First Thing to do is power down your computer. Run a virus quick scan and remove any threats...Before powering up again, unplug your monitor from the CPU...Power up and plug in your monitor, this should reload the drivers. You can then go to your display settings box and select your monitor, as it will be the only one to select...This should solve your problem...
Other cpu`s than them on the list, does not fit the mainboard. This will cause the mainboard not to boot up, when the cpu is wrong. The (wrong) cpu will fit the socket, but it does not fit the cache size, fsb, and so on.
Hello Cornloh, Hi! it seems to me that the switching elements are not working, you need to check the Power transistor for shorts, and replace the IC (switching IC, usually IP3842). the easiest is to use an Oscilloscope to read/find the pulsing signal.
Sounds like your PC is diplaying out of your monitors range. Try pressing f8 while booting up to get safe mode. then turn down the video resolution to display what your monitor can handle. Good Luck.
If the light (yellow or pink) is flashing, your monitor is well. It's your CPU that is not giving a video signal to your monitor. Try to reset and notice if your CPU beeps. If it doesn't beep, then there is something wrong with the CPU... or the CPU's speaker.
Monitors are passive components in a computer system. These just receive signal from the CPU. You may find another CPU and connect your monitor to it to test if it really doesn't work. If it works, this may just mean that your video adapter has a problem.
You can also check the cable attached to the monitor. It may be damaged due to twisting or other causes. Check also if the port is inserted firmly.
Well as you have already tried disconnecting the peripherals from your computer, and tried restarting the computer too which did not help you, it sounds to be an hardware issue with the monitor. However if incase you have not tried this, you can disconnect the monitor completely from the tower, power on the monitor, if it powers on and you get a message as no signal, your monitor is working good. If not replace the monitor. If the message appears on the monitor screen, disconnect everything from the tower, push and hold the power button on the tower for a minute. Connect just the monitor and check for any display. If you do get display, thats good, connect one device at a time and check to see if the display appears.
If theres no display with just the monitor connected, the issue would be with the graphics card. You may need to replace it or get the system repaired.
If you mean the Monitor is powered by an external power supply
Then that indeed is an option worth trying
Simply get a multiple voltage one and set it to the voltage of the existing one.
There may be internal problems such as the inverter
But this will be a repair shop job.
