Question about HP Photosmart 8250 InkJet Printer
Error message - calibration failed.
After inserting all new HP cartridges and running the "alignment" procedure, got error message on printer display: calibration failed.
Talked to HP support techs who had me clean where the cartridges are inserted with damp que tip, then re-insert cartridges. Still got the same message when trying to align. They then told me it was a hardware problem and would require me to sent printer in for repair (not feasible from cost standpoint) or just buy a new printer and they would give me a rebate. Their offer was less than interesting to me.
tom19511
  • 1601 Answers
SOURCE: Aligning printer after new ink cartridge inserted
SOLUTION: Start the cartridge alignment by performing a series of button presses from the front panel of the product.
  • HP PSC 1200 and 1300 series:
    1. Turn on the HP PSC 1200 or 1300 series product.
    2. Disconnect the USB cable from the all-in-one.
    3. Press the sequence of front panel buttons below to start the print cartridge alignment process. The button-press sequence must be completed within ten seconds. It might take several tries to complete the sequence within ten seconds.
      1. Press and hold Cancel .
      2. While holding Cancel , press On .
      3. When the Check Paper and Check Print Cartridge lights begin to blink simultaneously, release both buttons.
      4. Press Cancel again.
      5. Press Copies .
      6. Press Paper Type .
      7. Press Color Start Copy . The alignment page will begin printing. If the alignment page does not print, repeat the button-press sequence in this step.
    4. When the alignment page has printed, place the page face down on the scanner glass and press Scan . The alignment is complete when the On light stops blinking.
    5. Reconnect the USB cable.
CAUSE: This can occur if the cartridge alignment is canceled or times out without a valid print cartridge alignment stored in memory.
Posted on Nov 12, 2007
SOURCE: align cartridges error
This means one of the cartridges is defective, they cant align if they cant print.  What i did to fix this problem is insert 2 working cartridges and get it to align properly, even if they are low on ink, then lift the cover and the cartridges will move to the center.  When this happens pull the power cable out, then insert the full non functioning cartridge. Plug the power cable back in.  I tried this with a color cartridge, the color cartridge was non functioning but i was able to print in black.
Basically you align the cartridges and then swap them so the printer thinks they are still aligned.
The color still doesnt work and it is probably a defective color cartridge.
Posted on Sep 13, 2008
jmassengill
  • 345 Answers
SOURCE: The printer doesn't recognize the new original HP color cartridge
There is a small spring that holds the ink cartridge in the ink holder. You will see it stick out from the right hand side of the ink holder where the ink cartridge slides in. If that spring isn't being held to the ink holder by two plastic tabs, (I.E. the plastic tabs are broken) the printer will never recognize the cartridge. If the printer is still under warranty I would contact HP or an authorized repair center for HP. Both the black and color ink holder has this spring. I know of no way to repair this kind of breakage.
Posted on Jan 08, 2009
leroyal
  • 2120 Answers
SOURCE: HP 1610 alignment failed error message
replace black also
Posted on Jan 25, 2009
POCBM
  • 121 Answers
SOURCE: hp officejet 6110
If machine does not print the colors it cannot align. Try changing the color and try again
Posted on Apr 03, 2009
Hp photsmart 8250 system failed error code Oxc19a0013
According to the HP website, this error code means the ink system has failed, and the unit will need to be serviced by an authorized HP repair technician - An Ink System Failure or 0x Error Message Displays on the HP Printer...
However, you can try resetting the printer first -
Reset the product
  1. Without turning off the printer, disconnect the USB cable from the rear of the product.
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the printer, and then try printing again
  10. If the reset fails it will require a service.
  11. NOTE: if you are using refilled or remanufactured cartridges try the reset with genuine hp cartridges as they will be recognized as original authentic HP cartridges by the printer
Apr 13, 2015 | HP Office Equipment & Supplies
How to set print alignment in hp officejet K7100
During cartridge alignment, the error message 'Print cartridge alignment failed' displays on the printer control panel....
