Question about Morphy Richards 42298 Iron with Auto Shutoff
Refilling water reservoir
I have Morphy Richards Jet Stream ironing system. What is correct way to remove water tank.At present I hold back of base and pull tank off,this takes a lot of tugging & pulling and I feel that this is not normal .
My instructions were thrown out with the box the iron came in.
    Genius:
  • 1,739 Answers
The Instruction Book for your Morphy Richards 42298 Iron can be found here:
http://www.morphyrichards.co.uk/Downloads/InstructionBooklets/IB42298.pdf
Make sure that before you attempt to slide the water tank back that you operate the Tank Release Knob.
See the instructions for an illustration of your iron and the positioning of the Tank Release Knob.
Sorry someone has not responded sooner.
Posted on Jun 20, 2011
Why is there No steam from morphy Richards 42247 model steam generator?
It may be calcified or have lime scale. If the heater is "gummed up", it cannot heat properly. Try using either vinegar (takes longer) or an iron cleaner. You pour it in and it breaks up the scale. CLR works quite well too. Use pipe cleaners to clear out the holes in the sole plate.
Jun 02, 2014 | Morphy Richards Jet Stream 42271 Iron
Brown steam
Brown steam is normally associated with internal rust in the iron. descaling may help clean it up. To descale make a solution of 3 parts distilled water to one part white vinegar, about a teacup full and pour into the irons water reservoir. Switch the iron on and set it on to the highest steam setting. Place a clean tea towel or similar on the ironing board and steam-clean it with the iron for a few minutes. The vinegar/distilled water solution will break down and expel the limescale. Turn off the iron (unplug). Pour out the water and vinegar solution. Pour clean distilled water into the iron reservoir and steam-clean a new clean cloth for a few minutes. this will remove any risidual vinegar etc. Turn off and unplug the iron and pour out the remaining water.
Oct 26, 2013 | Morphy Richards Jet Stream 42271 Iron
Descale
Soak and/or run vinegar or CLR through it. They also make a steam iron cleaner.
May 11, 2013 | Morphy Richards Jet Stream 42271 Iron
How to descale your morphy richards jet stream 42271 iron
you must read your owner manual section maintenance or troubleshooting , or get contact support from the factory, via chat or phone.
God bless you
Sep 23, 2012 | Morphy Richards Jet Stream 42271 Iron
MORPHY RICHARDS 42256 JET STREAM STEAM GENERATOR IRON does not provide steam
My MORPHY RICHARDS 42256 JET STREAM STEAM GENERATOR IRON has stop producing steam. I have changed the filter and although it heats up, it does not produce any steam.
Feb 29, 2012 | Irons
My Morphy Richards Jetstream is about 5 or 6 years old & works fine except that when I first use the steam I get brown water marks on items. This means I have to wash them again. What can I do to solve...
Try cleaning the inside of the water holder it might just be calcium built up, use white vinegar to clear it and you'll prolly be fine. Put vinegar where you usually put the water and heat the iron up and steam the vinegar through the iron then put water, try distilled water to save this problem from happening again or try filtered water.
Jun 08, 2011 | Morphy Richards Jet Stream 42271 Iron
Steam comes out of the base system reducing the amount of steam that now comes out of the iron. The filter has been changed, could it be block with scale.
Yes it could. Try using CLR, Lime Away, both are Calcium, Lime, and Rust removers. They attack and disolve all 3 types of build ups almost instantly. You can buy eithere at most supermarkets, hardware stores. Use it on your shower heads too, it will improve water flow, Follow instructions to the letter,
May 16, 2010 | Morphy Richards Jet Stream 42271 Iron
Morphy richards jet stream iron
We have a water filter and softened water. Our iron is clean and went after 2 months.
A Morphy Richards Jet Stream Elite pro.
It is just the steam generator that has gone.
May 27, 2008 | Irons
Morphy Richards 42298 Iron with Auto Shutoff Logo
210 people viewed this question
Top Morphy Richards Irons Experts
Mack Baxter
Are you a Morphy Richards Iron Expert? Answer questions, earn points and help others
