water in washer does not
drain or drains slowly.
Because drain hose is kinked or clogged.Clean and straighten the drain hose.
let me know, Huuum
Sep 08, 2008 | Frigidaire GLWS1339CS Top Load Washer
Frigidaire GLWS1339CS Top Loader, Won't Spin
Smoke usually means a major overheating of a belt or agitator transmission, get this checked before trying to run it again,
Jun 25, 2008 | Frigidaire GLWS1339CS Top Load Washer
WASHING MACHINE
washing machine goes through whole washing cyle without draining.
Nov 07, 2007 | Frigidaire GLWS1339CS Top Load Washer
Frigidaire GLWS1339CS Top Load Washer Logo
249 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
