Question about Nikon COOLPIX S610 Digital Camera
My camera got wet at the beach. It wasn't totally submerged, just splashed, and now the shutter won't close. Everything else still works and it still takes pictures and all, so is it worth fixing? How would I do that?
    Novelist:
  • 162 Answers
Hi. I think you just have to let it dry for the meantime, because same thing happen with my Sony T100 but what happen is the play button is grounded and when i press it it would take a picture instead of viewing the picture inside, so i just let it dry before I'd use it again, but sadly same thing happen the next time it this time it got submerge in the sea water now it wont even turn on, the tech told me that the motherboard needs to be replace. I think on your case in case after letting it dry but still has the issue then you should bring it to a camera tech. Hope this Helps
Posted on Jun 04, 2010
  • 4,102 Answers
Hi the only thing you could try is to go to a computer repair shop and buy a small can of compressed air their about the size of deodorant can, buy one of these and then give the shutter a good blast with the canned air this should then dislodge and sand or grit that it causing the shutter to remain open.
another thing you can try is hold the camera in your one hand and then hit the side of the camera into the palm of your other hand, this wont damage the camera but doing this should shock any grit out thats stopping it from closing try doing this with both side of the camera it should dislodge what ever is keeping it open give it a few hard hits into the palm of your other hand, so that the side of the camera is hitting the palm of your hand.
so hold the camera on its side not the way you would to take picture tip it on its side then hold it like that then hit the camera into the palm of your other hand, doing this should free it up and get it closing again for you.
it would also be a good idea to get the can of air as this will ensure you have removed all the grit and sand from the camera.
let me know how you get on or if you need further assistance ok
My father dropped my Kodak camera into the sand and it won't work now
If there's sand in the mechanics of the shutter flap and you can hear more that's stuck inside, there's nothing you can do except take it to a camera technician. It'll need to be disassembled, thoroughly cleaned and reassembled.
You will more than likely do more damage if you try turning it on or shaking it to get the sand out.
Sorry to hear about it!
Aug 02, 2012 | Kodak Md863 Easyshare Digital Camera...
My olympus tough tg-310 got wet inside with salt water form the beach now it won't turn on please help.
There is very little that can be done, salt water will corrode metal on contact, all eletronic parts have been compromised, if the memory card is still intact save your pictures and remove it from the camera to transfer to new hardware. Replacing the camera unfortuneately is the only option.
Apr 02, 2012 | Olympus TOUGH TG-310 Digital Camera
My droid 3 fell into the sink and got wet, it wasn't totally submerged it splashed into a dish that had some water in it, I put it in a bag of rice overnight and when I turned it on this a.m....
First thing is take out the battery and dry the battery with a towel or paper towel. Allow it to dry for a while and in the meantimelet you phone dry out. There is suppose to be a seal around the phones main board to keep out moisture so if it didn't get to wet it should be OK. After about 30 minutes the battery should be dry enough to put back in and then try to turn the phone on. In most cases it will work.
Sep 07, 2011 | Motorola Mobility Droid (2 GB) Cell Phone
My Kodak Easyshare V1223 turns on and shows all icons normally on the view screen as well as older pictures on the memory card...but shows everything else black and pictures remain black even with flash...
Hi!
It is not necessary something wrong with the camera itself. Sometimes the simptom is caused by the memory card. Reading from it works (so you can see older pictures) but every new picture is written wrong, so the camera shows only black.
Hope it is only the memory card in your case.
Good luck,
Bogdan
Aug 28, 2011 | Kodak EASYSHARE V1253 Digital Camera
I have a nikon N2000 35mm slr, before it was fully functional, now the problem is, The shutter won't open/close but the rest of the camera controls are still functional. Camera wasn't set on B...
So I assume you have changed the batteries and made sure there isn't any corrosion on the contacts. If your mirror is flipping up but no shutter, it sounds like a bad shutter. Check the shutter from the back, then from the front behind the mirror. Look for abnormalities or residue. It is a great camera and uses standard batteries (!) but the 1/2000 shutter has a half life like any other SLR. If you are going to throw it out you may want to open the back and use a q-tip to drip a couple drops of 90% alcohol on the top and bottom (and sides) of the shutter. As a last ditch, I throw cameras or lenses in the toaster oven at 200° for 10 min. and retry (take out batteries and film). At the least it will kill any fungus at the worst it hardens some lubricants. It does make you feel like you are doing some specilized scientific work before you toss it in the trash.
Jan 07, 2018 | Nikon N2000 35mm SLR Camera
What do i do when my camera got wet and it wont turn on?
It all depends on if it was totally submerged or if it was slightly exposed. If it was totally submerged, there is not much to do at this point. It will need to be replaced. The entire unit will not work as designed, due to the severe water damage. Now; if it was slightly exposed to a minimal amount of liquid, simply, separate the internal component and batteries away from the cover housing and let them dry out for 5 full days. Once the dry out period has been completed, reassemble the unit and load a fresh set of batteries. It should work now.
NOTE_ The dry out method will not work if you have already tried to operate this unit shortly after the water damage occurred. Energizing a wet system board will cause a short,thus, damaging the entire unit.
Aug 10, 2010 | Sony Cyber-Shot DSC-S40 Digital Camera
Iphone got wet. camera shutter is stuck closed
you might have a lot of corrosion inside your phone.
try to open it up and clean it very well with alcohol.
the main camera does not work probably because of corrosion on its connector to the main board.
see the picture I took a few days ago:
Aug 29, 2009 | Apple iPhone 3G
Review windows is black, pictures are black
A stuck shutter is a common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jun 12, 2009 | Cameras
Salt water splash....
I hope by now you've taken it to a repair shop - salt water is deadly to any camera after 2 or 3 days it'll be uneconomical to repair.
Jun 26, 2006 | Canon PowerShot S500 IXUS 500 Digital...
Nikon COOLPIX S610 Digital Camera Logo
172 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
