Question about Kenmore 2383x
DRUM WILL NOT AGITATE OR SPIN. BELT IS TWISTED
  • Kenmore Master
  • 8,220 Answers
What you probably have is a failed lid switch.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jun 04, 2010
  • Dan Webster
    Dan Webster Jun 04, 2010
    Post your model number, I might have a manual.
How to find out if belt needs replacement on a whirlpool WTW4800X02
Does it agitate? That is does it spin back and forth during the wash cycle ok? The agitate and spin are through the same drive belt, so if it does one and not the other its probably not a belt or motor issue. When it gets to the spin cycle does it try to spin, do you hear the motor or anything run or the drum try to spin?
Jan 02, 2018 | Whirlpool Washing Machines
Hoover optima 614 drum wont spin
Either a broken drive belt or a failed transmission.
Jan 12, 2015 | Hoover Washing Machines
Hi, I just purchased an older style washer dryer combo. When loaded (with as little as two towels) it doesn't agitate or spin. Belt is fine. Drum starts to turn but can't make it up the hill. Any sugg
Your motor may be having trouble starting due to a bad capacitor or start winding in the motor. Ideally you want to use a multimeter to test resistance of the start winding.
Jul 31, 2013 | Washing Machines
The washing machine belt will move to agitate, but will not move to spin. The spin action burns up the belt. This is an Amana LWA50AW
open rear cover , see if belt slips. then remove belt and rotate empty drum if its jam than drum bearings need to change. if drum is free then belt might be loose and needs replacement.
Nov 05, 2009 | Zanussi FJS1225W Front Load Washer
The drum won't spin or agitate the cause is the belt slipping off
There is a mechanical alignment problem beyond your ability to fix. Get a repair Tech and pay for a service call.
Oct 24, 2009 | Washing Machines
My kenmore washer will not spin or agitate. It
i dont know what model this is, but hopefully its a belt type.un plugg unit, place on its side and check if belt is broken or slipping. if enclosed transmission type, it is a big repair.
Sep 04, 2009 | Washing Machines
Won'i\t spin or agitate. was working fine-went
Hi..
if agitator movement is weak or moves in only one direction check the following:
  • Inspect the agitator
  • Inspect the motor coupler
  • Inspect the drive belt(belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
  • Inspect the pump coupling
If drum does not spin check this:
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the drive belt (belt drive only)
  • Test the motor
Good luck !!!
Regards
PCmania
Jul 11, 2009 | KitchenAid Washing Machines
Kenmore 2383x Logo
23 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
