My remote will not operate the tv. how can i reset
My emote will not operate symphonic 19'' tv. how can i reset the tv or fix the infrared sensor?
    Novelist:
  • 144 Answers
The most common problem that causes this is the batteries in the remote.
Try replacing them with fresh batteries. Make sure that they are in correctly, they will only work in one certain position. Next make sure that nothing is obscuring the Infrared Sensor on the front of the set.
If the remote does absolutely nothing after these checks I would suggest purchasing a universal remote control, follow the instructions that come with it to program it for your particular brand. There may be several different codes for your brand of TV. You might need to try all of them one at a time to find the correct one. When you find the correct one I suggest that you save the little booklet that comes with the universal remote in case you need to program it for a different TV or have to re-program it again. It will give you step by step instructions. There may be a search function on the new remote that will allow you to simplify the programming.
Zashiban
Posted on Jun 04, 2010
Where is the IR on a Symphonic TV?
You are asking about the infrared sensor position, I assumes, and posts this solution. The infrared sensor can be located just behind the infrared sensor window at the front panel of the TV. You have to open the TV and take out the front panel control board out to access it. It is a three terminal component, can be bought from most of the electronic spare part shops at your town, and won't cost more. It will look like this.
Jun 28, 2012 | Symphonic ST420FF 20" TV
My original remote is not working. I bought a universal remote and it doesn't work either. Can't get a remote to work on the tv
Hello
The remote sensor inside the circuit board of your TV is faulty. It is the component that receives the infrared signals of the remote control. If this component go faulty, no remote control will go with the TV. This component can be located on the front panel board of the TV just behind the infrared sensor window at the front. You have to open your TV to locate this component. It is a three terminal component, look brownish black in colour. The sample picture of it has attached here. It is very cheap to buy, and can be bought from most of the electronic sparepart shops at your town. If you have a concept of soldering and resoldering, you can replace this component yourself at home OK.
Oct 02, 2011 | Symphonic ST420FF 20" TV
I also have a 19" Symphonic tv vcr combo which
The problem is with the vcr section, it is stuck in eject mode thinking there is a tape. This a mechanical problem that might be repairable. The tv and vcr share some of the same circuits, you can try resetting the tray in the out position as if it fully ejected the tape. Now if this does not work it means you have a gear timing problem or bad sensor.
Dec 23, 2010 | Symphonic SC319C 19 in. TV/VCR Combo
My will not work with the remote any longer. I replaced that. When I manually turn power on, it takes 3 or 4 times before coming on. Then, it will turn off after about 30 seconds. ANy ideas?
There is an infrared sensor inside the tv to receive infrared signals transmitted by the infrared signal generating light emittin diode fixed on your remote control. Either the sensor inside the tv or light emitting diode in the remote controller faulty, remote function will not work. For manual operation troubles, check the wall power socket of plug of the tv is faulty, loose contact etc.
Oct 13, 2010 | Sony FD Trinitron WEGA KV-34XBR800 34" TV
I can't find a code to set the remote for my Symphonic combination TV/DVD tv
Hello, on some of these combinations you might have to try not only the TV codes on your universal remote list, but also the DVD or VCR codes also. One of these three will program your universal remote, but make a note: you may have a partial function on your remote ie: power, but no volume control or channel scan(up/dn) or no number operation(0-9). This happens on some of the universal remotes not all of them. thanks!
Jun 19, 2010 | Symphonic WF-719 19 in. TV/VCR/DVD Combo
A friend gave ne an old Symphonic TV with its Remote control. Trying to program my TV but the remote has the ''UP'' , ''DOWN'' , ''LEFT'', ''RIGHT'' arrows but NOT a ''SELECT'' button. I do I lock-in the...
u can go 2 buy a universal remote with a handbook 2 tell u how 2 program it lol.b alot easier.that way if u have dvd & vcr...it can b programmed 2 operate it as well as the tv!universal remotes r the best sollution lol.lazier the better lol.
Sep 23, 2009 | Symphonic SC319C 19 in. TV/VCR Combo
Symphonic 19 inch
you should purchase a remote for your set to remove system OSD from showing. If you want I can post you one that is exactly matchable to your TV set.
Patrick
Jul 25, 2008 | Symphonic ST419E TV
Please help!!!
Try the remote's "search" feature. If that does not work, then the remote doesn't have a code for that unit.
Hope that fixed ya...
Geno
Mar 28, 2008 | Symphonic WF-719 19 in. TV/VCR/DVD Combo
Symphonic WF-719 19 in. TV/VCR/DVD Combo turns on and automatically shuts off I cant get it to stay on
It is likely that your infrared LED, under the VCR mechanism, might be dirty or failing.
Mar 17, 2008 | Symphonic WF-719 19 in. TV/VCR/DVD Combo
Televison & Video Logo
313 people viewed this question
Top Televison & Video Experts
Electro Med Services...