More Info visit this links...
Print cartridge alignment failed Error Message Displays on the All in...
Alignment Page Does Not Print
Thanks,
HP Printer Support
Jun 26, 2014 | HP Officejet Pro 8500 Wireless All-In-One...
I have an HP Photosmart C4795 printer. I am getting an error "cartridge error:. I have tried changing to new original HP ink cartridge and loading and unloading cartridge several times. I can not...
Welcome to FixYa!
Try to reset the printer by doing the following;
1. Turn ON the printer.
2. Disconnect the USB printer cable at the back of your printer while the printer is ON.
3. Remove the cartridge.
4. Wait for the "Insert Cartridges" message to display on the message screen of the printer.
(You can skip this if your printer does not have this feature.)
5. Disconnect the power cord from the back of the printer.
6. Wait for 1 minute.
7. Reconnect the power cord.
8. If the printer does not turn on, use the power button to turn it on.
9. Reinsert the cartridges.
10. If the printer prompts you to print a calibration page or requests for a cartridge alignment, please do so.
11. Reconnect back the USB printer cable and try to print.
I hope that this would be helpful to you, thank you for usng FixYa!
Jas247
Mar 07, 2011 | HP Photosmart D5145 Printer
I "m getting error 252*
Welcome to FixYa!
The USB printer cable looks like the image below.
3. Open the Cartridge Door and remove the cartridge. Refer to the image below.
Jas247
Mar 06, 2011 | HP Photosmart Premium C309A All-In-One...
I am getting an error message: 0xc18a0206
Hi
This is the proper procedure andif this fails, take it in for service.
Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
Open the cover of the product and remove the print cartridges.
Close the cover and wait for the Insert Ink Cartridges message to display.
Disconnect the power cord from the back of the product and wait for one minute.
Open the cover and reinsert the print cartridges.
Close the cover. If prompted, print a calibration page.
Reconnect the USB cable, and try to print a print job from the computer. Source(s): Computer Analyst / Microsoft Certified
Feb 12, 2010 | HP Photosmart D7160 InkJet Printer
Everytime I switch on the printer,it starts alignment and prints a page
Try removing the two cartridges and power off unit.
Disconnect the power source and allow the unit to set for a few minutes.
Reconnect the power source and wait for error messages to come up on unit or computer.
Re-install the first cartridge and wait for the next message.
Again, insert the last cartridge and wait for the unit to acknowledge alignment procedure.
Answer yes to alignment and complete procedure.
After a complete alignment procedure, the unit should register the completion of setup.
Hope this works for you.
Happy Holiday's
John
Dec 09, 2009 | HP PSC 1315 All-In-One InkJet Printer
I'm told by the HP Officejet J4540 that the color cartiridge has a problem. It is new. I've done all I know to do. It tells me to refer to the device documentatio. Got any ideas? THANKS!! Everytime I try...
IS IT REFILLED IF NOT TRY TO ALIGN THE CARTRIDGE
REMOVE THE CABLE FROM THE BACK
PRESS # AND 6 AND BY KEEPING THEM PRESSED INSERT THE POWER CABLE
ALIGN THEN
Sep 18, 2009 | Office Equipment & Supplies
Installed new computer - keep getting error - HP Photosmart C6150
Try
Reset the product:
  1. Without turning off the product, disconnect the USB cable from the rear of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
Jan 10, 2009 | HP Photosmart C6180 All-In-One InkJet...
Hp psc 1610 alignment error
replace the colour cartridge aLSO AS IT NEEDS some specific colour to start this allignment and to complete but the colour is not getting printed so this error.
remove the cartridges from the printer.unplug the printer for some time.then again ON it and insert the cartridges and try .
sometimes it helps.
Jun 02, 2008 | HP PSC 1610v All-in-One Printer
HP Photosmart 8250 InkJet Printer Logo
94 people viewed this question
Seeker5211
Seeker5211
