Hi I have two marantz amps witch cut in and out when run from
Hi I have two marantz amps (Pm-66 se and Pm 55) witch work fine when used with a cd player etc. However when I try to run them out of my allen & heath xone 92 dj mixer they start cutting in and out and clicking when they do it. Would you know why?
Regards Robert
  • rdoublem Jun 08, 2010
    Hi Barbu51,
    Thanks for the reply its really helpful. Do you think this will do the job? http://cgi.ebay.co.uk/Samson-S-Plus-Ster...
    Or should I go for something better? Will a limiter effect the sound quality?
    Regards Robert
  • rdoublem Jun 09, 2010
    Hi Shpbling thanks for taking your time to help me. I am running from the output on the mixer into the input on the amp. So would it not be the other way round? Sorry if I am wrong I just want to build a better understanding of whats going on.
    Regards Robert
  • 447 Answers
In stereo terms your system is "clipping" which means you are pulling more amps than the system can handle. If it happens only when you use the mixer, I'm thinking the mixer cant handle the power. Check the specs, It should show maximum amp input.
Posted on Jun 04, 2010
  • Stephen Potts Jun 09, 2010
    Running the mixer after the amp is correct. This way the mixer takes the amplified sound and adjusts the different sound levels to your liking. Try it first with the amp turned 1/2, 3/4 of the way up and the mixer set at minimum levels. Play something with extended highs and lows, and turn up the mixer slowly. You are looking to hear when the sound starts to distort. If you hear no distortion, increase the amp power slowly, untill you get some, then turn it down. This ensures you will not overdrive the mixer.
  • 566 Answers
Hi Robert
To answer your question;
I`ve worked with allen&heath mixers installed in clubs/bars and most often we had to limit them because of the high peaks they can generate at the outputs.
What is probably happening is that those high peaks force your amps into clipping and the protection circuits are getting engaged.
The way to resolve that problem may be to install a limiter/compressor such as the dbx 160a in between your mixer and amps .
There are many different brand and type but you can look at the dbx by clicking HERE
Hope this help and happy listening.
Testimonial: "Very helpful, will look about for a limiter now."
  • Jacques Marin
    Jacques Marin Jun 08, 2010
    Hi again robert
    This actually looks pretty good and the price looks right (translated in canadian dollars)
    As for the sound quality you`ll get use to adjust it where it won`t be noticeable.
    I suggest you crank up the compression when you first get it , that will give you an idea when you hear the sound going like through mud. :)
    By the way: the "Samson" brand is popular on this side of the atlantic too.
    Cheers
Marantz PM-66 SE: Power light comes on, but the amp does not work
try taking a flashlight and look through cover into unit for a blown fuse or take cover off (which is better) if taking cover off unplug unit. If a fuse is blown remove it and take to a store like Radio Shack for proper fuse watt and amp..if fuses are ok i would get it fixed...sounds like a minor problem since main power is there. GL
Aug 08, 2014 | Marantz Audio Players & Recorders
Marantz problems
The speakers are 8ohms. Always try using speakers 6 or 4ohms. For B&W 683 on PM 6004 is too low. You should go for PM 7000 or 8000 series to catchup with 683. Also when you increase the volume please decrease the bass as well.
You need 8ohm 55w to 90w or 4ohm 80w to 110w speakers.
Jul 20, 2014 | Marantz PM6004 Integrated Amplifier
Marantz pm 7200 loudspeakers do not cut off when headphones pugged in
Some amps have a button which you press to mute the speakers when the headphones are plugged in. Sometimes marked "Speakers on off". If it hasn't then a new headphone socket would not be expensive to fit. As long as the amp producers sound I don't see any future problems. The previous owner may have used the headphone socket a lot, and simply wore it out!
Jul 19, 2012 | Marantz Audio Players & Recorders
The OVERLOAD on my Marantz PM 44-SE is tripping out even at very low volume setting - using any of the inputs with either speakers connected or disconnected. I can even hear it tripping when no inputs or...
Overload is another form of protect mode. See the link below for an explanation of protect. Also, in your specific case, the problem is definately internal to the amp rather than an external cause. Expect a parts cost in the $40 range. Feel free to post additional questions.
Thanks,
Dan
Link: http://www.fixya.com/support/r5390728-protector_means
May 01, 2011 | Marantz Audio Players & Recorders
Poor sound from 1 channel on a PM 66 SE Special Edition. Changed speaker and wire, no change. The sound is muffled and lower in volume. Same happens when tuner is on, so must be amplifier. Hope you can...
Hi...
My 1st thought would be a broken contact or 2 inside on the main volume control... Is the balance set to middle?
Is it the same with headphones?
Sep 24, 2010 | Marantz Audio Players & Recorders
Remote not working on Marantz 63cd. Tried
check the back of your marantz player, some old marantz products have a buttom at the back saying system or intermal, if it is on the system side, the remote will never works.
May 06, 2010 | Marantz CD-67 SE CD Player
Marantz pm 15 s1 amplifier and marantz sa15 s1 Cd player
There really is no point in  connecting the two components with an optical (=digital) cable, if you didn't want to use the SA-15s DAC- and analog output section you might aswell have bo bought the chiepest one you could find...
To get better sound than the SA-15s analog outputs can provide, you would have to spend a load of money (not as much as for the SA-15 but quite a bit) on a DAC - and the DAC would only work with CDs, you would still have to use the SA-15s analog outputs to listen to SACDs.
So in conclusion:
-Use the SA-15s analog outputs
-If you have other digital sources that you want to use - if you care about their sound quality - you can sell/return the SA-15s, buy the chiepest CD-Player you find (only look and feel matter) and spend the rest on a good DAC. (note: SACDs won't play on this setup)
I'm using a PM-15S1 with a DAC (Apogee Mini DAC, Studio-Equipment, nominal price ~1000$, got mine 2nd hand for 400€ ) myself. A DAC is usually the better choice over an expensive CD-Player - especially if you've got other digital sources (PC, ...) - but you'll probably lose a lot of money if you sell the SA-15, so think about it (IF you're still thinking about it, I realise that your question is 8 months old...)
anyway... have fun with the PM-15, it sure is beauty
Jan (Hamburg, Federal Republic of Krautistan)
Jul 01, 2009 | Marantz PM-15S1 2-Channel Amplifier
Marantz Pm-7200 left channel weak compared to the right
hmmm. Let's start by swapping the wires you are using for your speakers. Double check the wire connections first, then take the left and place iton the right and vice versa.
May 05, 2009 | Marantz PM7200 2-Channel Amplifier
Marantz PM 4000 has cut out
May be the problem solved here :
http://www.audiotoolers.com/ubbt/ubbthreads.php/ubb/showflat/Number/5316/page/1#Post5316
Nov 21, 2008 | Marantz Audio Players & Recorders
Marantz PM-48 connecting to TV
look on the back of the TV and there should be L/R audio outputs (white & red), connect this to a spare input of your amp via a connecting lead eg. AUX or any other input except PHONO.
hope this helps.
Oct 19, 2008 | Marantz PM-68 Amplifier
288 people viewed this question
 Grubhead
Grubhead
