Question about GPS
I dropped my garmin and the little button that turns it on and off popped out. I used a pen tip to turn it on and off when I wasn't in the car but now it has locked the screen and I can't get it unlocked. Is there a way to open it so I can put the little on/off switch back in without damaging it.
  • 666 Answers
I would say to just contact garmin and see about sending it in to them for a new one or purchasing a new one of same brand and than returning the old one but as far as the dissemblance of it you would probably cause more errors or issues by opening it up
hope this helps
Robb
Posted on Jun 04, 2010
My garmin nuvi 260 gps wont come on and have already replaced power/ charging chord. What might b the problem?
Sometimes you have to do a reset/reboot on your systems. Turn your Garmin backwards and if you look along the label you can see a little circle that says reset. Plug the power cord into the Garmin and with a pen or your finger nail push the reset button for 5 seconds and flip the power switch on the Garmin. I have done this a couple times, after the reset you may have to reload map packs if you have already updated your Garmin.
Sep 04, 2014 | GPS
I lost my manual for setting time on a White Deuce Watch. Where can I find instructions
You will need something with a fine point, like a pen. Turn the watch inside out and you will see two small buttons that are used to adjust the time. Place the tip of the pen on the top button and press it 4 times - or until you see the P or A pop up (PM or AM) or time (hour or minute) or date (day or month) flash. Then use the tip of the pen for the bottom button and press it until you get the correct hour of the day. Hit the top button again to get to the minutes. Press the bottom button until you get the correct minute of the day. Press the top button again until you get back to deuce blinking on the watch and you are done.
Dec 24, 2010 | Guess Watches
Garmin nuvi 260 won't turn on
There is a reset button on the bottom of the unit. Push it in with the tip of a pen. Worked for me!
Aug 12, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 205 WIll not power on
Press and hold the reset button with a ball point pen for eight seconds.
The reset button is nearly invisible. On the bottom of the unit is a grey label with a bunch of writing on it. There's a little splotch of printing with a circle, crosshairs, and the word "Reset." You'll ahve to look carefully. You can't actually SEE the button. It's beneath the circle on the label.
Use a ball point pen, press in at the circle and hold for eight seconds.
Jun 11, 2009 | Garmin nuvi 205 GPS Receiver
GArmin 205W won't turn back on
I recently ran into the same problem, my 205w would not power back on. I logged in Garmin website under repair solutions. Said hit reset button using pen or stylis. My 205w does not have a
reset button....further comments in the reset instructions said if your device does not a button,
slide on switch to the left and hold 10 to 15 seconds it should power on while your holding it.
it took 12 seconds for me... This was refered to as a soft reset
Hope this helps, Enjoy!
Apr 22, 2009 | Garmin nuvi 205W GPS Receiver
My garmin GPS wont turn on
there should be a reset button (probably on the back). take a pen and push it, then it should reboot.
thanks
please rate me and give me a fiya! if it works for you.
Apr 04, 2009 | Garmin nuvi 260W GPS Receiver
My Wacom Bamboo Tablet Pen: only the pen was dropped. Now the eraser works but the pen tip does not. Neither do the buttons. The tablet itself does not pick up the pen tip's presence, but it works perfect...
Try replacing the pen nib. Take out the little nib with a tweezer or something along those lines and replace it with a new one. There should be a few of them when you bought the tablet. Also, try looking at the tablet properties.
Feb 02, 2009 | Toshiba Portege M200 Tablet PC
Brand new only month old Nuvi 205 and ont turn on no reset button
I had the same problem.
Jan 18, 2009 | Garmin nuvi 205 GPS Receiver
Wacom Bamboo Fun Pen isnt working correct
I think you dropped the pen on its tip and broke the little ferrite sensing core.  You can try to repair it by gluing the core back together - it worked for me.  For detailed instructions on how to do it, go here: http://wishidknownthat.blogspot.com/2009/04/fixing-wacom-bamboo-pen.html  or you can try to swap the core for the eraser and the tip (more involved - you would need to be very good with a soldering iron to attempt this).  Either way - it's unfortunate that the pen is so fragile and that the user manual doesn't really warn you of this.
Jan 17, 2009 | Wacom Bamboo Fun 8.5" x 5.3" USB Tablet...
Pen Won't STOP Working
Well... I contacted Wacom support and the guy who write back recomended me to change the nib, to turn 3 times the eraser and to hit 4 times with the pen onto your palm hand...
Of course I didn´t do anything like that, I mean, what´s that??? An spell of some sort (or what)???
But what I did was the following (MAC-OS user):
-Enter to the pen tablet options on your preferences
-Switch the sensitiveness of the pen to the hardest
-Run an app that work´s best with your tablet and make some lines to check if at least in this mode the pen works
-Return to your tablet preferences and adjust at your best
I can´t explain why but my stylus is working fine again...
hope someone find this useful...
Oct 20, 2008 | Wacom Bamboo Fun 5.8" x 3.7" USB Tablet...
GPS Logo
15 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
