Question about EA - Electronic Arts The Sims Double Deluxe for Windows
Take down walls and fences - EA - Electronic Arts The Sims Double Deluxe for Windows
  • 30 Answers
Go to build mode and select the wall icon, then hold ctrl and delete the walls as if you were building over them
Posted on Jul 19, 2010
How do i stop my dog from jumping over the wall
Use an invisible dog fence. You can read this article Best invisible dog fence reviews and cost comparison PetHov to know more.
Jun 18, 2013 | Dogs
Square up fence to blade
with the tool unplugged from power . u need a good square drop the blade down to cutting position place thesquare against the fence then slide it up to the teeth on the blade making sure u are against the teeth . if not square in the zero position on the scale undo the fixing bolts for the fence and adjust till the square shows no gap between fence and blade teeth . retighten bolts and check . plug in and make a cut . or u could just make cuts and move fence till get it right . i should add with straight edge make sure the fence itself is straight across its face. with one piece fences they can get bent. good luck.
Aug 14, 2011 | Makita 10" Miter Saw LS1030N
I installed the heater to the minimum distance from the ceiling due to the vent cap on the outside wall. The way I read the instructions it appeared the the end of the vent cap could not be within...
the flue is what is called a balanced flue, air in the other flue to burn inner flue is outlet gases , so you cannot just put any flue on there if is not in the makers instructions i would say no or contact the makes to be sure, how far is it from the fence
Dec 03, 2010 | Williams 1403622 Gas Compact Heater
Rip fence to saw blade alignment
I dont believe there are pictures, but what you need to do is move the fence to the blade, there are 2 10MM bolts on the backside that you need to loosen and then you can move the fence to square with the blade. Snug them down and move the fence and recheck let me know if you have anymore problems
Jul 18, 2010 | Dewalt DW744S 10" Portable Table Saw with...
New table saw, timber runninig off away from guide, saw blade running its own line,do i need to reset the guide.
The guide is called a fence. The fence should be positioned to the right of the blade. When using the fence, the largest part of the board goes between the blade and fence. Fences are typically have some relief toward the end, so you don't get the blade cutting on it's way down, and then cutting again on it's way up.
Apr 22, 2010 | Craftsman 10" Table Saw
Can the dewalt 705 cut a 45 for a corner on crown molding? It'll cut a 45, just not the 45 cross ways for the moldings to come together at the corner. Any thoughts if we are lacking tools?
it seems that you are not "bedding" the molding up properly in the saw.
imagine the saw being the ceiling and the fence being the wall.
Hold the molding in the saw the way it would be installed, with the base being the ceiling and the fence being the wall
Swing the saw to a 45 degree angle and make the cut.
If you need more help, contact me at builtbybob1@bellsouth.net
Nov 22, 2009 | Electrical Supplies
Blade isn't cutting well. It smokes and the wood rides up as it is cutting. The saw is 14 yrs old but blade has only been used a few times. I think it needs alignment. Can I do that myself?
You should be able to adjust the fence but every model is different so I probably cannot tell you exactly how. My Biesemeyer fence has 2 set screws on front guide of the fence for parallel adjustment to the blade (this fence is a single piece fence). I had a Sears contractor saw that had 2 bolts on the top of the fence that needed to be loosened, the fence moved parallel, and the bolts tightened again (the Sears fence was a bolt together fence). Whatever fence you have I would think the adjustment would be on the front part of the fence. I would remove the fence (the fence only, not the guides) from your table saw and take a close look at it for any adjustment screws (the Biesemeyer set screws are somewhat hidden) . If the fence bolts together you will probably need to loosen the bolts to do the alignment. There is a quick check you can make to verify the problem is the fence not being parallel to the blade because your problem could also be caused by a bent saw blade arbor (the saw blade would wobble as it turns)
ø Lock your fence down and measure from the front of the blade to the fence and from the back of the blade to the fence. These measurements should be within 1/32” (ideally is should be zero).
ø If the fence passes the test above, you can see if your saw blade shaft is bent by sliding the fence very near the blade, locking the fence down, and rotation the blade by hand (unplug the saw first). If the blade rubs on the fence as it rotates then you could have a bent arbor, a bad arbor bearing, or a bent blade.
Oct 03, 2009 | Craftsman 10" Table Saw
Biesemeyer fence not parallel to blade.
Yes you can adjust the angle of the fence. There are two adjusters at the front of the fence where it meets the fence rail. Adjusting these will pivot the fence either slightly left or slightly right.
There is a basc video on youtube my daughter made to show you how to align yourfence to the saw blade.
Feb 28, 2009 | Delta Machinery 3 HP Left Tilt Unisaw with...
Zoo tycoon on ds, how to expand enclosures?
well you built a fenced enclosures right then what you is build more fencing next to it to expand it then delete the wall between them
Feb 21, 2009 | Video Game Consoles & Games
EA - Electronic Arts The Sims Double Deluxe for Windows Logo
46 people viewed this question
Top EA - Electronic Arts Video Game Consoles & Games Experts
James Wishart
 Shayaan Tanwir
Shayaan Tanwir
Person On the...
Level 1 Expert
Are you an EA - Electronic Arts Video Game Console and Game Expert? Answer questions, earn points and help others
