I have a canon imagerunner C3380i. It will not feed an 11x17m or a 12x18 out of the drawer or the side feeder. It goes in about 1/2 way and then error codes out. whre i have to shutdown on the panel and then shutdown on the side of the machine. When it comes back on it is ready to go, but still will jam every time. is there a sensor or something i need to clean???
    President:
  • 1,469 Answers
Hi,problem can be solved. What particular code is it displaying?.
It all determines the type of code error,so we can be able to know how to describe the solution better.
But here are some codes for you to check out and see if one of them is the fault of the machine.
  • E000: The main thermistor reading does not reach 40ºC 14 sec after the fixing heater goes ON. (fixing low temperature error)
  • E001: The main thermistor reading reaches 220ºC or higher.
  • E002: A start-up fault is detected under any of the following conditions of the main thermistor
  • E003: After the end of the WAIT period, the main thermistor reading is 100ºC or lower. In standby, the sub thermistor reading is 50ºC or lower.
  • E004: At time of initialization, the ZEROXI signal of the power supply is not detected. During temperature control, the ZEROXI signal does not arrive for 3 sec continuously. A short circuit is detected in the triac
  • E010: A specific revolution is not detected from the main motor rotation detection signal.
  • E100: When the scanner motor is started up, the BD input signal does not arrive within a specific period of time.
  • When the scanner motor is started up, the motor rotation is too fast, and fails to reach a specific revolution within 20 sec at time of deceleration. While the scanner motor is rotating at a specific speed, the BD input signal cycle is not within a specific range (±2%) for an equivalent of 10 mm (print distance). While the scanner motor is rotating at a specific speed, the BD input signal cycle is not as indicated (±2%).During the WMUPR period after the power switch has been turned on or the front cover/left cover has been opened/closed, the drum unit is absent.
  • E719: The communication between the card reader and the image processor PCB is disrupted.
  • E805: After the heat discharge fan drive signal is generated, the fan lock detection signal does not arrive for a specific period of time.
  • E500: An error has occurred in the communication between the machine and the finisher twice continuously.
  • E514: The stack delivery belt does not reach home position when the stack handling motor (M2) is driven for a specific time (CW; if the same condition occurs during stack delivery, a jam will be identified).
  • E530: The rear aligning plate does not reach home position when the rear alignment motor (M4) has been driven for a specific time.The rear aligning plate does not reach home position when the rear alignment motor (M4) has been driven for a specific time.
  • E531: The stapler does not leave the stapling home position sensor (S13) within 0.5 sec after the stapler motor (M6) is rotated CW.The stapler does to return to the home position sensor (S13) within 0.5 sec after the stapler motor (M6) is driven CW and, in addition, it does not return to the sensor within 0.5 sec after the motor is driven CCW thereafter.
  • E537: The front aligning plate does not reach home position when the front aligning motor (M3) is driven for a specific time.The front aligning plate does not leave home position when the front alignment motor (M3) is driven for a specific time.
  • E551: The delivery fan rotation signal (FNALCOK) does not arrive within 1 sec when the heat discharge fan drive signal (FANON) is sent.
  • E577: The return roller does not reach home position when the delivery motor (M1) is driven for a specific time. (If the same condition is detected while alignment takes place in the direction of feed, a jam will be identified.)
  • E580: The stack tray upper limit sensor (S1) goes ON while the stack tray up/ down motor (M5) is in operation.The clock signal of the stack tray up/down clock sensor (S9) is not detected 15 times or more within 0.8 sec while the stack tray up/down motor (M5) is in operation.It does not reach the stack tray paper height sensor (S10) 2 sec after the stack tray up/down motor (M5) rotates for ascent.It does not leave the stack tray power height sensor (S10) 2 sec after the stack tray up/down motor (M5) starts to rotate for descent.
  • E585: The stack retaining lever does not reach home position when the stack handling motor (M2) has been driven for a specific time (at the start of motor CCW rotation). (If the same condition is detected during stack delivery, a jam will be identified.).
If you still need more help, will be waiting for your comment.
Take care.
Posted on Jun 07, 2010
Install web cleaner
open the front door. pull out drawer 1. remove the yellow cover, 1 screw. take out 2 screws, 1 front, 1 rear. remove old web. install new web,put the full roll on the right side with it feeding from top right to bottom left. if this is not installed correctly it will tear up the new web.
Jun 02, 2009 | Canon imageRUNNER 5000 Copier
My cannon imagerunner C3380i keeps jamming.
Make sure that the paper in the tray are set to the correct paper size. Also, the paper trays can be removed from the copier, remove them & look for any paper jammed or present blocking the paper path... Good Luck
Mar 19, 2009 | Canon C3380i Color Copier
Letter Drawer 1 on Model IR5020
look behind tray for paper preventing the feed rollers from knowing there is paper there
Feb 18, 2009 | Canon imageRUNNER 5020 Copier
Imagerunner 330S - just received this copier as a donation (we're a small nonprofit). Machine claims there is a paperjam in paper tray and side drawer. Doesn't seem to be paper in either location. Any...
check whether any sensor spring will open under stack bypass area, under toner area or under back panal fixing area or any short piece of paper in way of paper feeder
Feb 09, 2009 | Canon ImageRUNNER 330s Copier
No matter what way we put the paper in (feeder or on glass)
do you have the settings on the drawer right should be a round blue diail or slide, LTR is 8 1/2 side close to you LTRR is 11 inch side facing you
Jan 20, 2009 | Office Equipment & Supplies
Canon imageRunner 5055 copying in landscape instead of portrait
Double check paper orientation when you put paper into the feeder and how the paper is loaded.
The orientation of the page in the feeder and the page in the drawer should match.
Dec 16, 2008 | Canon imageRUNNER 5000 Copier
Printing bleeds
This machine, like almost every other laser based device on the market does not print bleeds.
The spec for the image masking at the edge is probably in the 3 to 4 mm range. When the sales person tells you that you can do "full bleed" what they are saying (even if they do not realize it) is that you can print an image larger than 11x17 onto a 12x18 sheet of paper and then trim the page back to 11x17 so that the final product bleeds over the edge.
Mar 03, 2008 | Canon imageRUNNER C3200 Color Printer
930 people viewed this question
jasbo
jasbo
