Question about Canon imageRUNNER 5000 Copier
Replacing upper fuser roller
When replacing the upper fuser roller, it seems there is an easy way to get the web assembly out of the way of the upper fuser roller? Yes or No
  • 149 Answers
There really is no need to remove the cleaning web when replaceing the upper fixing roller.... it stays in place and will not present a problem apon replacement
Posted on Jun 09, 2010
What does replace the cleaning web mean?
Cleaning web is a prediatecally replaceble part.,its a part of fuser assembly which cleans the fuser roller surface and applies lubricarion to avoid ghost image, toner stains, paper jams. Its look like a paper roller very near to fuser roller depends on model.
Oct 04, 2014 | Ricoh Office Equipment & Supplies
Canon ir2000 fusing unit film or top roller
This model has an upper fusing roller & a lower pressure roller.
If you have a print quality issue (that you have narrowed down to the fuser unit) then you will need to replace the upper fusing roller (not an easy job best to replace the fuser unit complete)
Aug 24, 2014 | Office Equipment & Supplies
The paper is crumpled in the lower part of the paper.
Maybe you have problems with the upper fuser roller, open the back door and try to see the upper fuser roller and lower pressure roller if you see any wrinkles or damage in any of the rollers that's is the problem, you can replace them just the upper fuser roller and the lower pressure roller but it will need advanced skills, the other option is change all fuser assembly but at higher price
Nov 26, 2013 | Brother HL-5250dnt Laser Printer
What does E005 mean?
The error code means that fuser cleaning web is about to run out or has run out. The fuser cleaning web cleans off the upper fuser roller (the hot one) and it also lubractes the roller. Most of the time when it runs out it starts to ruin the upper fuser roller. The best thing to do is to have the web replaced and the counter rest. If you just rest the counter, you may end up causing my damage to the fuser unit. Good Luck
Apr 10, 2012 | Canon imageRUNNER 400S Copier
Done shown as 005
A E005 error code means the fuser cleaning web needs to be replaced. It cleans & lubricates the upper fuser unit. It is the white web that rest above the upper fusing roller. There is also a web counter in service mode that will need to be reset as well. You can just rest the counter, but if the web runs out > the upper fixing roller will be damaged. Good Luck
Oct 04, 2011 | Canon imageRUNNER 400S Copier
Fuser upper failure is the message i am getting on my xerox phaser 7300. can anyone help please
Hello, The fuser or fuser roller is what actually bonds or melt the toner on to your paper. There is probably some type of temperature sensor, that senses the temperature of the fuser. If its not hot enough or just plain dead, it will give out an alarm similar to what your getting. You probably need to replace the fuser unit. You have a lower fuser and an upper fuser. You might be able to get away with just replacing the upper roller. The roller has a heating element inside and that's what probably defective.
Hope this Helps
Thank You for your feedback
Jan 31, 2011 | Xerox Phaser 7300DN Laser Printer
Sharp AR-M700N damaging fuser rollers. I just replaced both rollers, Upper and lower, the cleaning rollers as well and when I installed on the machine it bacame so hot it rip off the skin of the lower...
it sounds to me like you have some severe fuser thermistor and thermal fuse problems ...i would look into getting an entire fuser assembly sharp part number DUNTW7305DS** last digits depend on your location and power supply
Feb 06, 2010 | Sharp AR-M700N Copier
Re: Removing the upper fuser roller assemble.
I am not sure what the black legs do but they problably support the heater lamps....if there is a wire going to the legs then the black legs need to be removed. the key is to d isassemble any drive chains, brackets etc that support the fuser rollers the black legs could also be support for stripper fingers
just dissasemble all components holdng the fuser roller from both sides
best of luck
Jan 17, 2009 | Office Equipment & Supplies
Upper (gray) fuser roller needs replacing, (tear on 1 side).
If you are handy it is not hard to replace the upper fuser roller you will need a small phillips screwdriver and pliars
the fuser lamp goes through the fuser roler so youmust disconnect the power leads to the lamp and remove the lamp
You do have to release the back side of the drive
gear on the fuser roller
when you install the new roller be sure to put some silicone fuser oil on the cleaning pad
take your time good luck
Jan 04, 2009 | Office Equipment & Supplies
Xerox 416si print or copy are dirty
the problem is upper heat roller of the fusing unit are defective.try to ask xerox u.s.a if you can buy only the upper heat roller.
Apr 14, 2008 | Office Equipment & Supplies
Canon imageRUNNER 5000 Copier Logo
136 people viewed this question
old marine
old marine
