Question about Garden
I am trying to find info for a ranch king pro rear tine tiller, the engagement cable is broken and i can't seem to find any cable to replace it with or anything about a ranch king pro tiller, the engine is a briggs & stratton
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 146 Answers
Looks like Ranch King Pro is made by MTD. The part is probably the same, but to be safe, take your old cable off and take it to a lawn equipment service shop to match it up. Shouldn't cost more than $10 - $20.
Posted on Jun 04, 2010
Tines on tiller
-Check the locking bolt that hold the tine shaft to the main shaft. Possibly it's broken. If so replace new bolt. you should be good to go again.
Good Luck
mai
May 24, 2014 | Craftsman 17 In. Dual Rear Tine Tiller
I have a Yard Machine rear tine tiller that has sat unused for 4 years. I replaced the engine and while in goes forward and backward, when I engage the tines they won't rotate and the engine bogs
Transmission/differential.
Perhaps the unit sat for 4 years because the tines would not turn and your replacement engine has not solved the real problem.
I'd say disassemble the chain case to discover what's locking the tine drive.
Apr 12, 2013 | Garden
Belt will not tighten when tines are engaged
There should be a spring on the other end of the engagement cable connected to the take up (idler) pulley. It sounds like it have broken or came off. You will need to removed the side cover and inspect. After you have the cover off, pull the engaging bar and watch the take up pulley for correct operation.
Jun 02, 2010 | Craftsman 8.50 Torque Rating Dual...
Mtd rear tines tiller won't engage tines. F and R
I had similar problem recently with 2007 Huskee MTD series 410. The shift assembly bent and couldn't move the clutch collar all the way over on the drive shaft.
Apr 23, 2010 | Mtd Products Yard Machines 158CC Tiller
Rear tine craftsman wont engage in any gear. feels like there in no connection from handle cable to engagement
That is correct "Only if the shifter cable isn't broken!" And if it is a linkage type, make sure all of your clevis pins are in place. And on mine even if i get it in gear...the "dead man" is cable connected for sure. Make sure when you squeeze the "safety stop" or "Run/engage" lever that it is actually moving a lever at the other end. If so? Then trans box is next to inspect. But that would have had to suffer a nasty jam to damage that. And again with other people I've seen this a hundred times with rear tine tillers. Sometimes it just "cogs out" into a state of "bad mesh" with the gears and all that is needed is to push or pull the tiller a bit while you try to engage the shifter. The wheels just got be rolled a tiny but and "Voila!" you've managed to free up the meshed gears to a state of freedom. Sometimes its that simple!
Apr 22, 2010 | Craftsman 8.50 Torque Rating Rear Tine...
Mtd rear tine garden tiller . The wheeles will engage and turn forward and reverse but the tines will not engage. At first they would but would pop out of gear. Now they w9ont engage at all.
Could be the shifter inside the gearbox or it could be a stripped gear or broken chain. The bad news is you will have to remove the gearbox from the engine and then open the gearbox to see what is going on. This is quite time consuming but taking to a shop for this is very expensive due to the labor involved. You can do it yourself if you pay attention to how you take it apart. I hope this helps you out.
Apr 04, 2010 | Mtd Bronco Rear Tine Tiller
Tines won't turn
Possible broken key where crankshaft meets gearbox.
May 15, 2009 | Mtd 21a 643b066 Bronco Rear Tine Tiller
Broken clutch cable connector, MTD Tiller
I found micro fiche on jackssmallengines.com . Click on the manufacturer's tab at the top of the page then you'll have the option to use an off-site tool to locate your machine. I used it and found my 1990 mtd rear tine tiller. I needed the cable that engages the tines - maybe the same as you. The part number for my 1990 model's cable was 746-0535. Dont know if it was still the same in 96 to 98. But look at the fiche and see.
Apr 04, 2009 | Mtd Products Yard Machines 158CC Tiller
Stateman Tiller tine not engaging
Sounds like the worm gears are worn to the point they will not engage.
Feb 20, 2009 | Craftsman Rear Mount Tiller
Garden Logo
482 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
